    Duet3/pi DCS is unavailable after wiring 24V
    duet 3 rasberry pi
    8
    166
    12.0k
    • fractalengineerundefined
      fractalengineer
      @bearer But is it really? I probed the pins directly on the board like so and they all showed continuity; that is the direct signal from one board to another
      @chrishamm any feedback on the image result?
      Thanks
      Railcore II ZL
        A Former User @fractalengineer
        @fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
        unless the probe exert no force on the board and connector, I'll stick to "probaly", or even "most likely" but at the end of the day it doesn't matter, the cable is a fraction of the cost of the board so just get both replaced for good measure even if its most likely not a cable fault.
        • Azulundefined
          Azul @fractalengineer
          @fractalengineer same problem i just completed the procedure described still no luck
            @fractalengineer, thanks for doing that. We suspect a hardware problem. Please ask your supplier to replace the Duet and ribbon cable under warranty. You may refer your supplier to this post for authorisation.
            @Azul, please start a new thread for your issue, explaining what the problem is, what software versions you are using, and what you have tried.
            fractalengineerundefined 1 Reply Last reply Reply Quote 0
              fractalengineer @dc42
              @dc42 Hi Tony; well ok I bought it directly from Duet, order #7829. Will send a request RMA. Thanks
              Railcore II ZL
                dc42 administrators @fractalengineer
                In that case, see https://www.duet3d.com/warranty for the procedure.
                  fractalengineer
                  Hi Again...
                  So I just received my replacement board and I'm still getting an error
                  Here's what I did upon opening up the box:
                  1-Wrote @chrishamm image on the SD card
                  2-Flashed the board to 3.01 RC7 using Bossa
                  3-Connected the pi to the board
                  Here's the error message I get; it's different than last time:
                  pi@duet3:~ $ sudo journalctl -u duetcontrolserver -e
                  Apr 23 11:09:06 duet3 DuetControlServer[2500]: Licensed under the terms of the G
                  Apr 23 11:09:09 duet3 DuetControlServer[2500]: [info] Settings loaded
                  Apr 23 11:09:09 duet3 DuetControlServer[2500]: [info] Environment initialized
                  Apr 23 11:09:10 duet3 DuetControlServer[2500]: [fatal] Duet is not available
                  Apr 23 11:09:10 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                  Apr 23 11:09:15 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                  Apr 23 11:09:15 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                  Apr 23 11:09:15 duet3 systemd[1]: Stopped Duet Control Server.
                  Apr 23 11:09:15 duet3 systemd[1]: Started Duet Control Server.
                  Apr 23 11:09:16 duet3 DuetControlServer[2566]: Duet Control Server v1.3.2
                  Apr 23 11:09:16 duet3 DuetControlServer[2566]: Written by Christian Hammacher fo
                  Apr 23 11:09:16 duet3 DuetControlServer[2566]: Licensed under the terms of the G
                  Apr 23 11:09:18 duet3 DuetControlServer[2566]: [info] Settings loaded
                  Apr 23 11:09:19 duet3 DuetControlServer[2566]: [info] Environment initialized
                  Apr 23 11:09:20 duet3 DuetControlServer[2566]: [fatal] Duet is not available
                  Apr 23 11:09:20 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                  Apr 23 11:09:25 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                  Apr 23 11:09:25 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                  Apr 23 11:09:25 duet3 systemd[1]: Stopped Duet Control Server.
                  Apr 23 11:09:25 duet3 systemd[1]: Started Duet Control Server.
                  Apr 23 11:09:26 duet3 DuetControlServer[2596]: Duet Control Server v1.3.2
                  Apr 23 11:09:26 duet3 DuetControlServer[2596]: Written by Christian Hammacher fo
                  Apr 23 11:09:26 duet3 DuetControlServer[2596]: Licensed under the terms of the G
                  I don't understand what's going on anymore.
                  Following the getting started guide I even enabled SPI and started DCS; still no luck
                  Really bummed out now; any idea what to do?
                  I left all the components version as is from the image:
                  pi@duet3:~ $ apt list 2>/dev/null | grep duet
                  duetcontrolserver/now 1.3.2 armhf [installed,local]
                  duetruntime/now 1.3.2 armhf [installed,local]
                  duetsd/now 1.0.6 all [installed,local]
                  duetsoftwareframework/now 1.3.2 armhf [installed,local]
                  duettools/now 1.3.2 armhf [installed,local]
                  duetwebcontrol/now 2.1.2 all [installed,local]
                  duetwebserver/now 1.3.1 armhf [installed,local]
                  Railcore II ZL
                  • chrishammundefined
                    chrishamm administrators
                    Do you have a spare Raspberry Pi? If you can confirm proper connectivity between the Pi and the Duet 3, then the only option left is a damanged SPI controller on the Pi itself.
                    Duet software engineer
                      fractalengineer @chrishamm
                      @chrishamm We tried another pi on the previous board already, that's why I'm so confused
                      I can try again on the new one
                      Railcore II ZL
                        did you confirm the new firmware version with M115 or M122 after flashing?
                        (not that it'd matter, but they have released RC9 since last time.)
                          fractalengineer @A Former User
                          @bearer yep
                          M115
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC7 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-14b3
                          I'll try RC9 fwiw
                          Edit: Yeah RC9 no luck
                          Railcore II ZL
                            A Former User
                            Not to make light of the situation, but I did say you should get the volcano insurance..
                            So you've tried new pi, new cable, new duet.
                            That leaves power supply?
                              @bearer lol
                              Well so far I tried different USB ports, including the 3A charging port, and powersupply when powered through VIN is a brand new MeanWell 350W 24V
                              The 5 and 3.3V power lights on the Duet are on as they should when plugged in usb
                              Railcore II ZL
                                A Former User
                                Unless you've got a scope or a logic analyzer I'm out of ideas; sorry.
                                  @bearer yes I'm looking forward to try another pi
                                  One thing happened to me once on a quadcopter
                                  It used a separate board for ESC connected to the flight controller board by pwm
                                  One day I plugged in and one motor started acting funny; then after trying to connect to the firmware front end it got worse, and eventually, the flight controller became unresponsive.
                                  A couple messages back and forth with the FC designer (used an STM32 F7 chip; wasn't junk) he told me he had experiences of shorts happening on the ESC, running back to the FC board and frying sectors of the chip
                                  Anyway I have no clue what's going on, but if anything I would like to try if there's a possibilty something on the old board may have fried the SPI capability of my pi on top of it's own
                                  New duet and new pi must do something
                                  Railcore II ZL
                                  • Danalundefined
                                    Danal
                                    I believe those two won't talk to each other. I would do a standard
                                    sudo apt update
                                    sudo apt upgrade
                                    And let the system move itself to DSF 2.1.0. That should fix things... but... it may not be able to auto-flash the board.
                                    • If, after the update/upgrade, your apt-list shows duetsoftwareframework/now 2.1.0 armhf [installed,local], and things are still not working, then bossa the board with the file /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                                    • If, after the update/upgrade, your apt list shows anything else for DSF itself, ask again here.
                                    You are very close. We'll get you going.
                                      fractalengineer @Danal
                                      @Danal Thank you;
                                      So I just updated the packages and I saw this message while it was running: (line 4)
                                      Setting up duetwebserver (2.1.0) ...
                                      Setting up git (1:2.20.1-2+deb10u3) ...
                                      Setting up reprapfirmware (2.1.0-1) ...
                                      Setting up rpi-eeprom (5.8-1) ...
                                      Setting up duetsoftwareframework (2.1.0) ...
                                      Processing triggers for mime-support (3.62) ...
                                      Processing triggers for libc-bin (2.28-10+rpi1) ...
                                      Processing triggers for man-db (2.8.5-2) ...
                                      Processing triggers for desktop-file-utils (0.23-4) ...
                                      Processing triggers for initramfs-tools (0.133+deb10u1) ...
                                      duetcontrolserver/unstable,now 2.1.0 armhf [installed,automatic]
                                      duetruntime/unstable,now 2.1.0 armhf [installed,automatic]
                                      duetsd/unstable,now 1.0.6 all [installed,automatic]
                                      duetsoftwareframework/unstable,now 2.1.0 armhf [installed]
                                      duettools/unstable,now 2.1.0 armhf [installed,automatic]
                                      duetwebcontrol/unstable,now 2.1.4 all [installed,automatic]
                                      duetwebserver/unstable,now 2.1.0 armhf [installed,automatic]
                                      Still not working.
                                      I can't find this location /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin But the board is already flashed in 3.01 RC9.
                                      M115
                                      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-21b1
                                      I'll borrow my friend's pi 4 in a couple hours; keep you posted
                                      Railcore II ZL
                                        fractalengineer
                                        Man I don't get it anymore...
                                        On the other Pi the wifi now doesn't work; I triple checked the wpa supplicant and it still won't show on network
                                        Meanwhile, even through the HDMI it still shows DCS not started
                                        Halp
                                        Railcore II ZL
                                          i'm sure we can figure that out, maybe do a new thread after having tested the new pi
                                          • Danalundefined
                                            Danal
                                            Progress! Clearly upgraded to 2.1.0
                                            Line 4 I sort of expected. That is why we may need to bossa the board one more time. After we get everything in sync, future upgrades will take care of this and keep things in sync.
                                            Not finding /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin is a little concerning. Can you please:
                                            ls /opt/dsf
                                            ls /opt/dsf/sd
                                            ls /opt/dsf/sd/sys
                                            And post the results here?
