    Setting up Z Probe M558 problem
    • Skaterundefined
      Skater
      I need help setting up my BLTouch 3.1
      When I add the code M558 P9 F100 H5 R0.2 T6000 A5 B1 it sets the Z-probe to 1000. When i add the I1 to invert the signal it goes to 0. All the actions, drop pin, raise pin, test, and reset all work. The issue is when I go to home the z-axis, it never triggers. I set it up using BeTrue3ds set up and changed P5 to P9.
      Let me also add that this issue started when I added a Mosquito hotend and thermister.
      Any help would be appreciated.
        What firmware version are you using? Which board?
        Post your config.g and homeall/homez
        • Skaterundefined
          Skater
          Config.g
          M550 P"FT-5" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M350 X32 Y32 Z32 E32 I1 ; configure microstepping without interpolation
          M92 X161.61 Y160.00 Z797.26 E832.28 ; set steps per mm
          M906 X1100 Y1200 Z1200 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X300 Y300 Z400 S0 ; set axis maxima
          M307 H7 A-1 C-1 D-1;
          M558 P9 F100 H5 R0.2 T6000 A5 B1 ;
          G31 P25 X20 Y0 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
          M557 X25:285 Y15:285 S20 ; Define mesh grid
          M305 P1 T100000 B4267 R4700 ; Set thermistor + ADC parameters for heater 1
          M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          Homeall.g
          G91 ; relative positioning
          G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X40 Y15 F6000 ; go to first bed probe point and home Z
          Homez.g
          G1 X40 Y15 F6000 ; go to first probe point
          Thanks
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in Setting up Z Probe M558 problem:
            I say again...
              Phaedrux Moderator @Skater
              @Skater said in Setting up Z Probe M558 problem:
              Have you tried the static test described here? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
              Are you saying that triggering the pin during a G30 move does not stop the movement?
              • Skaterundefined
                Skater
                Board is Duet Wifi 1.04
                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
                Duet WiFi Server Version: 1.23
                The issue is the input for the probe is always high. So when the probe is started it stops right away.
                The probe input is high even when there is no probe attached. I did not have this problem before I added the new thermistor.
                Thank you for helping so far
