    my second raspberry has just passed away
    Duet Web Control
    9
    102
    5.8k
      dc42 administrators @spllg
      @spllg said in my second raspberry has just passed away:
      @dc42 m115 returns 'FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.01-RC2 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-02-18b1'
      Thanks, I suggest you upgrade to 3.01-RC9 and see if the network issues persist.
      • spllgundefined
        spllg
        i have received a new rpi, installed it and the printer works using this rpi.
        q.: is it necessary to upgrade dwc on rpi?
        if yes: how to do it.
        currently running
        ii duetcontrolserver 1.2.4.0 armhf Control server application for Duet 3 series
        ii duetruntime 1.2.4.0 armhf .NET Core runtime libraries for the Duet software framework
        ii duetsd 1.0.5 all Virtual SD card directory for the Duet software framework
        ii duetsoftwareframework 1.2.4.0 armhf Meta package for the full Duet software framework
        ii duettools 1.2.4.0 armhf Optional tools (code examples)
        ii duetwebcontrol 2.0.7-1 all Official web interface for Duet electronics
        ii duetwebserver 1.2.3.1 armhf Optional web server for Duet 3 series
          You can either switch to the unstable package feed and upgrade to the latest DSF, DWC and RRF release candidates, or wait for the 3.01 stable release.
          spllgundefined 1 Reply Last reply Reply Quote 0
          • spllgundefined
            spllg @dc42
            @dc42 thanks for your answer - going to wait for 3.01 stable. (have you got any idea when it will be released?)
            please allow another question: i'm using cura and can upload gcode to the duet rpi.
            i found a cura plugin (Duet RepRapFirmware Integration) and installed it but it does not work. the plugin wants to access http://<rpi-hostname>/rr_connect?password=&time=2020-04-23.. but rr_connect does not exist on <rpi-hostname> - ERROR 404: Not Found.
            (how) can i enable http://<rpi-hostname>/rr_connect?
              The plugins for Cura and S3D and the upload support in PrusaSlicer are designed for the upload interface provided by Duets in standalone mode. DSF on the Pi supports a different upload interface. I think there is an experimental version of one of the plugins that supports both interfaces.
              spllgundefined 1 Reply Last reply Reply Quote 1
              • spllgundefined
                spllg @dc42
                @dc42 thanks for your reply. i cloned from https://github.com/Kriechi/Cura-DuetRRFPlugin/ . this seems to work fine.
                btw1: how is it possible to activate/use simulation mode in dsf?
                btw2: could you please tell me where to find a network printing plugin for s3d?
                dc42undefined spllgundefined 2 Replies Last reply Reply Quote 0
                  Simulation mode is available in the RRDF/DSF release candidate, available on the unstable package feed.
                  I don't think there is a S3D plugin that supports upload to Duet with attached SBC yet, but according to https://forum.duet3d.com/topic/15492/duetrff-cura-plugin-duet-3/25 there is now one for Cura.
                  spllgundefined A Former User? 2 Replies Last reply Reply Quote 1
                    A Former User
                    IIRC the last time I looked at S3D it was a script that runs wget curl?
                    if so we could "easily" replace with ssh/scp command to achieve the same with DSF
                    edit:
                    in Duet wifi S3D:
                    Yep, Got it
                    This works:
                    curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=0%3A%2Fgcodes%2F[output_filename].gcode"
                    curl "http://192.168.x.x/rr_gcode?gcode=M32 0%3A%2Fgcodes%2F[output_filename].gcode"
                    Many thanks !!
                    assuming windows and putty with public key authentication set up on the pi*
                    "%PROGRAMFILES%\PuTTY\pscp.exe" -i "%USERPROFILE%\.ssh\id_rsa.ppk" [output_filepath] pi@duet3:/opt/dsf/sd/gcode/[output_filename].gcode
                    and
                    curl -s -d 'M32 "[output_filename].gcode"' http://duet3/machine/code
                    ☝ @gtj0 said simplified things a little removing the need to run ssh, just scp. (As such I guess one could install an ftp server to remove the need to use scp and just rely on curl, but each to his own i guess)
                    "%PROGRAMFILES%\PuTTY\plink.exe" -no-antispoof -i "%USERPROFILE%\.ssh\id_rsa.ppk" pi@duet3 "echo M32 [output_filename].gcode | sudo /opt/dsf/bin/CodeConsole"
                    this also means you need to add a NOPASSW entry to run CodeConsole as root without a password. should probaly be wrapped as shells script to ensure only M32 and a valid file is passed as well.
                    I can't try those, but should get you started and we can help trouble shoot.
                    *) ideally the key should be dedicated to S3D uploads and limited to only allow the specific commands and scp. can probably get around to a more thorough guide next week
                    • spllgundefined
                      spllg @dc42
                      will wait for release 3.01
                      so i'm going to wait until one is available before buying s3d
                      i guess, that's the one which is working at my site.
                      • spllgundefined
                        spllg @A Former User
                        @bearer thanks - i did have not yet decided to buy s2d (which seems to be better than cura).
                        A Former User? A Former User? 2 Replies Last reply Reply Quote 0
                          A Former User @spllg
                          S3D even..... 🙂
                            @spllg if it comes down to the ability to print from S3D then don't worry about it - functionally the commands I listed will be the same as the curl commands used with the Duet2.
                            There could be some adjustment needed with " and stuff that I can't test with S3D (until I get my computer fixed), but I can take a gcode file and send it from the command line on windows and have it print using those commands now.
                            (Which slicer is better, or if S3D is worth is is a discussion best left for other imho)
                            • arhiundefined
                              arhi @spllg
                              prepare for a loooooong wait (and before you decide to purchase, check their forum and their user experiences first, just to not be surprised later like some)
                                A Former User
                                While I'm sure there are plenty of reasons to carefully consider purchsing S3D, getting prints to a(ny) Duet isn't one - I have used the curl commands with a Duet2 before, and getting it to work with Duet 3 can only be a matter of variable expansion and the correct use of quotes. Worst case scenario we'll have to make a wrapper script, but if it works for curl i don't see why that should be neccecary.
                                admittedly using ssh is more fiddly unless you want to take the "pull your pants down and hope for the best" approach when it comes to the security aspect of it.
                                (edit: yes, I'm saying I'll make it work, if it doesn't as posted already)
                                  A Former User @dc42
                                  @dc42 said in my second raspberry has just passed away:
                                  would i be correct in that its sufficient to check for spaces, qoutes (and newlines?) in a filename to avoid gcode injection if passing it to CodeConsole?
                                  (i.e. S3D calls wrapper with filename as parameter, wrapper sends M32 "filename" to CodeConsole to start print after checking for gcode injection)
                                  • gtj0undefined
                                    gtj0
                                    After copying the file to the SBC, you can call curl to start it printing...
                                    curl -s -d 'M32 "[output_filename].gcode"' http://duetsbc/machine/code
                                      A Former User @gtj0
                                      @gtj0 said in my second raspberry has just passed away:
                                      That simplifies it a bit, and while I suppose its still possible to mess about with g-code in the file name, its not an additional vector so not my concern.
                                      I'll update my earlier comment to reflect your input 👍
                                      I suppose a HTTP request toPUT /machine/file/{filename}could replace scp as well. Will have a poke later and update the S3D thread.
                                      • spllgundefined
                                        spllg
                                        going to stay with cura (4.6)
                                        • spllgundefined
                                          spllg @spllg
                                          @spllg
                                          spllg 24 Apr 2020, 08:19
                                          it seems to have the ability to crash cura - staying with saving gcode to file and downloading this file to rpi.
                                            please consider filing a bug report to the github page for the plugin; it might just help get it fixed by the developers
