    Duet3/pi DCS is unavailable after wiring 24V
    duet 3 rasberry pi
    8
    166
    12.1k
    • Danalundefined
      Danal
      @fractalengineer said:
      pi@duet3:~ $ apt list 2>/dev/null | grep duet
      duetsoftwareframework/now 1.3.2 armhf [installed,local]
      Flashed the board to 3.01 RC7 using Bossa
      I believe those two won't talk to each other. I would do a standard
      sudo apt update
      sudo apt upgrade
      And let the system move itself to DSF 2.1.0. That should fix things... but... it may not be able to auto-flash the board.
      • If, after the update/upgrade, your apt-list shows duetsoftwareframework/now 2.1.0 armhf [installed,local], and things are still not working, then bossa the board with the file /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
      • If, after the update/upgrade, your apt list shows anything else for DSF itself, ask again here.
      You are very close. We'll get you going.
      fractalengineerundefined 1 Reply Last reply Reply Quote 0
      • fractalengineerundefined
        fractalengineer @Danal
        @Danal Thank you;
        So I just updated the packages and I saw this message while it was running: (line 4)
        Setting up duetwebserver (2.1.0) ...
        Setting up git (1:2.20.1-2+deb10u3) ...
        Setting up reprapfirmware (2.1.0-1) ...
        [fatal] Duet is not available
        Setting up rpi-eeprom (5.8-1) ...
        Setting up duetsoftwareframework (2.1.0) ...
        Processing triggers for mime-support (3.62) ...
        Processing triggers for libc-bin (2.28-10+rpi1) ...
        Processing triggers for man-db (2.8.5-2) ...
        Processing triggers for desktop-file-utils (0.23-4) ...
        Processing triggers for initramfs-tools (0.133+deb10u1) ...
        duetcontrolserver/unstable,now 2.1.0 armhf [installed,automatic]
        duetruntime/unstable,now 2.1.0 armhf [installed,automatic]
        duetsd/unstable,now 1.0.6 all [installed,automatic]
        duetsoftwareframework/unstable,now 2.1.0 armhf [installed]
        duettools/unstable,now 2.1.0 armhf [installed,automatic]
        duetwebcontrol/unstable,now 2.1.4 all [installed,automatic]
        duetwebserver/unstable,now 2.1.0 armhf [installed,automatic]
        Still not working.
        I can't find this location /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin But the board is already flashed in 3.01 RC9.
        M115
        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-21b1
        I'll borrow my friend's pi 4 in a couple hours; keep you posted
        Railcore II ZL
          fractalengineer
          Man I don't get it anymore...
          On the other Pi the wifi now doesn't work; I triple checked the wpa supplicant and it still won't show on network
          Meanwhile, even through the HDMI it still shows DCS not started
          Halp
          Railcore II ZL
            A Former User @fractalengineer
            @fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
            i'm sure we can figure that out, maybe do a new thread after having tested the new pi
            • Danalundefined
              Danal
              Progress! Clearly upgraded to 2.1.0
              Line 4 I sort of expected. That is why we may need to bossa the board one more time. After we get everything in sync, future upgrades will take care of this and keep things in sync.
              Not finding /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin is a little concerning. Can you please:
              ls /opt/dsf
              ls /opt/dsf/sd
              ls /opt/dsf/sd/sys
              And post the results here?
              • Danalundefined
                Danal
                Chris built your image, so the following SHOULD be OK, but just for triple-check:
                Run
                sudo raspi-config
                Navigate to 5 Interface options
                Go to P4 SPI
                Confirm to enable the SPI interface
                Once done, run ls /dev/spidev*and verify that /dev/spidev0.0 exists.
                Then run this command:
                echo "options spidev bufsiz=8192" | sudo tee /etc/modprobe.d/spidev.conf
                And reboot
                  A Former User @Danal
                  @Danal said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
                  Run
                  sudo raspi-config
                  Go to P4 SPI
                  And reboot
                  no need. DCS specifically says
                  [error] Failed to connect to Duet
                     System.IO.IOException: Error 2. Can not open SPI device file '/dev/spidev0.0'.
                  if thats the case; the shown error Duet not available as such confirms the SPI device is accessible.
                  • Danalundefined
                    Danal
                    @bearer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
                    Can an error 2 on open happen because the device does not exist?
                    A Former User? chrishammundefined 2 Replies Last reply Reply Quote 0
                      that what happened on my Pi. (same with lacking permission).
                      OP gets [error] Duet is not available which implies SPI is OK. (maybe there is room for making the two clearer as the first has nothing to do with the Duet as such, but still)
                      • Danalundefined
                        Danal
                        I think I misread your post a couple up. You were pointing out the error that occurs if the device is missing. I read it as "op is getting this error". Now I see what you were saying vs what is happening on OP's Pi, and agree, the device is available. Sorry for the rabbit hole...
                        Should OP still echo "options spidev bufsiz=8192" | sudo tee /etc/modprobe.d/spidev.conf
                        I don't believe we have proof either way that is correct.
                          you get a warning if that is missing. so no.
                          • Danalundefined
                            Danal
                            Got it. Thanks!
                            • Danalundefined
                              Danal
                              @fractalengineer Line 4 I sort of expected. That is why we may need to bossa the board one more time. Maybe.
                              Anyway, after we get everything in sync, future upgrades will take care of this and keep things in sync.
                              ls -al /opt/dsf
                              ls -al /opt/dsf/sd
                              ls -al /opt/dsf/sd/sys
                                @Danal Will do in the next hour
                                I didn't know you meant on the pi command; I can probably get there through SSH but I woudn't know what to do from there; would you mind clarifying what you meant?
                                Likewise, I did double, triple check the SPI was activated in the settings, even in @chrishamm 's image; it's on
                                Railcore II ZL
                                • Danalundefined
                                  Danal
                                  From the things you posted before, it looks like you've been issuing commands on the Pi... in the same way you did those in the past, just copy paste the "ls" commands.
                                    A Former User
                                    Ultimately it doesn't matter; board is updated to RC9 and installing the latest unstable DSF should work as hes tried time and time again.
                                    (Not having the correct firmware would only be a problem if the latest available apt packages aren't compatible)
                                    • Danalundefined
                                      Danal @A Former User
                                      Agreed... but... what should he do next?
                                        try the other pi he'll be borrowing any time now (and hope if the orignal Pi was damaged with the original Duet, the borrowed Pi didn't suffer the same fate).
                                        following that I guess either call an exorcist or attempt to try another SPI slave (maybe there is a bit banged SPI slave for a Pi out there?)
                                          fractalengineer
                                          Ok guys I'm just absolutely confused; the RPi 4 that worked last time on the standard image SD card won't connect to Wifi with chris's image no matter if I redo the wpa supplicant file.
                                          It is not a Pi4 hardware issue because it works just fine with my other SD card flashed with Octopi
                                          I'm rebuilding an image from scratch following this guide again; don't know what else to do at this point.
                                          Duetpi lite this time; as if it changed anything
                                          I'll report back once I get the new image setup on the pi4 with wifi working and everything up do date
                                          Thanks for the help
                                          Railcore II ZL
                                            A Former User
                                            Send me a message if you'd want a second pair of eyes on it. If you can connect the Pi to wired Ethernet and provide remote access (e.g. ngrok) I can take a stab at it.
                                            prime suspect is missing country code in the config or somehow strange whitespace in the config preventing it from being parsed.
                                            this was one of the more detailed guides I could find to share https://wiki.archlinux.org/index.php/wpa_supplicant
                                            fractalengineerundefined 1 Reply Last reply Reply Quote 1
