Duet3/pi DCS is unavailable after wiring 24V
@Danal Thank you;
So I just updated the packages and I saw this message while it was running: (line 4)
Setting up duetwebserver (2.1.0) ... Setting up git (1:2.20.1-2+deb10u3) ... Setting up reprapfirmware (2.1.0-1) ... [fatal] Duet is not available Setting up rpi-eeprom (5.8-1) ... Setting up duetsoftwareframework (2.1.0) ... Processing triggers for mime-support (3.62) ... Processing triggers for libc-bin (2.28-10+rpi1) ... Processing triggers for man-db (2.8.5-2) ... Processing triggers for desktop-file-utils (0.23-4) ... Processing triggers for initramfs-tools (0.133+deb10u1) ... pi@duet3:~ $ apt list 2>/dev/null | grep duet duetcontrolserver/unstable,now 2.1.0 armhf [installed,automatic] duetruntime/unstable,now 2.1.0 armhf [installed,automatic] duetsd/unstable,now 1.0.6 all [installed,automatic] duetsoftwareframework/unstable,now 2.1.0 armhf [installed] duettools/unstable,now 2.1.0 armhf [installed,automatic] duetwebcontrol/unstable,now 2.1.4 all [installed,automatic] duetwebserver/unstable,now 2.1.0 armhf [installed,automatic] Still not working.
I can't find this location
/opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
But the board is already flashed in 3.01 RC9.M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-21b1 I'll borrow my friend's pi 4 in a couple hours; keep you posted
Man I don't get it anymore...
On the other Pi the wifi now doesn't work; I triple checked the wpa supplicant and it still won't show on network
Meanwhile, even through the HDMI it still shows DCS not started
Halp
@fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
i'm sure we can figure that out, maybe do a new thread after having tested the new pi
Progress! Clearly upgraded to 2.1.0
Line 4 I sort of expected. That is why we may need to bossa the board one more time. After we get everything in sync, future upgrades will take care of this and keep things in sync.
Not finding /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin is a little concerning. Can you please:
ls /opt/dsf ls /opt/dsf/sd ls /opt/dsf/sd/sys And post the results here?
Chris built your image, so the following SHOULD be OK, but just for triple-check:
Run sudo raspi-config Navigate to 5 Interface options Go to P4 SPI Confirm to enable the SPI interface Once done, run
ls /dev/spidev*
and verify that /dev/spidev0.0 exists.Then run this command:
echo "options spidev bufsiz=8192" | sudo tee /etc/modprobe.d/spidev.conf And reboot
@Danal said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
ls /dev/spidev*
no need. DCS specifically says
[error] Failed to connect to Duet System.IO.IOException: Error 2. Can not open SPI device file '/dev/spidev0.0'.
if thats the case; the shown error Duet not available as such confirms the SPI device is accessible.
@bearer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
System.IO.IOException: Error 2. Can not open SPI device file '/dev/spidev0.0'.Can an error 2 on open happen because the device does not exist?
that what happened on my Pi. (same with lacking permission).
OP gets
[error] Duet is not available
which implies SPI is OK. (maybe there is room for making the two clearer as the first has nothing to do with the Duet as such, but still) -
I think I misread your post a couple up. You were pointing out the error that occurs if the device is missing. I read it as "op is getting this error". Now I see what you were saying vs what is happening on OP's Pi, and agree, the device is available. Sorry for the rabbit hole...
Should OP still
I don't believe we have proof either way that is correct.
Should OP still echo "options spidev bufsiz=8192" | sudo tee /etc/modprobe.d/spidev.conf
you get a warning if that is missing. so no.
Got it. Thanks!
@fractalengineer Line 4 I sort of expected. That is why we may need to bossa the board one more time. Maybe.
Anyway, after we get everything in sync, future upgrades will take care of this and keep things in sync.
ls -al /opt/dsf ls -al /opt/dsf/sd ls -al /opt/dsf/sd/sys And post the results here?
@Danal Will do in the next hour
I didn't know you meant on the pi command; I can probably get there through SSH but I woudn't know what to do from there; would you mind clarifying what you meant?
Likewise, I did double, triple check the SPI was activated in the settings, even in @chrishamm 's image; it's on
From the things you posted before, it looks like you've been issuing commands on the Pi... in the same way you did those in the past, just copy paste the "ls" commands.
Ultimately it doesn't matter; board is updated to RC9 and installing the latest unstable DSF should work as hes tried time and time again.
(Not having the correct firmware would only be a problem if the latest available apt packages aren't compatible)
Agreed... but... what should he do next?
try the other pi he'll be borrowing any time now (and hope if the orignal Pi was damaged with the original Duet, the borrowed Pi didn't suffer the same fate).
following that I guess either call an exorcist or attempt to try another SPI slave (maybe there is a bit banged SPI slave for a Pi out there?)
Ok guys I'm just absolutely confused; the RPi 4 that worked last time on the standard image SD card won't connect to Wifi with chris's image no matter if I redo the wpa supplicant file.
It is not a Pi4 hardware issue because it works just fine with my other SD card flashed with Octopi
I'm rebuilding an image from scratch following this guide again; don't know what else to do at this point.
Duetpi lite this time; as if it changed anything
I'll report back once I get the new image setup on the pi4 with wifi working and everything up do date
Thanks for the help
Send me a message if you'd want a second pair of eyes on it. If you can connect the Pi to wired Ethernet and provide remote access (e.g. ngrok) I can take a stab at it.
prime suspect is missing country code in the config or somehow strange whitespace in the config preventing it from being parsed.
this was one of the more detailed guides I could find to share https://wiki.archlinux.org/index.php/wpa_supplicant
@bearer thanks;
Well it's all fixed now with the new image...the wifi connection it is...Still unable to connect to DCS
On a separate pi...
On a new board...
Maybe we can try that pin by pin connection to double check the issue wasn't the ribbon?
I can go buy jumpers tomorrow; how many we need?
