    Laser mode - last line laserhead moves without laser power
    Laser Cutters
    • radiomodellundefined
      radiomodell
      Hi all,
      I finished setup of my machine with a laserhead. During tests I suffered a strange behavior. Last line in a sequence the laserhead is moving without laser power.
      Adding an additional command line, again the last line is printed without power. All lines before are printed. I add some picures and the corresponding G-Code.
      Left line of rectangle is missing. The G-Code is following: Laser-1-rectangle+circle.gcode
      Left line of rctangle is printed but diagonal is missing. The G-Code is: Laser-2-rectangle+diagonal+circle .gcode
      Now diagonal is printed but second diagonal is missing. The G-Code: Laser-3-rectangle+diagonal+2nd-diagonal+circle.gcode
      Here laserpower was too high. Again last command line is missing. The G-Code: Laser-4-rectangle+diagonal+2nd-diagonal+2rd+line+circle.gcode
      Circle in separate command block seems not to be effected.
      My printer is Cartesian type with Duet ethernet 2 with firmware 3.01-RC8 .
      Did anyone else figure out this behavior?
        Thanks for reporting this and providing the GCode. I've added it to my list of issues to investigate.
          This is now fixed. I've put internal builds of RRF including the fix at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. Use with caution!
            radiomodell
            First short test results look well. All segments are "printed" by the laser.
            There were no other issues coming up during my test. It works like a charm.
            Did not test CNC- and FFF-mode. Hope that I can do that tomorrow.
            Thanks a lot for your fast support!
              radiomodell
              CNC-mode also worked fine.
                Thanks! This fix is in the 3.01-RC10 release.
