    Stupid question.
    • Stevoundefined
      Stevo
      Is it possible to hook up to the duet2 via wifi using simplify 3d software so I can use the live preview tracking feature of the software?
      • gtj0undefined
        gtj0 @Stevo
        @Stevo said in Stupid question.:
        I've only been able to get it to work via USB.
        Stevoundefined 1 Reply Last reply Reply Quote 0
        • Stevoundefined
          Stevo @gtj0
          @gtj0 said in Stupid question.:
          Thanks for the reply I had to ask more out of curiosity
            A Former User
            not familiar with how s3d works, but enabling telnet on the duet and installing a virutal com port that is linked to the duet on the telnet port might work similarly as if it was connected via usb
            • gtj0undefined
              gtj0 @A Former User
              @bearer S3D is very picky about its ports. On Linux, it won't accept a "virtual" serial device like you'd create with socat. I can't try Windows but it might be worth a shot.
                A Former User @gtj0
                just occured to me using any esp8266-ish (board be it nodemcu/wemos d1 mini etc) you could probably combine Duet telnet with esplink firmware on the esp8266 to get you a hardware serial port that is networked to the Duet.
                (but printing from the duets SD card is one of the bigger features)
                ((and with RC11 you could also get raw g-code from the PanelDue port to put into another esplink to avoid telnet))
