    RRF 3.01-RC10, DWC 2.1.5 and DSF 2.1.1 released
    Beta Firmware
    15
    50
    2.6k
    • Silroccoundefined
      Silrocco @dc42
      I'm all set now, I directly installed the "DuetMaestroAP.bin file onto the SD Card and then uploaded the update.
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.01-RC10 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-04-25b3
      Thanks for all the support here.
      • Danalundefined
        Danal
        Install went fine, very smooth, including firmware load of B0. It also appears to operate, although I have not yet done a full print.
        WOW the update of B1, etc, messages got MUCH CLEANER. I realize that 3HC boards are still on RC7... but I just thought I'd check, and the "Please wait, updating" style messages are GREAT.
        It seems that DWC "Emergency Stop" hangs and never comes back. If I can derive info, I will start a linked thread.
        • arhiundefined
          arhi
          first short print (2 hours) done, everything working awesome 😄
          • Garfieldundefined
            Garfield
            A Noctua Fan that I use to cool the CPU / drivers etc has now become an 'ON/OFF' fan, it used to work fine between the 40 / 45 Deg limits set.
            It now is either at 100% or nothing, it comes on at the low end i.e. 40, this used to work just fine so I won't accept that this is a gcode issue unless M950 has changed but not yet been documented.
            Up until the update this morning the fan has been fine (although I have skipped a couple of RC versions).
            I am now getting
            'inconsistent Z' when trying to home Z.
            Cancel print results in a 'attempt to extrude with no tool selected' error.
            NOTHING has been changed mechanically - was all tickety boo before the update.
            Has anyone developed a 'Test plan' that can be executed against new RC's - many people can execute on different hardware and report result - just a thought.
            • ChrisPundefined
              ChrisP
              Problem with DCS crashing ungracefully (usually on startup) - DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
              • Danalundefined
                Danal
                Bug report: G32 messages work from console, not from DWC.
                https://forum.duet3d.com/topic/15894/g32-messages-not-returning-to-console-rrf-3-01-rc10
                • Garfieldundefined
                  Garfield
                  very basic Q to ask - shouldn't the Duet3 boot from the same SD card used by the Pi ?
                  Because mine doesn't, doesn't make any attempt to get an IP address when hardwired.
                  gtj0undefined A Former User? 2 Replies Last reply Reply Quote 0
                  • gtj0undefined
                    gtj0 @Garfield
                    @Garfield said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
                    Other than the M55x network commands, it should work. Make sure they're not commented out when in standalone mode.
                    • Garfieldundefined
                      Garfield
                      Don't have any M55x commands - have never had any ...
                        Phaedrux Moderator @Garfield
                        @Garfield I think you'd need at least M552 S1 to enable networking. It should get a DHCP address. You should then be able to reach the printer via the name set in M550 P. Http://printername
                        • Garfieldundefined
                          Garfield
                          Gone from bad to worse ... can't even boot the DWC in the Pi now .... Pi boots OK ... sytemctl status reports DWC is running but can't access it.
                          • gtj0undefined
                            gtj0 @Garfield
                            @Garfield I thought you were trying to go standalone to get around the DCS issue, no?
                              A Former User @Garfield
                              it won't unless you copy the config from /opt/dsf/sd/sys to /boot/sys before removing it from the Pi. (moving the config to /boot/sys/config.g and symlinking it back to /opt/dsf/sd/sys/config.g would be an interesting exercise though (and adding M552 S1))
                              i.e. duet can only read the first fat32 partition, raspbian uses it for /boot and the duet is unable to read the config file the pi normally uses.
                              • Garfieldundefined
                                Garfield
                                I was trying to boot stand alone - couldn't - put it into the Pi and although DWC reports running it can't be accessed, I can access SSH.
                                Never been a Linux fan ..... never will be until it ceases to a 19th century OS accessible only to those prepared to waste days on a basic config (I am not one of those - I have a life)
                                • gtj0undefined
                                  gtj0 @A Former User
                                  @bearer said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
                                  Can't symlink in that case but yeah, I keep forgetting about people running their SBC from an SD card since I run from SSD. When I need to go standalone, I just copy the /opt/dsf/sd/ directory contents to a freshly formatted SD card.
                                    A Former User @gtj0
                                    @gtj0 said in RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1 released:
                                    not if you move the config to the /boot parition and link from the ext4 parition?
                                    (i cant test in a duet3, but think it should work)
                                    pi@rpix:/opt/dsf/sd/sys $ ls
                                    config.g
                                    pi@rpix:/opt/dsf/sd/sys $ sudo mkdir /boot/sys
                                    pi@rpix:/opt/dsf/sd/sys $ echo M552 S1 | tee cat - >>config.g
                                    pi@rpix:/opt/dsf/sd/sys $ sudo mv config.g /boot/sys
                                    mv: failed to preserve ownership for '/boot/sys/config.g': Operation not permitted
                                    pi@rpix:/opt/dsf/sd/sys $ ln -s /boot/sys/config.g
                                    pi@rpix:/opt/dsf/sd/sys $ ls -l
                                    total 1460
                                    lrwxrwxrwx 1 pi   pi       14 Apr 26 22:44 config.g -> /boot/sys/config.g
                                    pi@rpix:/opt/dsf/sd/sys $ echo M552 S1 | sudo tee -a config.g
                                    pi@rpix:/opt/dsf/sd/sys $ cat config.g
                                    ; Duet 3 Configuration File
                                    ; It is recommended to replace the contents of this file with a preset from https://configtool.reprapfirmware.org
                                    M550 P"Duet 3" ; set machine label
                                    M552 S1
                                    (although i suspect doing the whole sys, gcode, macro folders might be more convenient.. and throwing in the stand alone dwc not as a link)
                                    • gtj0undefined
                                      gtj0 @A Former User
                                      @bearer Oh, that direction. 🙂 Yeah that works.
                                      • Garfieldundefined
                                        Garfield
                                        Well my system is now totally borked - can't access DWC, can't access SSH, doesn't get an IP.
                                        So I re-imaged the SD from the links in the 'getting started with duet 3' Dozuki and .....
                                        it still doesn't work - starting to get a tad grumpy.
                                        I'm only thankful that I have a config backup ....
                                          understandable, does the ribbon cable attached make a difference? (or detached would be more to the point)
                                          • Garfieldundefined
                                            Garfield
                                            None whatsoever ... Pi won't respond, definitely does something - lots of green LED flickering which says it is healthy, can't connect it via hdmi because some jokers thought it would be a laugh to add yet another poxy standard for which I have no cable - got 6 or 7 Pi 3's - ask me how many I can find ....
                                            Trying to do a boot eeprom rebuild but I don't have a microSD small enough but I don't think it is that.
