    DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
    Beta Firmware
    12
    132
    7.3k
    • Garfieldundefined
      Garfield
      pr 27 11:15:05 duet3 DuetControlServer[3136]: [info] Application has shut down
      Apr 27 11:15:05 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
      Apr 27 11:15:10 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
      Apr 27 11:15:10 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 57.
      Apr 27 11:15:10 duet3 systemd[1]: Stopped Duet Control Server.
      Apr 27 11:15:10 duet3 systemd[1]: Started Duet Control Server.
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: Duet Control Server v2.1.1
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: Written by Christian Hammacher for Duet3D
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: Licensed under the terms of the GNU Public License Version 3
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Settings loaded
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Environment initialized
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Connection to Duet established
      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] IPC socket created at /var/run/dsf/dcs.sock
      Apr 27 11:15:12 duet3 DuetControlServer[3175]: [fatal] Abnormal program termination
      Apr 27 11:15:12 duet3 DuetControlServer[3175]: [fatal] Update task faulted
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    System.ArgumentException: Property set method not found.
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.PropertyInfo.SetValue(Object obj, Object value)
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 237
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMon
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 209
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Bas
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 149
      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 182
      Apr 27 11:15:12 duet3 DuetControlServer[3175]: [info] Application has shut down
      Apr 27 11:15:12 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
      SSH connections are stable though ...
        A Former User @Garfield
        @Garfield it needs to evolve a little, but it has a sibling that will identify and flash any duet 2 wifi/ethernet/maestro or duet 3 with the correct firmware in any state as long as usb is working. that might be proposed for the doczuki/wiki when polished.
        anyways, glad you found it helpful in the end, the goal is in the end to take the guesswork out of the flashing when necessary.
        • Garfieldundefined
          Garfield
          spoke too soon - ssh eventually dies .... so we are back on topic - same issue as we started with ...
          ChrisPundefined 1 Reply Last reply Reply Quote 0
          • ChrisPundefined
            ChrisP @Garfield
            @Garfield said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
            Excellent... ish 😕
            Is the log you posted above what you see when DCS crashes? I still haven't managed to get anything interesting in the logs.
            • Garfieldundefined
              Garfield
              Yup - thats the crash log ...
              • Danalundefined
                Danal
                I'm the one that leans toward bossa from the Pi. However, I'm just an end-user that's trying to dig another end user out of a hole. If someone else, prefers windows, great!
                I prefer the Pi for two reasons:
                1. It does avoid ground loops, to a somewhat greater extent than a separate computer.
                2. Windows bossa works quite a bit of the time... and other times, windows gets really weird about USB ports.
                Again, I'm just making suggestions, if someone prefers one tool over another, fantastic, use that!
                • gtj0undefined
                  gtj0
                  @Garfield @ChrisP Have you tried my suggestion above to remove the two CPUScheduling lines from /lib/systemd/system/duetcontrolserver.service and rebooting?
                  • Danalundefined
                    Danal
                    Data point: I have not changed the CPU scheduling and I am now about 14 hours into a print, with no issues.
                    Running DuetLapse on the same Pi. (Which I was not doing the other day).
                    I don't know what changed, if anything, from the point where I couldn't get it to run for 15 minutes at a time.
                    gtj0undefined Danalundefined 2 Replies Last reply Reply Quote 0
                    • Garfieldundefined
                      Garfield
                      I've not tried the scheduling - can't get DCS to start and stay running, first time it came up and was fine - until I threw my .g files at it and then BOOM ....
                      I need to get the whole thing back to RC6 and stable but right now it is all turned off (day job - that and run out of patience for now).
                      Could really do with that 'version compatibility' matrix ....
                      gtj0undefined A Former User? Danalundefined 4 Replies Last reply Reply Quote 0
                      • gtj0undefined
                        gtj0 @Danal
                        @Danal When your print is done it's be helpful if you could test without DuetLapse and see if you can reproduce the issue, then try removing the CPUScheduling lines.
                        • gtj0undefined
                          gtj0 @Garfield
                          @Garfield Understood. If you do get a chance, try removing those 2 lines.
                            back to RC6
                            @bearer said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                            RRF3.01-RC10     duetsoftwareframework 2.1.1      reprapfirmware 2.1.1-1
                            RRF3.01-RC9      duetsoftwareframework 2.1.0      reprapfirmware 2.1.0-1
                            RRF3.01-RC8      duetsoftwareframework 2.0.0      reprapfirmware 2.0.0-1
                            RRF3.01-RC7      duetsoftwareframework 1.3.2      reprapfirmware 1.3.2-1
                            RRF3.01-RC6      duetsoftwareframework 1.3.1      reprapfirmware 1.3.1-1
                            RRF3.01-RC6      duetsoftwareframework 1.3.0      reprapfirmware 1.3.0-1
                            RRF3.01-RC4      duetsoftwareframework 1.2.5.0    reprapfirmware 1.2.5.0-1
                            RRF3.0           duetsoftwareframework 1.2.4.0    reprapfirmware 1.2.4.0-1
                            RRF3.0           duetsoftwareframework 1.2.3.1    reprapfirmware 1.2.3.1-1
                            RRF3.0           duetsoftwareframework 1.2.3.0    reprapfirmware 1.2.3.0-1
                            RRF3.0           duetsoftwareframework 1.2.2.1    reprapfirmware 1.2.2.1-1
                            RRF3.0RC2+1      duetsoftwareframework 1.2.2.0    reprapfirmware 1.2.2.0-1
                            RRF3.0RC1        duetsoftwareframework 1.2.1.0    reprapfirmware 1.2.1.0-1
                            RRF3.0RC1        duetsoftwareframework 1.2.0.0    reprapfirmware 1.2.0.0-1
                            RRF3.0beta11     duetsoftwareframework 1.1.0.5    reprapfirmware 1.1.0.5-1
                            RRF3.0beta11     duetsoftwareframework 1.1.0.4    reprapfirmware 1.1.0.4-1
                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.3    reprapfirmware 1.1.0.3-1
                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.2    reprapfirmware 1.1.0.2-1
                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.1    reprapfirmware 1.1.0.1-1
                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.0    reprapfirmware 1.1.0.0-1
                            RRF3.0beta10+1   duetsoftwareframework 1.0.4.1    reprapfirmware 1.0.4.1-1
                            depcheck()
                              local NODE=$1
                              local VER=$2
                              local pattern="\ ([a-z]*)\ \([0-9]+\ ([0-9\.]+-?[0-9]{0,2})\)"
                              local IFS=$'\n'
                              s=$(apt-cache showpkg $NODE |  grep "^$VER - ." )
                              for package in $(echo $s | grep -Eo  $pattern)
                              do
                                [[ $package =~ $pattern ]]
                                [ "${BASH_REMATCH[1]}" == "${BASH_REMATCH[2]}" ] || echo -en "  ${BASH_REMATCH[1]}=${BASH_REMATCH[2]} $EOL"
                                [ "${BASH_REMATCH[1]}" == "duetcontrolserver" ] && depcheck ${BASH_REMATCH[1]} ${BASH_REMATCH[2]}
                              done
                            [ $# -gt 0 ] && {
                            V=$1
                            PARENT=duetsoftwareframework
                            [ $# -gt 1 ] && PARENT=$2
                            EOL=""
                            [ -t 1 ] && EOL="\\ \n"
                            echo  -en "sudo apt install $EOL"
                            depcheck $PARENT $V
                            [ -t 1 ] && EOL="\n"
                            echo  -en "  $PARENT=$V $EOL"
                            } ||  echo $0 version ;
                            save as dsfdep.sh and run like bash dsfdep.sh 1.3.1 to restore to 3.01-RC6
                            copy and paste the suggest command and hope for the best (or put in backticks if braver than most)
                            pi@raspberrypi:~ $ bash dsfdep.sh 1.3.1
                            sudo apt install \
                              duetcontrolserver=1.3.1 \
                              duetruntime=1.3.1 \
                              duetsd=1.0.6 \
                              duettools=1.3.1 \
                              duetwebserver=1.3.1 \
                              duetwebcontrol=2.1.1 \
                              reprapfirmware=1.3.1-1 \
                              duetsoftwareframework=1.3.1
                            • Danalundefined
                              Danal @gtj0
                              @gtj0 said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                              Will do.
                              May do a different print, this one is running MUCH longer than I anticipated. It is a toolchanger multi-material, and "estimators" do not (yet) account for the time spent changing tools. There are 1045 changes in this print.
                              • Danalundefined
                                Danal @Garfield
                                I'm working on a script that generates one. No promises as to when... lots of learning and research on my part.
                                In fact, if anyone else is working on one, I'll stop.
                                • gloomyandyundefined
                                  gloomyandy
                                  Just as another data point. After my initial crashes I went on to print (for a couple of hours or so) with no problems and things seemed pretty stable. I wonder if forcing a reload of DWC had anything to do with the problem?
                                    jay_s_uk @gtj0
                                    @Danal said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                                    I believe he's saying, "start a job, and then close DWC".
                                    Yes, I tried that. SSH only, no VNC, no DWC. Still locked within a few minutes.
                                    Yeah that was it. I wanted to make sure it wasn't DWC related. I've been running RC10 + 2.1.1 and printing fine but I don't use the DWC.
                                    Something to try... The systemd service file for the DCS was changed to set
                                    CPUSchedulingPolicy=fifo
                                    CPUSchedulingPriority=20
                                    which may be contributing to the problem.
                                    Edit /lib/systemd/system/duetcontrolserver.service and remove those 2 lines, then reboot and see if that helps.
                                    @gtj0
                                    I've checked the above folder and I don't have a duetcontrolserver.service file to edit
                                    • gtj0undefined
                                      gtj0 @jay_s_uk
                                      @jay_s_uk said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                                      @gtj0
                                      See if it's in /usr/lib/systemd/system.
                                        jay_s_uk
                                        @gtj0
                                        Thats where they are. I have commented them out and will report back
                                          jay_s_uk
                                          @gtj0
                                          I have managed a small print without any failures.
                                          So far so good.
                                            A Former User @Danal
                                            gave up on recursion seems all reprapfirmware from 1.0.4.1-1 to 1.2.5.0-1 has a dependency to duetcontrolserver 1.0.3.4 which doesn't exist (which probably means or greater but )
