    Bed heater always on
    490
    • Skaterundefined
      Skater
      Just hooked up a new board and the heatbed is always on. I have started the board without the SD card to rule out a config problem
      Here is all the info I hope you need.
      RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1
      ELECTRONICS: Duet WiFi 1.02 or later
      FIRMWARE_DATE: 2020-02-09b1
      M550 P"FT-5" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M350 X32 Y32 Z32 E32 I1 ; configure microstepping without interpolation
      M92 X161.61 Y160.00 Z797.26 E832.28 ; set steps per mm
      M906 X1100 Y1200 Z1200 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z400 S0 ; set axis maxima
      M307 H7 A-1 C-1 D-1;
      M558 P9 F100 H5 R0.2 T6000 A5 B1;
      G31 P25 X20 Y0 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X25:285 Y15:285 S20 ; Define mesh grid
      M305 P0 T1000000 ; set thermistor + ADC parameters for heater 0
      M305 P1 T500000 B4723 C1.196220e-7 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280 ;set temperature limit for heater 1 to 280C
      M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      Thanks in advance
        @Skater, I think your board has a hardware fault. Can you see any damage to the small square chip about 2cm left of the bed heater LED?
        • Skaterundefined
          Skater
          I have looked over the board and can find no damage what so ever. Since I blew out a mosfet on a previos board I know what it looks like.
          Thanks
          • elmoretundefined
            elmoret
            Hi Skater, was anything connected to this board aside from the bed heater prior to this fault?
            Generally this is caused by a short circuit in one of the things connected to the Duet causing a failure on the Duet itself.
            • Skaterundefined
              Skater
              Motors, endstops, Hotend and a BLTouch
              • Skaterundefined
                Skater
                When I remove the jumper from the INT 5v EN the heater will turn off. Does that help at all in the diagnostics? I would like to get this issue taken care of
                  A Former User
                  Its really hard to tell from the blurry photo, but looks like the E1 heater is also on?
                  Could suggest the driver is damaged, but hard to say without a better picture tbh.
                  • Skaterundefined
                    Skater
                    Thank You
                    That is correct. The E1 heater is also lit
                      A Former User
                      So how about a focused high res picture if there is anything else relevant we might spot?
                      • Skaterundefined
                        Skater
                        Here is the best I can get
                          A Former User
                          given both the bed and E1 are stuck on, they trun off when you remove the 5v en jumper and removing the sd card makes no difference i would suspect the problem lies here even though there no clear visual signs of damage.
                          not to say its not possible I'm wrong or there is more damage; however determining what is wrong only help determining the likelihood of what caused the problem, which will affect how to handle it but thats up to the duet3d people for now.
                            Hello, sorry to see you've had a failure.
                            Please contact your vendor and initiate a warranty replacement. You can refer them to this thread.
                            • Skaterundefined
                              Skater
                              Thank you for all your help
