    No Response from Duet Maestro out of the box
    Firmware installation
    259
    • IGENundefined
      IGEN
      Straight out of the box my Duet Maestro has no lights on the board after plugging it in with a micro USB cable. Tried tons of different cables and multiple computers. Any suggestions?
        Not a single light at all?
        Have you tried connecting it to VIN yet?
        Can you post some close up well lit photos of the board front and back to see if there are any damaged chips?
        • elmoretundefined
          elmoret
          Also, where was it purchased?
          • IGENundefined
            IGEN
            Not a single light.
            I've attached two photos.
            It was bought through Duet3D's online store.
            https://drive.google.com/open?id=11shmve_bgmN37uZpTE7q5YIGxxl30W9j
            https://drive.google.com/open?id=12NVNDDu8kmJVQnLuBcpMF6KS5ky0Zrp3
              That crimp pin wasn't on the back of the board like that when you were testing it was it?
                A Former User
                presumably the JST KK terminal on the rear of the PanelDue_SD connector is just a prop, and not stuck shorting something out?
                • IGENundefined
                  IGEN
                  I am blind as a bat. No idea how I didn't see that. I plugged it in now and the lights turn on as they should.
                  Could that have caused irreparable damage?
                    A Former User @IGEN
                    @IGEN said in No Response from Duet Maestro out of the box:
                    Nothing is irrepairable although most things on the board does take some effort to repair.
                    Its hard to say anything about the long term viability after a short, but given the supply was an USB port odds are it dealt with the surge, and if it didn't it would "just" be the 3.3v regulator to repair down the line which isn't too bad.
