Unsolved How to cancel a macro
I want to run a long macro to test my toolchanger before I start printing with it.
I was planning to just have a ton of T0's and T1's.Is there a way to cancel a macro if I run into an issue without using the emergency stop button?
You could have the macro test an endstop switch during the loop.
This post is deleted! -
So something along the lines of carrying out the macro using interactions?
And then inserting a check for an endstop being pressed and add an extra physical button to stop the macro?
Can I add an extra endstop without adding an extra axis? -
You could have the macro start a print, the print file being the test gcode you wish to run.
