    duet 3 endstop wiring
    3.1k
      A Former User
      the ground and input pin of the io0-8 headers
      although you may want to refer to https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO and use the io headers that doesn't have other functions you may need
      • Dad003undefined
        Dad003
        so middle pin and the one next to it , it what i have right now but my endstop always show as triggered in the duet control , when i try to home axis move but do not hit the switch
          A Former User
          normally open or normally closed switch? and how is it configured?
          • Dad003undefined
            Dad003
            they are close switch that open when hit , duet control show then has triggered , one on each axis , at the low end excepted the Y axis
            here the switch him using
            ![https://cdn11.bigcommerce.com/s-mm9wpa/images/stencil/original/products/1204/5043/microswitch_with_1000mm_cable_800x800__94048.1506175702.jpg?c=2](image url)
            • Dad003undefined
              Dad003
              i found something when i hold the limits switch it show as not trig erred anymore and when release it show back to triggered what parameter i show inverse ?
                A Former User @Dad003
                @Dad003 said in duet 3 endstop wiring:
                next to it could be ioN.out or ioN.in so pin 2 is input and pin 3 is ground to rule out ambiguity.
                also how is it configured in config.g?
                edit: ah, its configured connected correctly then. I think you need to invert the pin with the M950 command, but someone will probably confirm.
                • Dad003undefined
                  Dad003
                  SO WHAT SHOULD THE M950 LOOK LIKE ? SOMETHING LIKE THIS ? IN THE WIKI THERE NOT REALLY AN EXEMPLE FOR THAT KIND OF STUFF
                  M950 Jnn "IO_0" C"IO0.IN" !
                  • Danalundefined
                    Danal
                    Endstops directly define their pin in m574, no M950 is used.
                    M574 X1 S1 P"io1.in" ; Set homing switch configuration X1 = low-end, S1 = active-high (NC)
                    Dad003undefined 1 Reply Last reply Reply Quote 0
                    • Danalundefined
                      Danal
                        A Former User
                        maybe thats just for the zprobe, and you can invert the endstop with a ! in m574 ? idk and caps locks doesn't help..
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                        • Danalundefined
                          Danal
                          Z Probe also directly defines its pin, and yes, ! and ^ work per usual:
                          M558 K0 P9 C"^io4.in" H9 A5 T6000 S0.02 ; Z probe BLtouch - Set the height of the bed when homing G28. Combined with content of bed.g as invoked by G32, levels bed. Also used for Mesh.
                          • Dad003undefined
                            Dad003 @Danal
                            @Danal
                            when i try this G code it tell me the pin is not free and nothing happen
                            • Danalundefined
                              Danal
                              Then you have something else in your config.g that defines that pin, before what you are trying. There are no default assignments.
                              Did you remove the M950?
                              • Dad003undefined
                                Dad003
                                this is what i have for config file
                                M569 P0.5 S1 ; physical drive 0.5 goes forwards
                                M569 P0.4 S0 ; physical drive 0.4 goes forwards
                                M584 X0.0 Y0.1 Z0.2 E0.5:0.4 ; set drive mapping
                                M92 X160.00 Y160.00 Z6400.00 E172.64:172.64 ; set steps per mm
                                M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                                M906 X800 Y800 Z800 E800:800 I50 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M208 X360 Y260 Z700 S0 ; set axis maxima
                                M574 X1 S1 P"io0.in" ; configure active-low endstop for low end on X via pin io0.in
                                M574 Y2 S1 P"io2.in" ; configure active-low endstop for high end on Y via pin io2.in
                                M574 Z2 S1 P"io1.in" ; configure active-low endstop for low end on Z via pin io1.in
                                M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                M308 S0 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
                                M308 S1 P"spi.cs0" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs0
                                M143 H1 S260 ; set temperature limit for heater 1 to 260C
                                M308 S2 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs1
                                M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
                                M143 H2 S290 ; set temperature limit for heater 2 to 290C
                                M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                                M106 P0 C"extruder 1" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
                                M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                                M106 P1 C"extruder 2" S1 H2 T45 ; set fan 1 name and value. Thermostatic control is turned on
                                M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
                                M106 P2 C"blower" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
                                M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
                                M106 P3 C"electrical" S1 H1:2 T30 ; set fan 3 name and value. Thermostatic control is turned on
                                M563 P1 D0 H1 F0 ; define tool 1
                                M563 P2 D1 H2 F0 ; define tool 2
                                G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
                                G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                                T1 ; select first tool
                                  try
                                  M574 X1 S1 P"!io0.in"
                                  and so on
                                  • Dad003undefined
                                    Dad003
                                    my endstop are assigne to io_0 , io_1 and io_2
                                      A Former User
                                      note the exclamation point before the pin name, should invert the pin so its active when pressed instead of the other way around.
                                      • Dad003undefined
                                        Dad003 @A Former User
                                        @bearer said in duet 3 endstop wiring:
                                        thank you , that solved my problem !
                                        and another problem gone , now i need to figure out why the bed heat so slow
                                        • Dad003undefined
                                          Dad003
                                          so here another development after finally having the limit switch in the right state , trying to home the axis , X will move and do what need to be done , Y will move but not hit the switch or ram into the switch without stopping and say it home and the Z axis will move like 10mm and nothing else without even ever getting close of the switch
                                          him using the basic g code from the RRF Config tool, i even copy pasted the X home code that was working and switching the coordinate and axis and it still doesnt work
                                          ; homeall.g
                                          ; called to home all axes
                                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 01:01:37 GMT-0600 (Mountain Daylight Time)
                                          G91 ; relative positioning
                                          G1 H2 Z-5 F3000 ; lift Z relative to current position
                                          G1 H1 X-365 Y255 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                          G1 H2 X5 Y-5 F3000 ; go back a few mm
                                          G1 H1 X-365 Y255 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                          G1 H1 Z-805 F360 ; move Z down stopping at the endstop
                                          G90 ; absolute positioning
                                          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                          ;G91 ; relative positioning
                                          ;G1 Z-5 F50 ; lift Z relative to current position
                                          ;G90 ; absolute positioning
                                            Please reset the homing files to the ones the the configurator generated, and post them here along with your current config.g file.
