    duet 3 endstop wiring
    3.1k
    • Danalundefined
      Danal
      Z Probe also directly defines its pin, and yes, ! and ^ work per usual:
      M558 K0 P9 C"^io4.in" H9 A5 T6000 S0.02 ; Z probe BLtouch - Set the height of the bed when homing G28. Combined with content of bed.g as invoked by G32, levels bed. Also used for Mesh.
      • Dad003undefined
        Dad003 @Danal
        @Danal
        when i try this G code it tell me the pin is not free and nothing happen
        • Danalundefined
          Danal
          Then you have something else in your config.g that defines that pin, before what you are trying. There are no default assignments.
          Did you remove the M950?
          • Dad003undefined
            Dad003
            this is what i have for config file
            M569 P0.5 S1 ; physical drive 0.5 goes forwards
            M569 P0.4 S0 ; physical drive 0.4 goes forwards
            M584 X0.0 Y0.1 Z0.2 E0.5:0.4 ; set drive mapping
            M92 X160.00 Y160.00 Z6400.00 E172.64:172.64 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800:800 I50 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X360 Y260 Z700 S0 ; set axis maxima
            M574 X1 S1 P"io0.in" ; configure active-low endstop for low end on X via pin io0.in
            M574 Y2 S1 P"io2.in" ; configure active-low endstop for high end on Y via pin io2.in
            M574 Z2 S1 P"io1.in" ; configure active-low endstop for low end on Z via pin io1.in
            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
            M308 S0 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
            M308 S1 P"spi.cs0" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs0
            M143 H1 S260 ; set temperature limit for heater 1 to 260C
            M308 S2 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs1
            M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
            M143 H2 S290 ; set temperature limit for heater 2 to 290C
            M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
            M106 P0 C"extruder 1" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
            M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
            M106 P1 C"extruder 2" S1 H2 T45 ; set fan 1 name and value. Thermostatic control is turned on
            M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
            M106 P2 C"blower" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
            M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
            M106 P3 C"electrical" S1 H1:2 T30 ; set fan 3 name and value. Thermostatic control is turned on
            M563 P1 D0 H1 F0 ; define tool 1
            M563 P2 D1 H2 F0 ; define tool 2
            G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
            G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
            T1 ; select first tool
              A Former User @Dad003
              @Dad003 said in duet 3 endstop wiring:
              try
              M574 X1 S1 P"!io0.in"
              and so on
              Dad003undefined 1 Reply Last reply Reply Quote 0
              • Dad003undefined
                Dad003
                my endstop are assigne to io_0 , io_1 and io_2
                  A Former User
                  note the exclamation point before the pin name, should invert the pin so its active when pressed instead of the other way around.
                  • Dad003undefined
                    Dad003 @A Former User
                    @bearer said in duet 3 endstop wiring:
                    thank you , that solved my problem !
                    and another problem gone , now i need to figure out why the bed heat so slow
                    • Dad003undefined
                      Dad003
                      so here another development after finally having the limit switch in the right state , trying to home the axis , X will move and do what need to be done , Y will move but not hit the switch or ram into the switch without stopping and say it home and the Z axis will move like 10mm and nothing else without even ever getting close of the switch
                      him using the basic g code from the RRF Config tool, i even copy pasted the X home code that was working and switching the coordinate and axis and it still doesnt work
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 01:01:37 GMT-0600 (Mountain Daylight Time)
                      G91 ; relative positioning
                      G1 H2 Z-5 F3000 ; lift Z relative to current position
                      G1 H1 X-365 Y255 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y-5 F3000 ; go back a few mm
                      G1 H1 X-365 Y255 F360 ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-805 F360 ; move Z down stopping at the endstop
                      G90 ; absolute positioning
                      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                      ;G91 ; relative positioning
                      ;G1 Z-5 F50 ; lift Z relative to current position
                      ;G90 ; absolute positioning
                        Please reset the homing files to the ones the the configurator generated, and post them here along with your current config.g file.
                        • Dad003undefined
                          Dad003
                          @dc42 ok,
                          here the Z home
                          **; homez.g
                          ; called to home the Z axis
                          G1 H1 Z-805 F1800 ; move Z down until the endstop is triggered
                          ;G90 ; absolute positioning**
                          here the Y home
                          ; homey.g
                          ; called to home the Y axis
                          G1 H1 Y255 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 H2 Y-5 F3000 ; go back a few mm
                          G1 H1 Y255 F360 ; move slowly to Y axis endstop once more (second pass)
                          G1 H2 Z5 F3000 ; lower Z again
                          the X files
                          ; homex.g
                          ; called to home the X axis
                          G1 H1 X-365 F1800 ; move quickly to X axis endstop and stop there (first pass)
                          G1 H2 X5 F3000 ; go back a few mm
                          G1 H1 X-365 F360 ; move slowly to X axis endstop once more (second pass)
                          ANd my config file
                          **; Configuration file for Duet 3 (firmware version 3)
                          M550 P"The mean printer" ; set printer name
                          M551 P"9410648" ; set password
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S1 ; enable FTP
                          M586 P2 S0 ; disable Telnet
                          M569 P0.5 S0 ; physical drive 0.5 goes backwards
                          M569 P0.4 S1 ; physical drive 0.4 goes forwards
                          M92 X160.00 Y160.00 Z3200.00 E172.64:172.60 ; set steps per mm
                          M906 X1500 Y1500 Z1200 E1500:1500 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M208 X360 Y250 Z800 S0 ; set axis maxima
                          M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin io0.in
                          M574 Y2 S1 P"!io2.in" ; configure active-high endstop for high end on Y via pin io2.in
                          M574 Z2 S1 P"!io1.in" ; configure active-high endstop for low end on Z via pin io1.in
                          M558 P0 H-5 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed
                          M308 S0 P"temp3" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp3
                          T1 ; select first tool**
                          MY bed should go down hit the limit switch and back up but nothing happen when i try to home that one but it will move when using control
                          • Dad003undefined
                            Dad003
                            Here something weird , i was trying to tune the heat bed and started homing Y actually worked like intended i didn't change anything in the config when it wasnt working 15 min earlier
                            • Dad003undefined
                              Dad003 @dc42
                              So i tested something here , tried ot home the Z with heat bed OFF it move 10mm and stop , started heated bed and boom Z axis keep moving , ANy idea what G CODE i should had or remove or modify ?
                                You're set up to home to Z max. Where is the endstop located? Is it at the bottom when the be is closest to the nozzle or is it at the opposite end?
                                • Dad003undefined
                                  Dad003 @Phaedrux
                                  @Phaedrux ends stop is at the bottom the opposite side of the hot end ,
                                    Phaedrux Moderator @Dad003
                                    ; homez.g
                                    Ok, in that case your homez should have a positive Z movement to the endstop rather than negative.
                                    G1 H1 Z805 F1800
                                    • Dad003undefined
                                      Dad003
                                      So after a few frustrating days i still have problem , my Y axis and Z axis will not home , they move a little and the duet web control show as home when they didnt even touch the limit switch
                                      here a video of the Y axis showing my problem , if i run a macro to move the axis after they home everything move fine but homing Y and Z unless they are already next to the limit switch doesnt work they start moving than stop sometime they move more like the video show . Either it a parameter that i dont see somewhere in the config but it not the gcode in the home files since the X work fine , if it neither in the file than is a firmware issue and it a big one , him running the last available firmware 3.01 RC11.
                                      https://www.youtube.com/watch?v=VYiLlLr1R1s
                                      ; homey.g
                                      G1 H2 Z5 F3000 ; lower Z relative to current position
                                      G1 H2 Y-5 F3000
                                      G1 H1 Y300 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                                      G1 H1 Y300 F360 ; move slowly to Y axis endstop once more (second pass)
                                      ; homez.g
                                      G1 H2 Z10 F3000 ; lift Z relative to current position
                                      G1 H1 Z805 F3000 ; move Z down until the endstop is triggered
                                      G92 Z572 ; set Z position to axis minimum (you may want to adjust this)
                                      M906 X1600 Y1600 Z1200 E1600:1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M208 X360 Y250 Z572 S0 ; set axis maxima
                                      M308 S0 P"temp3" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin temp3
                                      G10 P2 X0 Y34.05 Z0 ; set tool 2 axis offsets
                                      • Danalundefined
                                        Danal
                                        If you have physical normally closed switches, you do not need the !
                                        Go to the "machine specific" tab and look lower right. There is a sub-screen that shows endstop status. Verify the say "No" under triggered. Then press them with your finger and be sure each says "yes" .
                                        • Dad003undefined
                                          Dad003
                                          they are all on no and they all work , when i press them
                                          • Danalundefined
                                            Danal
                                            Then the switches themselves are working and configured correctly.
                                            Therefore, look at the homing files, or axis configuration, or other similar things.
