    Z probe offset - off edge of bed...
    1.2k
    • dbrb2undefined
      dbrb2
      I had tried some G31 variations
      The duet uses the offset here to set the X and Y position when the endstops are hit - but in my case this puts the Z sensor off the edge of the board - so after homing X and Y it will need to move in bot h X and Y before homing Z...
      • PaulHewundefined
        PaulHew
        OK, I home Z in the middle of the bed. I have an Ender3 Pro and a Hangtight Titan Aero mount, so my Y is off the bed.
        My homez.g
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool v2.1.6 on Mon Jan 13 2020 17:26:38 GMT+0000 (Greenwich Mean Time)
        G91              ; relative positioning
        G1 H2 Z5 F6000   ; lift Z relative to current position
        G90              ; absolute positioning
        G1 X122 Y122 F6000 ; go to first probe point
        G30              ; home Z by probing the bed
        Let get you homing Z first.
        Please post your config.g just so we know if you are using RRF2 or 3
        And a M115, please
        Regards,
        Paul.
        • dbrb2undefined
          dbrb2
          Ah - some progress:
          I updated my homez.g to be similar to yours above, and can now home the Z fine - though I do get the following error:
          M280: Invalid servo index 3 in M280 command
          "Home All" though still crashes the z into the bed. I haven't yet worked out the relationship between the homez.g, homey.g, homez.g, and homeall - It doesn't look like "homeall.g" simply calls he first three in sequence....
          My config.g for z probe is:
          M558 P5 I1 H5 F120 T6000                ; set Z probe type to inductive and the dive height + speeds
          G31 P500 X50 Y50 Z5.0                   ; set Z probe trigger value, offset and trigger height
          M557 X15:290 Y15:290 S20                ; define mesh grid
          And M115 gives me:
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
          • PaulHewundefined
            PaulHew
            @dbrb2 Please post your config.g and you homez.g
            Bits of config.g does not help us 🙂
            What probe do you have, BL Touch or something else?
            Regards,
            Paul.
            • dbrb2undefined
              dbrb2
              It's an NPN inductive probe. It seems to trigger OK at present when I use "z home" - but "home all axis" causes dthe probe to crash into the bed when it gets to Z - so "home all" doesn't seem to make use of the "homez" gcode....
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 19:55:13 GMT+0100 (British Summer Time)
              G90                                     ; send absolute coordinates...
              G21                                     ; use mm
              M83                                     ; ...but relative extruder moves
              M550 P"TronXY X5SA"                     ; set printer name
              M669 K1                                 ; select CoreXY mode
              M552 S1                                 ; enable network
              M586 P0 S1                              ; enable HTTP
              M586 P1 S0                              ; disable FTP
              M586 P2 S0                              ; disable Telnet
              M569 P0 S1                              ; physical drive 0 goes forwards
              M569 P1 S1                              ; physical drive 1 goes forwards
              M569 P2 S0                              ; physical drive 2 goes forwards
              M569 P3 S0                              ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                        ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z1200.00 E420.00      ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                 ; Set idle timeout
              M208 X00 Y00 Z0 S1                      ; set axis minima
              M208 X310 Y310 Z380 S0                  ; set axis maxima
              M574 X1 Y1 S0                           ; set active low endstops
              M574 Z1 S2                              ; set endstops controlled by probe
              ; Filament Run Out Sensor
              M591 D0 P1 C4 S1 ; Filament runout Sensor for Extruder E0 on E1 Endstop input P1 = signal HIGH.
              G31 P500 X20 Y20 Z5.0                   ; set Z probe trigger value, offset and trigger height
              M307 H0 B0 S1.00                        ; disable bang-bang mode for the bed heater and set PWM limit
              M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
              M143 H0 S120                            ; set temperature limit for heater 0 to 120C
              M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
              M143 H1 S280                            ; set temperature limit for heater 1 to 280C
              M106 P2 S0 I0 F500 H-1                  ; set fan 2 as part cooling fan
              M106 P0 T45 S0.7 H1			; set fan 0 as our hotend fan
              M563 P0 D0 H1 F2                        ; define tool 0 uses part cooling fan 0
              G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
              G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
              • PaulHewundefined
                PaulHew
                Have you seen this guide?
                https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                Please post homeall.g and homez.g
                We will get there!
                P.
                • dbrb2undefined
                  dbrb2
                  I think I am getting there - a "home z" now works, as does a "auto bed level compensation"
                  ; homez.g
                  G1 X50 Y50 F6000 ; go to first probe point
                  ;G91 ; relative positioning
                  ;G90 ; absolute positioning
                  However, a "homeall" complains that I have homes insufficient axis (even if run just after a sucesful home X and Y)
                  ; homeall.g
                  ; called to home all axes
                  G1 H1 X-335  Y-335      ; move quickly to X or Y endstop and stop there (first pass)
                  G1 X5 Z5 F6000          ; go back a few mm
                  G1 H1 X-335 F360        ; move slowly to X axis endstop once more (second pass)
                  G1 H1 Y-335 F360        ; move slowly to Y axis endstop once more (second pass)
                  G1 X50 Y50		; Move z probe over bed
                  G1 H1 Z-405             ; then move slowly to Z axis endstop
                  G1 H1 Z5 F6000          ; lift Z relative to current position
                  G1 H1 Z-335 F1800       ; move Z down stopping at the endstop
                  In addition, the M280 z probe error still occurs - but from what I had seen of the guide you suggested, I had set the probe up as a type 5, which I think is correct....
                  • PaulHewundefined
                    PaulHew
                    @dbrb2 as long as the individual homing buttons work, ie homex y and z, you should be able to use this.
                    Rename homeall.g to OLDhomeall.g
                    Create a new homeall.g and put the following lines in it.
                    M98 P"homex.g"
                    M98 P"homey.g"
                    M98 P"homez.g"
                    Regards,
                    Paul
                    dbrb2undefined 1 Reply Last reply Reply Quote 1
                    • dbrb2undefined
                      dbrb2 @PaulHew
                      @PaulHew Cheers - I'll give it a go first thing in the morning
                      • dbrb2undefined
                        dbrb2
                        Thanks - that worked
                        And the M280 issue is also resolved - I had a deploy and retract probe file, but the inductive probe is always in place - so this was referring to a servo that did not exist
                        Cheers!
                        • PaulHewundefined
                          PaulHew
                          @dbrb2 Pleasure, That is what the forum is for!
                          Regards,
                          Paul
                          dbrb2undefined 1 Reply Last reply Reply Quote 0
                          • dbrb2undefined
                            dbrb2 @PaulHew
                            @PaulHew thanks
                            Mechanically and electrically all now works. Something I suspect though is wrong in my config still. My 20mmcalibration cube gets this far:
                            Which doesn't look great, before reliably lifting from the bed entirely. I have set Z quite a few times, and checked the bed temperature. This isn't a problem I had with the old stock board, so I suspect the issue is with my config....perhaps something to do with my extruder settings:
                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                            I'll double check them. Will get there though...try again tomorrow!
