    Fans don't turn on/work
    2.5k
      So the fans were working but now do not?
      What else did you change?
      Is there a blue LED lit on the wifi module? Does it blink at power on?
      If you connect USB terminal, can you send M552 and report the response?
      Also send M122 and report the response.
      Asabolundefined 1 Reply Last reply Reply Quote 0
      • Asabolundefined
        Asabol @Phaedrux
        @Phaedrux Before the fans stopped working the WiFi module would blink when turned on but now they don’t.
        • Asabolundefined
          Asabol
          I also think I had uploaded the wrong file for the config file because I had changed some stuff and I wanted to go back to the way I had it. So if I upload the correct files for the config then also do the things you said to do I think I can get the printer to operational again.
          • Asabolundefined
            Asabol
            This is the response from the printer for what you asked me to type in.
              Ok, send M552 S1 to re-enable the wifi module.
              What is in your config.g now?
              • Asabolundefined
                Asabol
                I had accidentally uploaded the wrong package for the config file then I uploaded the correct one for the printer. Question now that I have most of the things back into working order. Why does my thermostatically controlled fan not turn on when I have the hotend above 45C.
                • Asabolundefined
                  Asabol
                  Also since I pushed the correct package for the config, the wifi turns on when I turn the printer on.
                    Phaedrux Moderator @Asabol
                    @Asabol said in Fans don't turn on/work:
                    That will depend on which fan port it's plugged into and what your M106 fan config looks like. If you tell me that I might be able to tell you why it's not turning on. And if the configuration checks out good, there is a chance there is damaged mosfet or fan, but we'll cross that bridge when we get to it.
                    • Asabolundefined
                      Asabol
                      This is what M106 says in my config.
                      M106 P0 S0.45 I0 F20 H-1                           ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P1 S0 I0 F20 H1 T45                           ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M106 P2 S0 I0 F20 H1:0 T45                         ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        And which port are you using for the hotend fan?
                        • Asabolundefined
                          Asabol
                          I have that fan plugged into the first port of the always on which I think is incorrect. Then I also have the electronics case fan plugged into the other always on port and the part cooling fan into port 0 of the PWM fan ports.
                            There's your problem. The always on fan ports are always on, so they are not thermostatically controlled.
                            Part cooling fan to port 0 is correct and your config looks correct for that as well.
                            Connect your hotend fan to port 1 and it should be correct as well.
                            For the case fan, if you want them to turn on when you are printing at temp, connect it to port 2.
                            • Asabolundefined
                              Asabol
                              So I did that and now when it gets above 45C it still doesn't turn on. So what could be the issue then? Also should I add a picture to show how the cables are in the connectors. Meaning that they might be backwards.
                                Does the fan work at all when connected to the always on port?
                                • Asabolundefined
                                  Asabol
                                  No it doesn't
                                    Do other fans work when connected to that always on port?
                                    • Asabolundefined
                                      Asabol
                                      No any other ones won't turn on when connected to the always on ports.
                                      • Asabolundefined
                                        Asabol
                                        The electronics case one used to but it doesn't anymore.
                                          Ok, that means that either your fans are all dead, or there is either a blown fan fuse or damaged mosfet(s).
                                          Do any of those fans work with any of the other ports?
                                          Can you post some photos of the fan port area? Close up and well lit.
                                          • Asabolundefined
                                            Asabol
                                            Here is a picture of the fan area. I think I might have the cables to the fans in backwards. IMG-0844.jpg (image url)
