    12V on the 5V rail
    2.9k
      A Former User @A Former User
      @bearer said in 12V on the 5V rail:
      but should be compatible with AP7361C-33ER-13
      @Haggan90 just clicked in my head the AP7361C doesn't specify if the tab is connected to v-out or gnd or anything at all; so I can't say for sure if it works.
      TC2117-3.3VDBTR is the full partno from the 1.03 schematic.
      Haggan90undefined 1 Reply Last reply Reply Quote 0
      • Haggan90undefined
        Haggan90 @A Former User
        TC2117-3.3VDBTR
        IS this the correct one?
        https://www.digikey.se/product-detail/sv/microchip-technology/TC2117-3-3VDBTR/TC2117-3-3VDBCT-ND/7065613
          A Former User
          has the same manufacturer part number as on the schematic at least, so thats about as sure as I can get.
          "Tillverkarens artikelnummer TC2117-3.3VDBTR"
          (the key to decoding the part numbers are usually towards the end of the datasheets, helps decode the various letters and numbers)
          • Haggan90undefined
            @bearer Hi!
            I have now changed the U2 and I can connect to the board via USB 😃
            It seems like maybe the WiFi module is broken, but is there any way I can check that over YAT?
              A Former User
              just follow the getting started guide to set up wifi again, if it responds to M552 and connects you're good.
              • Haggan90undefined
                @bearer ok!
                The blue LED does not light up on start, is that a bad thing?
                • Haggan90undefined
                  Haggan90 @Haggan90
                  @Haggan90
                  Ok, it seems like I can't get the Wifi module into idle mode.
                  Also, I do belive it get's a bit warm, not hot but warm.
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1<LF>ok<LF>
                  M552 S-1
                  WiFi module stopped<LF>ok<LF>
                  M552
                  WiFi module is disabled<LF>ok<LF>
                  M552 S0
                  ok<LF>
                  M552
                  WiFi module is being started<LF>ok<LF>
                  M552 S0
                  ok<LF>
                  M552 S0
                  ok<LF>
                  M552
                  M587
                  M587: Failed to retrieve network list<LF>ok<LF>
                    Phaedrux Moderator @Haggan90
                    @Haggan90 try deleting all saved wifi networks with M588 S"*" (That is, using an asterix for the network name), then re-adding it with M587. For example, M587 S"networkname" P"password".
                    Haggan90undefined 2 Replies Last reply Reply Quote 0
                    • Haggan90undefined
                      Haggan90 @Phaedrux
                      @Phaedrux Hi, I get this:
                      M588 S"*"
                      M588: Failed to reset the WiFi module to factory settings<LF>ok<LF>
                      • Haggan90undefined
                        Haggan90 @Phaedrux
                        @Phaedrux The SD-Card seems to be fine.
                        Do I need a hot air desoldering station to change the Wifi Module? And, what would I need to do after I've changed it?
                        This is what I get when sending M21.
                        M21
                        SDHC card mounted in slot 0, capacity 3.98Gb<LF>ok<LF>
                          A Former User @Haggan90
                          @Haggan90 said in 12V on the 5V rail:
                          A good preheating and some quickchip or similar 138C-ish melting point solder might to the trick; but most likely "yes".
                          edit: oh, and after all you need to do is run M997 S1, presuming the wifi firmware file is in the /sys folder on the SD card.
                          Haggan90undefined 1 Reply Last reply Reply Quote 1
                          • Haggan90undefined
                            @bearer Thank you! I will see what I come up with to desolder it 😃
                            Is there any special version of the ESP-12S Wifi Module I need?
                              ESP-12S
                              Thats about as specific as you can get, but no, any ESP-12 ought work, the 12S has all the right certifications on it which is important for Duet3d selling them, not so much for you. I.e. you could use a 12E or F if easier to obtain (or pretty much any other ESP with the same footprint)
                              (the ESP-07S is an official option if you want external antenna, just make sure to never run it without antenna attached to avoid damage to the rf tx)
                              • Haggan90undefined
                                @bearer Thanks!
                                I just ordered a ESP-07S as I have a bunch of these antennas laying around, hoping for a bit better range on the WiFi then 😃
                                • Haggan90undefined
                                  Haggan90
                                  Manage to desolder it using a regular soldering iron, now I just need the new chip!
                                  • Haggan90undefined
                                    @bearer Woho! It's working again! 😄 Thanks for all the help!
                                      A Former User
                                      Well done! I'm sure the planet prefers a bit of repairing to just landfills:)
                                      • Haggan90undefined
                                        @bearer
                                        Unfortunalty is seems like the Duex2 took a hit as well, as I can't get the steppers working there.
                                        Nothing get's hot on the board.
                                        Any idea what could have broke on the Duex2?
                                          dc42 administrators @Haggan90
                                          Does M115 report that there is a DueX connected? If not then the SX1509B chip has probably failed.
                                          • Haggan90undefined
                                            Haggan90 @dc42
                                            M115
                                            So, is that SX1509B hard to change? 😃
                                            And where can I find it on the DUEX2? 😃
