    Upgrading from RRF2 to RRF3 issues
    Firmware installation
    914
    • Fodenundefined
      Foden @Foden
      @Foden
      This is my original working RRF2 config.g
      Original RRF2 config.g
      ; generated by RepRapFirmware Configuration Tool on Sun Sep 09 2018 17:28:37 GMT-0600 (Mountain Daylight Time)
      M667 S1 ; select CoreXY mode
      M550 PLB-HEVO ; set machine name
      M551 PXXXXXXXXXX ; set password
      M552 S1 ; Enable network
      M587 S"XXXXXXXXXXXXX" P"XXXXXXXXXXXXXXX" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X79.29 Y79.48 Z400.63 E467.00 ; set steps per mm - calibrated from 20mm cube Jan 13 2018
      M203 X8000.00 Y8000.00 Z2000.00 E1000.00 ; set maximum speeds (mm/min)
      M201 X2000 Y2000 Z400 E10000 ; set maximum accelerations (mm/s^2)
      M906 X1500 Y1500 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; set idle timeout
      M208 X275 Y275 Z300 S0 ; set axis maxima
      M574 X1 S1 ; set active high endstops
      M574 Y1 S0 ; set active high endstops
      M307 H7 A-1 C-1 D-1 ; disable the 7th Heater to free up PWM channel 5 on the Duex board
      M558 P9 H5 R0.3 F1000 T4000 X0 Y0 Z1 A4 S0.04 ; set Z probe type/mode 9. H=Dive Height. F=Speed the bed
      G31 P25 X-26.5 Y-12 Z2.14 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X0:275 Y15:275 S30 ; define mesh grid - S=spacing between points in mm
      M305 P0 T100000 B4725 C0 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
      ;Fan 0-Bed, 1-Hotend
      M106 P0 H-1
      M106 P1 T45 H1 ;Hot End fan, thermostatic control is turned on at 45c runs at 100%
      M563 S"Nozzle1" P0 D0 H1 ; Define tool 0
      ; Custom settings
      ;Correct CPU temp
      M912 P0 S-10.1
      M501 ; Load saved parameters from non-volatile memory
        Your motor currents are much lower in our RRF3 config.
        M574 S0 is not supported in RRF3 anymore.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
        Endstop type S0 (active low switch) is no longer supported in M574 commands. Instead, use type S1 and invert the input by prefixing the pin name with '!'. Ex: M574 X1 S1 P"!xstop". Invert the input when using an NPN output inductive or capacitive sensor, or using a NO switch (not recommended, use a NC switch instead).
        So that may explain your Y endstop issue.
        Use M574 Y1 S1 P"!ystop" instead.
        For the BLTouch you have M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 remove the +zprobe.mod part. The modulation shouldn't be used. In the configurator it is selected by default and should be deselected. It's on the change list to have that fixed as it tends to catch people out quite often. Sorry about that.
        Also for the BLTouch, what do you have for your deploy and retract macros? Does M401 and M402 work to deploy and retract the pin?
        Fodenundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @Foden
          @Foden said in Upgrading from RRF2 to RRF3 issues:
          M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          Recent versions of BLTouch need the pullup resistor enabled too:
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          • Fodenundefined
            Foden @Phaedrux
            @Phaedrux Thanks Phaedrux
            Motor currents - looks like i messed up there as it is taking the values now
            Missed the M574 info - thought i had read it all properly, obviously not and appreciate the heads up. However that code was all created by the configuration tool
            BLTouch - yes M401 & M402 work as expected
            ; deployprobe.g
            ; called to deploy a physical Z probe
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 18:10:19 GMT-0600 (Mountain Daylight Time)
            M280 P0 S10 ; deploy BLTouch
            ; retractprobe.g
            ; called to retract a physical Z probe
            M280 P0 S90 ; retract BLTouch
            • Fodenundefined
              Foden @dc42
              @dc42 Thanks DC42
              Working through Phaedrux and your updates
              Much appreciated guys!!!
              • Fodenundefined
                Foden @Foden
                @Foden Quick and outstanding support as ever - THANK YOU guys
                Homing of the Y axis now works as expected as does the BLTouch. So was I selecting the wrong thing(s) here are there changes coming for the config tool? I was trying to keep my initial, baseline, config clean and created by the config tool before I dirty it with tweaking and fiddling with it
                  Phaedrux Moderator @Foden
                  The config tool is yet to be updated fully and is still outputting S0 rather than ! on the pin. It's on the list for the next update.
                  Glad it's working though,
                  • Fodenundefined
                    Foden @Phaedrux
                    @Phaedrux
                    Just noticed that if i do X home more than once (paranoia kicking in) X axis keeps moving to the right. Checked the endstop status and X is showing as triggered regardless of whether it actually is or not. Haven't messed with any cables and the optical sensor itself was working properly
                    M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
                    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                    G31 P500 X-26.5 Y-12 Z2.14 ; set Z probe trigger value, offset and trigger height
                    M557 X20:275 Y20:275 S20 ; define mesh grid
                    Stepped away from it for awhile, hit the emergency stop so it knows I'm still in charge and now it works like it should
                    No sane person would build their own 3D printer I guess
                    Thanks again!
                      Given that this is a CoreXY we should verify that your motor directions are correct and that you are configured to use a right hand coordinate system.
                      I'll point you to this post which goes through the steps of verifying that everything is set correctly (end stop positions, homing directions, and motor rotations)
                      https://forum.duet3d.com/topic/12676/mirrored-x-axis/9?_=1588616543576
                      • Fodenundefined
                        Foden @Phaedrux
                        @Phaedrux
                        I looked through the link
                        Motor directions are correct and haven't changed since original setup some years ago. Y endstop was changed when an optical sensor died and I only had mechanical spares so it was swapped and I haven't swapped it back since
                        As I mentioned, once I left it alone and the hit the emergency button all is well - go figure
                          Is this with RRF 3.0 or with RRF 3.01-RC11 ? I recommend you use 3.01-RC11.
                          • Fodenundefined
                            Foden
                            @dc42 said in Upgrading from RRF2 to RRF3 issues:
                            3.01-RC11
                            It was with 3.01-RC11 - once I left it alone and the hit the emergency button all was well
