    Upgrading from RRF2 to RRF3 issues
    Firmware installation
    881
      dc42 administrators @Foden
      @Foden said in Upgrading from RRF2 to RRF3 issues:
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      Recent versions of BLTouch need the pullup resistor enabled too:
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      Fodenundefined 1 Reply Last reply Reply Quote 0
      • Fodenundefined
        Foden @Phaedrux
        @Phaedrux Thanks Phaedrux
        Motor currents - looks like i messed up there as it is taking the values now
        Missed the M574 info - thought i had read it all properly, obviously not and appreciate the heads up. However that code was all created by the configuration tool
        BLTouch - yes M401 & M402 work as expected
        ; deployprobe.g
        ; called to deploy a physical Z probe
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 03 2020 18:10:19 GMT-0600 (Mountain Daylight Time)
        M280 P0 S10 ; deploy BLTouch
        ; retractprobe.g
        ; called to retract a physical Z probe
        M280 P0 S90 ; retract BLTouch
        • Fodenundefined
          Foden @dc42
          @dc42 Thanks DC42
          Working through Phaedrux and your updates
          Much appreciated guys!!!
          • Fodenundefined
            Foden @Foden
            @Foden Quick and outstanding support as ever - THANK YOU guys
            Homing of the Y axis now works as expected as does the BLTouch. So was I selecting the wrong thing(s) here are there changes coming for the config tool? I was trying to keep my initial, baseline, config clean and created by the config tool before I dirty it with tweaking and fiddling with it
              Phaedrux Moderator @Foden
              The config tool is yet to be updated fully and is still outputting S0 rather than ! on the pin. It's on the list for the next update.
              Glad it's working though,
              • Fodenundefined
                Foden @Phaedrux
                @Phaedrux
                Just noticed that if i do X home more than once (paranoia kicking in) X axis keeps moving to the right. Checked the endstop status and X is showing as triggered regardless of whether it actually is or not. Haven't messed with any cables and the optical sensor itself was working properly
                M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
                M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                G31 P500 X-26.5 Y-12 Z2.14 ; set Z probe trigger value, offset and trigger height
                M557 X20:275 Y20:275 S20 ; define mesh grid
                Stepped away from it for awhile, hit the emergency stop so it knows I'm still in charge and now it works like it should
                No sane person would build their own 3D printer I guess
                Thanks again!
                  Given that this is a CoreXY we should verify that your motor directions are correct and that you are configured to use a right hand coordinate system.
                  I'll point you to this post which goes through the steps of verifying that everything is set correctly (end stop positions, homing directions, and motor rotations)
                  https://forum.duet3d.com/topic/12676/mirrored-x-axis/9?_=1588616543576
                  • Fodenundefined
                    Foden @Phaedrux
                    @Phaedrux
                    I looked through the link
                    Motor directions are correct and haven't changed since original setup some years ago. Y endstop was changed when an optical sensor died and I only had mechanical spares so it was swapped and I haven't swapped it back since
                    As I mentioned, once I left it alone and the hit the emergency button all is well - go figure
                      Is this with RRF 3.0 or with RRF 3.01-RC11 ? I recommend you use 3.01-RC11.
                      • Fodenundefined
                        Foden
                        @dc42 said in Upgrading from RRF2 to RRF3 issues:
                        3.01-RC11
                        It was with 3.01-RC11 - once I left it alone and the hit the emergency button all was well
