    Motor phase A and B may be disconnected reported from driver 2
    384
    • Jmaxime89undefined
      Jmaxime89
      Hello all,
      I'm totally new here, I just got a Duet 2 Wifi yesterday.
      I was so excited to set that up.
      However I have at the moment two issues.
      The first is "Motor phase A and phase B may be disconnected reported by driver 2"
      I checked my crimps, tugged on my wires. Everything looks okay. I tried to swap the wires but I keep having the same error so I put them how it was wired originally on the Anet A8. I read on here that people seemed to have the same issue with an older firmware or with low current motor.
      I have a Duet 2 Wifi 1.02 or later
      Firmware 2.05.1
      Wifi server version 1.23
      Web interface version 1.22.6
      Second thing. I wired a bltouch as per the wiki. I did my config with the configurator. I can't deploy or retract the bltouch at all.
      Same thing here, checked my crimps and double checked my connections and my config. It seems all good.
      Here is my config.g if it can help :
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 04 2020 13:12:37 GMT-0400 (Eastern Daylight Time)
      M550 P"Metal Machine" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S1 ; physical drive 2 goes backwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X100.00 Y100.00 Z400.00 E415.00 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-33 Y-10 Z0 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      M574 X1 Y1 S0 ; set active low and disabled endstops
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y-38 Z2.36 ; set Z probe trigger value, offset and trigger height
      M557 X20:200 Y20:200 S40 ; define mesh grid
      M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S400 ; set temperature limit for heater 1 to 400C
      T0 ; select first tool
      Thank you so much in advance, and I hope to be soon good enough to be able to provide help to others around here.
        Jmaxime89
        EDIT : I tried to wire only one Z motor and put the jumpers in ZB connector. I still have the same error, I tried with both motor
          Are there any markings on the Z motor to indicate its type?
          Have you set up the deployprobe.g and retractprobe.g files for the BLTouch?
            Jmaxime89
            Thanks a lot for giving me a hand.
            On the motors it is written :
            Anet Step motor
            42SHDC3025-24B
            My deployprobe.g reads as such :
            ; deployprobe.g
            ; called to deploy a physical Z probe
            M280 P3 S10 I1 ; deploy BLTouch
            and my retractprobe.g :
            ; retractprobe.g
            ; called to retract a physical Z probe
            M280 P3 S90 I1 ; retract BLTouch
            Thanks once again for the help, I really appreciate it
              Jmaxime89
              Okay what I did is wire both of my motors to the same connector (ZA) and instead of 500mA I put 1000mA.
              Now my Z axis is moving. The only thing left is the BLtouch.
              Now that I can home Z, I realise that it doesn't use my BLtouch for the homing, I pull and push the pin manually and it doesn't stop.
              Thanks in advance for all the help
                Jmaxime89
                Note that I have a genuine BLtouch classic if it might help you troubleshoot my problem
                • ShaunCroundefined
                  ShaunCro
                  Funny thing, I was having these exact same issues the other day, but assumed I had 7 faulty motors as we were robbed the week before and they threw everything on the floor that they didn't want to steal.
                  Was also on the Z motors and my BL deploys, and then just stays there. 😐
                  At least my motors have a bit of hope then. Been meaning to finish off the project. But need to redesign the X to move the hotend 20mm down so it can reach the bed.
                  Out of interest, did you perhaps try allocate E1 as a second Z motor driver aswell?
                  Lets just get one thing straight....
                  You don't own a Delta! It's true, you don't!
                  It owns you!
                    Jmaxime89
                    No I didn't try to reallocate anything. And honestly since now my Z axis is working I'm scared to touch anything, I'm just super glad I got this part working. I really hope I can get my bltouch working now so I can finally enjoy my shiny new board
                      Jmaxime89
                      I measured the voltage going into the bltouch and it's 4.95v which I'm sure is okay. I'm really clueless now
                        Jmaxime89
                        Last post !
                        Found out my issue was completely stupid. I had a bad multimeter that showed continuity in my servo wire when there was none, it was broken
                        Now it works !
                        Thanks a lot for everything
                          Glad you got it sorted out! BLTouch wiring has given many people a headache.
                            Jmaxime89
                            Yeah but it is so easy with the tutorial. I can't believe my multimeter was the main culprit ahahah
