    423
    99.7k
    • Moriquendiundefined
      Moriquendi
      New Piezo Z-probe boards are in as well as Piezo Endstop boards if anyone wants to give those a try.
      Idris
      • Phytone3dundefined
        Phytone3d
        These piezo's are tough units (using 27mm). In fiddling around, the + wire became detached from the centre (pulled the white stuff off)- thought I'd reattach/solder and hope. Well works fine!
        After some more meddling, I am now getting really good results.
        This is the best bed mapping that I've ever had on the printer since running duet wifi.
        • DjDemonDundefined
          DjDemonD
          Excellent results that's very satisfying.
          Yeah they are quite tough the piezo's. On my test rig I've slammed it into the test bed so hard and so many times, it broke the bracket holding the module, but the piezo was still working like a champ. I've had a few de-soldered wires but soldered them back on with little or no drama. One of the issues moving this forward into a consumer unit is the fragility of the soldered connections on the piezo. My thinking is integrate the control board into the sensor module, thereby reducing the mobility in these wires to zero. It also reduces the (theoretical at this point) risk of interference on the lead to the piezo causing issues. There is another idea involving making the piezo part of the circuit and placing that in between the two parts of the assembly.
          www.precisionpiezo.co.uk
          • kraegarundefined
            kraegar
            Talked to a few people at MRRF and handed out some piezo's to a couple guys who had ideas about how to cut the holes more precisely, without any damage. Hopefully I'll have more info on their results soon.
            • DjDemonDundefined
              DjDemonD
              That sounds great. Mike (Leadinglights) has developed a method of cutting them on a lathe. Reasonably neat cuts too. That being said none of the discs I have drilled have failed to perform initially or since.
              I hope at some point we can source or have made piezo's with holes in at manufacture.
              • DjDemonDundefined
                DjDemonD
                Okay so Idris and I are getting closer to having a drop in module ready. More or less settled on the design, just a bit of tweaking. It's done several thousand probes on the rig with no issues. Very stiff as it turns out you don't need any noticeable vertical compliance to get a trigger. Idris is making a custom pcb for it.
                Should be a case of remove hot end, insert module between hot end and extruder/carriage and then plug in your endstop wire. It's for groove mount but could be easily adapted with a few bolt holes for screw mounting.
                It's small around 30x20x18mm. Should illuminate on trigger (but will also make a solid colour version also).
                Aiming for around £25 delivered (UK) for final version. The initial units will be considered beta units and be £19.99 delivered (UK) on the assumption we will get some feedback on improving the product.
                International postage will be by individual postage quote.
                • kraegarundefined
                  kraegar
                  So this would be a piezo with a hole for a bowden, and you just drop it over the top of your groovemount (around the bowden)?
                  • DjDemonDundefined
                    DjDemonD
                    So the idea is this is a module which will sit between the groovemount in your effector/carriage/extruder such as a titan, and your hotend. It will have just a 3 wire endstop connector on it. Its pretuned and tested on my rig. If you are using one in a chamber or your ambient temp is 35 deg C+ then let us know we will tune one for higher temp environment, or leave the PCB adjuster with no threadlock on it so you can tune it yourself.
                    If using bowden, you'd just feed your bowden tube through the middle, there will be space to attach and tension the bowden tube on the hot end, as well as remove the hot end without dismantling the module. If using direct I will supply a short length of bowden tube to use as a filament guide from extruder down into the hotend.
                    This is what it looks like in my test rig. If you don't want groovemount I'll do a version with captive nuts and bolt holes for direct mounting to underside of a carriage or effector. Almost no compliance of the nozzle in this design, the piezo is pre-tensioned quite firmly.
                    The new custom PCB will be attached to the back of the module for the transparent version and it will light up the module when powered and hopefully change colour when triggered. If preferred a solid colour version will also be available with the pcb on the front (you can insert the module into your printer whichever way around you want) so it will show two LED's one for power, one for triggered.
                    This module completed 2000 probes on the rig with no issues. I intend to do a test run of 36800 probes which will simulate a full year's use in a heavy-duty-cycle environment, based on doing 16 probes on a delta to autocalibrate each print, and doing 10 prints per day for 46 weeks per year, 5 days a week. This is likely to represent 3+ years of use in a slightly more normal environment.
                    • Dougal1957undefined
                      Dougal1957
                      DJ think there is a typo and you mean 5 days a week and not 5 days a year
                      • DjDemonDundefined
                        DjDemonD
                        LOL fair enough edited. Also that didn't multiply up to 38000, it was 36800 probes (edited), I was doing that from memory. Its done 2000 already so another 34800 to do, surprisingly it only takes around 30 minutes to do 1000 probes. I'd leave it going all day whilst I'm at work but if the module fails I am not sure how the rig will deal with it, so I need to do them whilst I'm around and about.
                        • jmg123undefined
                          jmg123
                          @DjDemonD:
                          I'd be interested in a non groovemount one, I've been playing around with one of Moriquendi's boards on my reach 3d. Although it is groovemount, it mounts sideways onto a plate, so I reckon it is a good candidate for removing the grovemount. I'd just need to design some sort of interface to the captive nuts and my side plate.
                          My current setup is a bit bodged together (plate between the groovemount adapters, it does sort of work, but not as well as I'd like.
                          • ScotYundefined
                            ScotY
                            This sounds really cool, but almost one of those "if you ask how to make it work, you probably can't figure it out" type of things. I am quite interested in trying one of these sensors. While I do like the IR sensor a lot, it would be very nice to be able to use on any type of surface. Is it possible to mount this on a cartesian printer? My printer is quite small so if the hotend gets offset much, it will likely cause a loss of print area available.
                            • DjDemonDundefined
                              DjDemonD
                              Jmg123,
                              No problem whilst I haven't made a screw mounted one yet its not a problem. Please give me a shout in a week or two when we're ready to start sending some out and I'll make you one.
                              Just a question it might be the angle of the photo but what do you do with the inductive/capacitative sensor on its side? Or is it just stowed out of the way for now?
                              ScotY
                              Yes its possible to use it on any type of printer. The module sits below the carriage/effector and the hot end clamps into it.
                              Please let me know once they are released if you want one. I will post something here, and on reprap forum we will have a support/order thread.
                              • DjDemonDundefined
                                DjDemonD
                                And the module completed its 36800 probes without any issues, simulating a year of heavy duty cycle or three years of "normal" use.
                                • Ad-1undefined
                                  Ad-1
                                  I've been lurking around here for a while now.
                                  I'm with Moriquendi on lifting the nozzle close to the plane of the effector. So I took DjDemonDs 20mm piezo design and made an effector to use with Haydn's magnetic arms. Arm spacing is 64mm, goes with a 30mm fan and a Berd-Air like cooling pipe.
                                  The M3x25 bolts have no thread for the first 6mm at the base and that can make a good sliding zone. There is room for up to 5 but I think 3 will do.
                                  A second Bowden ( http://e3d-online.com/Mechanical/Bowden/Embedded-Bowden-Couplings-For-Plastic-1.75mm-Filament ) can be used to stop the PTFE tube from pulling sideways.
                                  I'm thinking to use it on the Kossel I'm building but that will take a while. Until then here is the link for .stl , .step and .f3d files.
                                  https://mega.nz/#F!z40QRazQ!5OobZxS4iGTfcdOhj_lC3w
                                  If you need them in any other format or modified in any way please ask
                                  Updated 22/04/2017 - Added a second Bowden and made some cosmetic modifications
                                  • ScotYundefined
                                    ScotY
                                    @DjDemonD:
                                    ScotY
                                    Thanks for the reply. I will definately get one if I can figure out how to mount it. I'm using an E3D Bowden setup. The mount for the E3D is the clamp type and then the mount screws to the x-carriage on the backside. I am assuming a custom mount will be required.
                                    Actually, my setup looks a little like jmg123's setup above. The back of the clamp mounts to the carriage. Then the front clamp goes on, then fan, etc.
                                    • DjDemonDundefined
                                      DjDemonD
                                      AD-1 that looks great. I've been meaning to try a raised hotend version like that but have been too busy. Let me know how it works out and if you have any issues tuning it.
                                      • Ad-1undefined
                                        Ad-1
                                        Presuming a drilled 20mm piezo works just as good as the 27mm one, it should be easy to tune following your instructions
                                        • DjDemonDundefined
                                          DjDemonD
                                          Yeah I've not had any issues with 20mm in fact the unit I am going to be selling as a complete drop in module uses 20mm discs. Its Idris' (and Mike's) circuitry that does the job so well, reacting to change in voltage means even very small (but rapid) rises generate useful triggers.
                                          It begs the question how small can we go? The smaller the piezo, the easier it is to incorporate it into any load bearing part of the printer which is compressed on nozzle contact.
                                          • whosrdaddyundefined
                                            whosrdaddy
                                            Awesome thread going on here!
                                            Are you guys aware of this board?
                                            http://wiki.seeedstudio.com/wiki/Grove-_Piezo_Vibration_Sensor
                                            Will test it once I get hold of 20mm discs (and could this be an alternative for Moriquendi's board?)
