    Connecting to Duet3 with Macbook
    Firmware installation
    691
    • meatfestundefined
      meatfest @A Former User
      @bearer also the diag led is dimly lit all the time, either with or without the erase pins connected...
        droftarts administrators @meatfest
        @meatfest said in Connecting to Duet3 with Macbook:
        That means that the firmware has been erased. It should flash once a second if firmware is running. Also note that the Bossa program doesn't work on Mac OS to flash Duet 3 (it does work with Duet 2) so use a Windows PC to flash the firmware.
        • meatfestundefined
          meatfest
          I switched to my Windows 10 machine for now, I just want to get it working. I will look at re flashing firmware.
          meatfestundefined 1 Reply Last reply Reply Quote 0
          • meatfestundefined
            meatfest @meatfest
            @meatfest still stuck. let me re-cap.
            I have Duet3D board.
            I am using Windows 10 (stopped using my Macbook Pro)
            I have installed Bossa and Sam-Ba
            I have updated the driver for USB and it shows Bossa Program Port (COM 9) in Device Manager.
            With Sam-ba I get message:
            Error h_handle returned zero
            while executing
            "TCL_Open $target(connection)" ....
            With Bossa I get the message:
            Could not connect to device on COM9
              @meatfest It sounds like something is still connected to the Duet on COM9. I'd suggest restarting your PC, then just use Bossa to flash the Duet.
              • meatfestundefined
                meatfest @droftarts
                @droftarts rebooted, same message from Bossa...
                  A Former User
                  While its possible there is a problem with the board, all the other instances has turned out to be issues with software or usb cables.
                  As such I think it could be worth while trying to build bossa from sources on the Mac and see if it makes a difference after applying a patch to the code.
                  Is cloning code with git and running make to build it something you're comfortable with on the Mac?
                  • Danalundefined
                    Danal
                    If you happen to have a Raspberry Pi, there are instructions on the Dozuki to set it up and try it. They are sometimes better at finding the bossa port. Sometimes.
                      dc42 administrators @meatfest
                      Which version of Bossa are you using?
                      • meatfestundefined
                        meatfest
                        Success!
                        In device manager I selected show hidden devices and found two instances of Bossa one was inactive the other active. I deleted both and reconnected and then when I selected the new com port I ran write and verify and all was well. It seemed that Windows held onto two com ports , one was hidden thus causing the problem. Something to bear in mind!
                        Phaedruxundefined 1 Reply Last reply Reply Quote 2
                          Phaedrux Moderator @meatfest
                          show hidden devices
                          Good tip.
                          • meatfestundefined
                            meatfest @Phaedrux
                            This post is deleted!
