    Inductive sensor as endstop
    • Headhunterundefined
      Headhunter
      i want to connect a LJ8A3-2-Z/AX (10-30VDC / 200mA) as Endstop for Extruder. How can i wire it, so it will work? Endstop gives out only 3.3v
      A Former User? gtj0undefined 2 Replies Last reply Reply Quote 0
        A Former User @Headhunter
        @Headhunter said in Inductive sensor as endstop:
        LJ8A3-2-Z/AX
        the *AX sensors are NPN type, meaning its output is essentially 0v. Wire the sensor supply to Vin (10-30v), Gnd to Gnd and output to endstop signal.
        • gtj0undefined
          gtj0 @Headhunter
          LJ8A3-2-Z/AX
          This should help you out...
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
