    Need help to make my IDEX printer work
    My Duet controlled machine
    433
    • Martin Simardundefined
      Martin Simard
      Hello!
      My name is Martin and i'm french newbie, so don't focus on my written english 😉
      I built my printer and i consider it to be the easy part! So, i try to make it work since 2 week, but nothing work. My understanding of G-code is really limited.
      So, I have a Duet 2 Ethernet with a Duex2 Expansion board, Paneldue and a BLTouch 3.1
      I used the configuration tool, but it's not really working for IDEX printer, so i followed the step of this page: https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian and i modified my G-Code.
      The problem i have is that the printer start, but i can't move any axis since they are not homed. When I push home, the Z axis move down a little bit and go back from where it came.
      I plug the BLtouch (White and Black on the duet2, and use the pwm3 from the duex2 for the other 3 cables.
      I also install a filament sensor that i plug in the duex2 pwm4 socket, but i don't know how to configure it...
      I share with you the actual G-code, but i will need a lot of help to make it work!
      G21 ;Work in millimetres
      M550 P"Imprimante IDEX" ; set printer name
      M552 P192.168.1.14 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.1.1 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes forwards X
      M569 P1 S1 ; physical drive 1 goes forwards Y
      M569 P2 S1 ; physical drive 2 goes forwards Z
      M569 P3 S1 ; physical drive 3 goes forwards U
      M569 P4 S0 ; physical drive 4 goes backwards E0
      M569 P5 S0 ; physical drive 5 goes backwards E1
      M584 X0 Y1 Z2 U3 E4:5 ; set drive mapping
      M350 X16 Y16 U16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E582.00:582.00 ; set steps per mm
      M566 X1200.00 Y700.00 U1200.00 Z24.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y9000.00 U15000 Z300.00 E2100.00:2100.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y500.00 U1500.00 Z400.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1800 U1200 Z1400 E900:900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-65 Y0 U30 Z0 S1 ; set axis minima
      M208 X355 Y380 U455 Z400 S0 ; set axis maxima
      M574 Y2 S0 P"ystop" ; configure active-low endstop for high end on Y via pin ystop
      M574 U2 S1 P"duex.e2stop" ; configure active-high endstop for low end on X via pin e2stop
      M950 S0 C"duex.e2heat" ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X23 Y-34 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X30:400 Y0:400 S30 ; define mesh grid
      M308 P1 R4700 H0 L0 ; Dyze design Hotend
      M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 R4700 H0 L0 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S493 ; set temperature limit for heater 1 to 400C
      M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
      M308 P2 R4700 H0 L0 ; Dyze Design Hotend
      M308 S2 P"e1temp" Y"thermistor" T4606017 B5848 R4700 H0 L0 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S493 ; set temperature limit for heater 2 to 400C
      M307 H2 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"duex.fan3" Q500 ; create fan 3 on pin duex.fan3 and set its frequency
      M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on
      M563 P0 S"Extrudeur Gauche" D0 H1 F0 ; define tool 0
      M563 P1 S"Extrudeur Droit" D1 H2 F1 ; define tool 1
      G10 P1 U30 Y0 Z0 ; set tool 1 axis offsets
      [0_1589030896787_Config MS.zip](Uploading 100%)
      I someone can tell me what is the problem, apart from my knowledge 😉
      Thanks
      homeall.g homeu.g homex.g homey.g homez.g
      • PaulHewundefined
        PaulHew
        @Martin-Simard said in Need help to make my IDEX printer work:
        I do not know much about IDEX, but I know about BLTouch.
        If you are using pwm3 for the BLTouch, I think your line in config.g needs to look like this.
        M950 S0 C"!duex.e4heat," ; create servo pin 0 for BLTouch
        Regards
        Paul
        Martin Simardundefined 1 Reply Last reply Reply Quote 0
          Martin Simard @PaulHew
          @PaulHew Thanks you! I change it in my config.g
          Do you always have to use the ''!'' to use before the duex.xxx??
          Because i also refer to a duex.e2stop command for my endstops and i will use pwm4 to install a filament sensor...
          Thanks
            Martin Simard
            I always have this pop-up: Fail to enable endstops
            See the pop-up here: http://martinsimard.net/photo/share/WmJWd0Qj/photo_496d7072696d616e7465_6572725f656e6473746f702e6a7067
            All the endstop works when i push the switches, the red light show up on the duet2 and duex2
            PaulHewundefined 1 Reply Last reply Reply Quote 0
            • PaulHewundefined
              PaulHew @Martin Simard
              @Martin-Simard Bien Sur.
              From what I understand, I might be wrong, anything to do with a Duex needs inverting.
              I was playing with lights connected to the duex5 and I found that I had to use the '!' to get them to work correctly. I have seen a lot of posts in regards to Duex and the !
              This page is helpful on your DWC.
              The box on the right, labelled 'Endstops' is a good way of making sure your endstops are working.
              If the axis's are away from the switches, they should be 'No', on my Ender3 this is.
              If you press the switch it should change to yes to indicate that the switch is pressed, same as if you were homing an axis.
              If they are 'Yes' and you press a switch and it goes to 'No' you need to reverse the logic. "!"
              The printer will not 'Home' an axis if they are 'Yes' and will move a short distance only without homing.
              Regards,
              Paul.
              • PaulHewundefined
                PaulHew
                Try it like this.
                M574 U2 S1 P"!duex.e2stop" ; configure active-high endstop for low end on X via pin e2stop
                Paul.
                  Martin Simard
                  Thank you Paul, your help is appreciated!
                  I found that it was the U endstop on my duex that was always ON. So I tryed with the ''!'' before, it was now OFF. But the trigger didn't work anymore. So I try with ''^'' The Endstop, when i push it change from No to Yes, but stay there. I tryed with ''^!'' but didn't work.... Finally plug my endstop to Extruder 0 of the main Duet2 and everything work.
                  I think that on the Firmware 2.X, you could do it like that: M574 S0 P''^duex.e2stop'' ; ''S0'' to invert the signal and ''^'' for pullup resistor
                  In firmware 3.X, the S0 Command is no more supported, so maybe you cannont combine pullup and invert anymore.... don't know
                  So my working code is: M574 U2 S1 P"!e0stop"
                  Have a nice day!
                  Martin
                  PaulHewundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • PaulHewundefined
                    @Martin-Simard Glad you got it working.
                    Have you printed anything yet?
                      Phaedrux Moderator @Martin Simard
                      Pullup + invert is supported, so that should work.
