    Issues with stealthchop2
    428
    • maroondsundefined
      maroonds
      Hi! I'm trying to set my drivers to stealthchop2, but somehow it always brings me to spreadcycle.
      M569 P0 S1 D3
      Am I doing something wrong?
      Any help is greatly appreciated.
      • danym21undefined
        danym21
        I have the same problem, and not found a solution yet:
        https://forum.duet3d.com/topic/16297/help-needed-with-duet-3-6hc-tmc5160-stealthchop-config
        can you try
        M569 P0 S1 D3 V34
        this should be changed the "tpwmthrs" as example on a 0.9deg Motors with 16Steps and 200 steps per mm to 110.3 mm/sec.
        this means all speeds under 110mm/sec should be in stealthchop mode and all above in spreadcyle.
        default I think is V100 and this is also verry slow depence on the step per mm I think.
        • maroondsundefined
          maroonds
          @danym21 said in Issues with stealthchop2:
          a solution yet:
          worked, thanks! How can I calculate the V parameter?
          • danym21undefined
            danym21
            this I do not know but when you call now M569 P0 as example it shows you the mm/s tpwmthrs 34 (110.3 mm/sec)
            decrease means sitch to spreadcycle on higher speed.
            which firmware version do you use?
            I still not understand why it is not working on my setup, can you give me your complete config please so maybe I can find my problem too.
            • maroondsundefined
              maroonds
              M569 P0
              Awesome, thanks!
              M569 P0
              Drive 0 runs forwards, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 85 (110.3 mm/sec)
              Isn't this supposed to say stealthchop?
              • danym21undefined
                danym21
                @maroonds said in Issues with stealthchop2:
                yes up to 110mm/sec all above (maybe travel with 120mm/sec) should be in spreadcycle.
                can you post you complete config please? maybe I can find my issue too.
                is your machine quiete now on normaly speeds like a move with F1800?
                • maroondsundefined
                  maroonds
                  tpwmthrs
                  It's sort of quite. Not as quite as my creality Ender 3 silent board, but hard to hear at slow moves.
                  Here's my config:
                  ; Configuration file for Duet Maestro (firmware version 2.03)
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 22 2020 01:05:56 GMT+0200 (Mitteleuropäische Sommerzeit)
                  M550 P"My Printer" ; set printer name
                  M552 P192.168.1.69 S1 ; enable network and set IP address
                  M553 P255.255.255.0 ; set netmask
                  M554 P192.168.1.254 ; set gateway
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S1 ; enable FTP
                  M586 P2 S0 ; disable Telnet
                  M552 S1 P192.168.8.101
                  M569 P0 S1 D3 v85 ; physical drive 0 goes backwards X
                  M569 P1 S1 D3 v85 ; physical drive 1 goes backwards Y
                  M569 P2 S0 D3 v34 ; physical drive 2 goes forwards Z
                  M569 P3 S1 D3 v34 ; physical drive 3 goes forwards E
                  M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation
                  M92 X160.00 Y160.00 Z800.00 E708.00 ; set steps per mm
                  M566 X420.00 Y420.00 Z24.00 E180.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X24000.00 Y24000.00 Z720.00 E7200.00 ; set maximum speeds (mm/min)
                  M201 X2000.00 Y2000.00 Z1000.00 E5000.00 ; set accelerations (mm/s^2)
                  M906 X850 Y850 Z850 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M204 P1000 T2000 ; Set printing and travel accelerations
                  M572 D0 S0.03 ; Pa
                  M208 X-5 Y-5 Z-5 S1 ; set axis minima
                  M208 X235 Y230 Z260 S0 ; set axis maxima
                  M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X49 Y23 Z2.08 ; set Z probe trigger value, offset and trigger height
                  M557 X10:210 Y10:210 S20 ; define mesh grid
                  M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
                  M305 P1 T100000 B4725 C7.060000e-8 R2200 ; set thermistor + ADC parameters for heater 1
                  M143 H1 S300 ; set temperature limit for heater 1 to 280C
                  M307 H2 A-1 C-1 D-1 ; Disables H2
                  M106 P0 A22 H-1 S0 F150 X175 ; Part cooling fan
                  M106 P2 A2 H1 T45 ; Hotend fan
                  M911 S23 R23.7 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  • danym21undefined
                    danym21
                    Duet Maestro
                    you have a Duet Maestro with Firmware 2.03?
                    have you tried the new Firmware 3.0RC12,
                    does this makes a difference for you?
                    • maroondsundefined
                      maroonds
                      I tried RR3.0 when it officially came out and it didn't really make a difference.
                      This is my current setup:
                      Board: Duet Maestro 1.0 (duetmaestro100)
                      Firmware: RepRapFirmware for Duet 2 Maestro 2.05.1 (2020-02-09b1)
