    How to build the bin file?
    Firmware developers
    968
    • Jimmykcundefined
      Jimmykc @dc42
      I right click on the project and select build configuration -> Set Active -> Duet3_V06_CAN0.
      I build it, but I fail.
      log.txt
        The versions of the CoreNG and RepRapFirmware projects you are using are slightly mismatched. Try updating both of them.
        Jimmykcundefined 1 Reply Last reply Reply Quote 0
        • Jimmykcundefined
          Jimmykc @dc42
          @dc42 I update CoreNG and RepRapFirmware projects. The previous problem has be fixed but show a new error.
          log2.txt
          I re-build the project again, and the error will not appear.
            You can find crc32appender.exe under the Tools folder of the RepRapFirmware repository. Copy it on to your PC and add it to the PATH.
            • Jimmykcundefined
              Jimmykc @dc42
              @dc42 I paste the crc32appender.exe on my path.
              I fixed all problems. Thank you, but I have the last question.
              Is the bin file for main board if I select build configuration -> Set Active -> Duet3_V06?
              Is the bin file for expansion board if I select build configuration -> Set Active -> Duet3_V06_CAN0 ?
                The _CAN0 one is just a test configuration so that we can test the second CAN port, which the standard firmware doesn't use. Use the Duet3_V06 configuration.
                To build expansion board firmware, import project Duet3Expansion into your workspace and build that project.
                • Jimmykcundefined
                  Jimmykc @dc42
                  @dc42 Now I know how to build the bin file. Thanks you so much.
                  • arhiundefined
                    arhi
                    @dc42 this still stands for RRF3.1 ?
                    to build firmware version 2.03beta3 and later use version 2018-q4-major
                    or you moved to 2020 version maybe?
                      For 3.1.1 I used version 9-2019q4-major. But I see that 9-2020-q2-update is now available, so I'll probably switch to that for 3.2.
                      arhiundefined 1 Reply Last reply Reply Quote 1
                      • arhiundefined
                        arhi @dc42
                        @dc42 nice, I recompiled it on mac, was faster to get everything up and running without messing out working envinronments for other stuff on my main win desktop and compiling is fast enough that the speed of the mac is not that important πŸ˜„ .. brew is a nice addon to osx πŸ™‚ .. brew installs (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599] so exactly what you say you are using for 3.1.1 and the issue is only with src/GCodes/GCodeBuffer/ExpressionParser.cpp the conv.Accumulate is called with wrong number of parameters .. probbly ReprapFirmware:v3-dev vs RRFLibraries:dev at point I was doing a clone were out of sync (I see that whole section is new) ... I just needed to do the quick read of the ADC so I removed that whole section and compiled without a problem πŸ˜„ .. got data I needed I returned release 3.1.1. πŸ™‚ ..
                        I moved to 2020 myself for few projects and so far did not notice any issues
