    Brand new Duet Maestro does not start/is inaccessible
    418
    • yonutz33undefined
      yonutz33
      I recently got a brand new Duet Maestro board from a local reseller. I wired it to my Sapphire PRO 3D printer (CoreXY) by following and adapting where necessary the Ender 3 guide (https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37?lang=en). I have hooked up a 12864 Full Graphic display.
      I have no idea why but it won't boot up properly (attached is a photo duet not working.jpg
      I have also looked in my router assigned IP's but it won't show up on the network (activity led seems to be blinking).
      Does anybody have any ideea what i'm doing wrong? I will provide any additional info promptly ...
      Could it be that i recieved a broken board?
      Thanks in advance,
      Peter
      ixlixundefined 1 Reply Last reply Reply Quote 0
        A Former User
        Part 2 covers populating the SD card with the necessary files and how to connect via usb to set up networking?
        • Vetiundefined
          Veti
          the duet maestro does not come with a default menu for the lcd
          you will have to do that yourself or use an existing one like
          https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files
          also do you have the config line to activate the display like
          M918 P1 E4 F2000000 ; configure direct-connect display
          in your config?
          yonutz33undefined 1 Reply Last reply Reply Quote 0
          • yonutz33undefined
            yonutz33 @Veti
            @Veti Thank you, i copied the files
            @bearer thanks, i thought it should have worked, but after i followed part 2 I realized what i had skipped
              I've added a note on the LCD wiring step mentioning that configuration is detailed later.
              • ixlixundefined
                ixlix @yonutz33
                @yonutz33
                DId you reverse the connectors like in that guide for the Ender 3?
                  dc42 administrators @ixlix
                  @ixlix said in Brand new Duet Maestro does not start/is inaccessible:
                  @yonutz33
                  That shouldn't be necessary, because the LCD is a RepRapDiscount one or a clone.
                  • Have you tried adjusting the contrast pot?
                  • See @Veti 's post about enabling the display using M918. Even without menu files, you should get a message on the display if you enable the display using M918.
                  • yonutz33undefined
                    yonutz33
                    Thank you, it was solved with your previous answers. I needed to enable it through M918 and copy the menu files.
