Blown driver
Drivers have that heat sink pad across their entire bottom... not what I'd recommend for someone's very first attempt at chip replacement, with so-so tools.
Of coursd, @Via it is your choice, if you are comfortable trying, go for it. At the same time, recognize that the board can be damaged in the attempt.
@bearer said in Blown driver:
TMC2660-PA
TMC2660-PA does not have a thermal pad which is why its possible to remove it without hot air. (and if the option is not repairing it no big deal)
@Via said in Blown driver:
Duet 2 WiFi
You might be able to get some low temp solder (like quick chip (138C)) to remove the blown driver without needing a hot air station, but you'd want to pre-heat the whole board in any case (another printer with a 100+C hot bed maybe?). But yeah, the parts aren't free and quick chip adds up; the Duet3 also comes at a premium though.
Just been doing the numbers on this myself. -
Getting "Driver 0 short to ground" after stupidly plugging a motor in without shutting off the power first.
The driver itself is cheap, but the associated bits add up.
Still, a new board is about five times that cost here is Oz, so I figure it's worth a shot. -
@OwenD said in Blown driver:
ChipQuick stuff is pricey, but you can get generic Bi58Sn42 solder or paste for a fraction of the price, same with solder wick. Shouldn't need two sizes for this job, I use 2mm for 95% as its a good fit for the medium tip I use for wicking. I wouln't skimp on the flux and solder though, and due to the 2oz copper thickness preheating the board is essential.
The most common reason for a driver to fail is that the stepper motor wires haven't been phased correctly.
@dc42 said in Blown driver:
@dc42 I know there is a limit on how far you can productively "read backward" in a thread. In this case, the OP stated it was a wiring fault, connector plugged in "one pin off". So you are spot on, wiring, and the OP knows how to prevent it in the future.
Could that be made less fatal if turning the current right down to the minimum allowable until wiring is sorted out? But if you can't get a positive test without risking a failure then moot point i guess.
Would that cause the driver to fail with a short to ground error?
It so, it would help explain how it happened.
I was changing an extruder and plugged the wrong motor into the X axis initially. The extruder I was replacing uses a different motor type.
When I got the short to ground error I assumed I must have forgot to shut down before I plugged a motor in, even though I was โsureโ I had. -
I do have hot air station but only used to replace mosfets so I'm 50/50 if I will attempt to replace or just leave how is... in old printer (once I replace Z steppers).
Duet3 in the post for new one
If you have hot air and a 2nd printer whose hotbed you can use to preheat the board it shouldn't be too bad. The Z driver is a little extra tricky with less physical clearance around the chip, still possible to shield the surrounding parts but a vacuum pickup helps a lot to pick up the bust driver. On the other hand if you can re-purpose it as is then enjoy the Duet3:)
