RRF3.01-RC12 Not Loading Config-Override.g on startup?
Beta Firmware
920
    KeeganB
    I just finishing re-doing my config.g to move my SeeMeCNC Orion (delta) over to RRF3.
    After finishing the config.g, I can set my z=0, run through a few G32's, get a good calibration, and then persist in via M500.
    The config-override.g is created and every time I G32 and then M500, the values are properly updated.
    All works fine after that, UNTIL... I reboot the machine.
    It doesn't seem to be loading the values from the override file on startup. It sets the Z height to the value from my M665 in config.g. so when I home it, it adds the z distance it travels to get home to the starting Z value from config.g so I end up with a Z height value when homed that is too high (usually about 15mm as that is the distance I drop the carriages at the end of my home-delta.g file.)
    I DO have an M501 at the end of my config.g. The only line after that is "T0"
    Thanks!
    Artemis
    Rostock Max v2
    Orion
      OwenD
      You're probably going to need to post your config.g, bed.g and config-overide.g files to get the answer, but I suggest you check out the M500 command parameters
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
      You probably need to use something like M500 P10:31
        KeeganB
        I'm happy to post my config, bed, override, and etc files.
        I highly doubt my M500 parameters are an issue. As I said, after running M500 the override is updated properly.
        Artemis
        Rostock Max v2
        Orion
          KeeganB
          bed.g:
          Orion
          Send code...
          Status
          Idle
          Mode: FFF
          Tool Position
          X
          -0.3
          Y
          0.0
          Z
          229.79
          Extruder Drives
          Drive 0
          0.0
          Speeds
          Requested Speed
          0 mm/s
          Top Speed
          0 mm/s
          Sensors
          Vin
          11.9 V
          MCU Temperature
          30.2 C
          Z-Probe
          0
          Tools
          Extra
          Control All
          Tool Heater Current Active Standby
          Hot End
          T0 - Load Filament Heater 1
          active 24.2 C
          0
          0
          Bed Heater 0
          off 24.7 C
          0
          0
          Temperature Chart
          System Directory
          0:/sys/bed.g
          ; bed.g
          ; called to perform automatic delta calibration via G32
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Mar 31 2020 14:38:51 GMT-0400 (EDT)
          ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
          ; 10 points, 6 factors, probing radius: 65, probe offset (0, 0)
          G30 P0 X0.00 Y65.00 Z-99999 H0
          G30 P1 X56.29 Y32.50 Z-99999 H0
          G30 P2 X56.29 Y-32.50 Z-99999 H0
          G30 P3 X0.00 Y-65.00 Z-99999 H0
          G30 P4 X-56.29 Y-32.50 Z-99999 H0
          G30 P5 X-56.29 Y32.50 Z-99999 H0
          G30 P6 X0.00 Y32.50 Z-99999 H0
          G30 P7 X28.15 Y-16.25 Z-99999 H0
          G30 P8 X-28.15 Y-16.25 Z-99999 H0
          G30 P9 X0 Y0 Z-99999 S6
          ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
          ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
          homedelta.g:
          ; homedelta.g
          ; called to home all towers on a delta printer
          G91 ; relative positioning
          G1 H1 X290 Y290 Z290 F1800 ; move all towers to the high end stopping at the endstops (first pass)
          G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
          G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
          G1 H2 X-15 Y-15 Z-15 F1800 ; move down a few mm so that the nozzle can be centred
          G90 ; absolute positioning
          Artemis
          Rostock Max v2
          Orion
            KeeganB
            config.g
            M550 P"Orion" ; set printer name
            M665 R88.512 L178 B85 H230 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M552 S1 ; enable network
            ;M552 S2 ; enable AP Mode network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M92 X80.00 Y80.00 Z80.00 E93.30 ; set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E2100.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X20000.00 Y20000.00 Z20000.00 E3600.00 ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E3000.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 Z0 S1 ; set minimum Z
            M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
            M558 P5 C"e0stop" H15 F500 T6000 ; set Z probe type to switch and the dive height + speeds
            G31 P500 X0 Y0 Z-0.32 ; set Z probe trigger value, offset and trigger height
            M557 R75 S20 ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
            M570 H0 S360 P180
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M950 F0 C"fan0" ;Q500 ; create fan 0 on pin fan0 and set its frequency
            M950 F1 C"fan1" ;Q500 ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
            M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
            T0 ; select first tool
            config-override.g:
            ; config-override.g file generated in response to M500 at 2020-05-13 16:54
            ; Delta parameters
            M665 L178.000:178.000:178.000 R88.538 H229.532 B85.0 X-0.062 Y0.097 Z0.000
            M666 X-0.141 Y0.567 Z-0.426 A0.00 B0.00
            ; Heater model parameters
            M307 H0 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            ; Workplace coordinates
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
            Artemis
            Rostock Max v2
            Orion
            undefined 1 Reply Last reply 13 May 2020, 22:14 Reply Quote 0
              droftarts administrators @KeeganB
              @KeeganB Try sending M98 P"config.g" and see if you get any errors. Not sure of the effect of those '{1}' lines at the end of the config.g.
              undefined 2 Replies Last reply 13 May 2020, 22:20 Reply Quote 0
                KeeganB @droftarts
                @droftarts said in RRF3.01-RC12 Not Loading Config-Override.g on startup?:
                Interesting. Those {1} values don’t show up in the dwc editor. They only appeared when I copied and pasted. I wonder if that’s the issue.
                I’ll try pasting to a text editor, cleaning those up, and then saving a new config.
                Artemis
                Rostock Max v2
                Orion
                  KeeganB @droftarts
                  @droftarts
                  Nope, i don't think that is it. I pasted it in BBEdit, and it looks clean. I think the form code snippet tool added those {1}'s.
                  Artemis
                  Rostock Max v2
                  Orion
                  undefined 1 Reply Last reply 14 May 2020, 03:31 Reply Quote 0
                    Phaedrux Moderator @KeeganB
                    @KeeganB said in RRF3.01-RC12 Not Loading Config-Override.g on startup?:
                    Yes I think you're right.
                      KeeganB
                      Bump, any other ideas?
                      Artemis
                      Rostock Max v2
                      Orion
                        If you manually send M501 does it get executed?
                        undefined 1 Reply Last reply 15 May 2020, 18:22 Reply Quote 0
                          zerspaner_gerd
                          I think the problem is the same!
                          This variant, M500 P31, helped me
                          Before that, I also used a simple M500
                          Had posted it here before
                          https://forum.duet3d.com/topic/15317/reprapfirmware-3-01-rc6-released/147?_=1589506715771
                          Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                            To clarify:
                            • M500 without the P31 parameter will always save the M665 and M666 parameters to config-override.g.g. I have just verified that this is still the case. It will also save the G31 parameters to config-override.g if a G31 command was read from config-override.g when the Duet was started.
                            • If you add the P31 parameter then M500 will unconditionally include a G31 line in config-override.g.
                            From your description, you should not need to use M500 P31. You would only need to so that if you have changed the G31 parameters, e.g. the trigger height (Z parameter).
                            undefined 1 Reply Last reply 15 May 2020, 18:21 Reply Quote 0
                              KeeganB @dc42
                              @dc42 Thanks David. That is how I understood it as well. So what am I missing?
                              Artemis
                              Rostock Max v2
                              Orion
                                KeeganB @Phaedrux
                                @Phaedrux Yes. If i boot up the machine from powered off and send M501 as the first thing I do, it loads the values from the override files and you can see the Z value change.
                                Artemis
                                Rostock Max v2
                                Orion
                                  KeeganB
                                  SOLVED:
                                  I had my end stops configured as active-low rather than active high. DOH.
                                  For others following this that may learn from it, here is my incorrect code:
                                  HERE IS THE CORRECT CODE:
                                  M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
                                  M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
                                  M574 Z2 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                                  Artemis
                                  Rostock Max v2
                                  Orion
                                  dc42undefined 1 Reply Last reply 16 May 2020, 08:50 Reply Quote 0
                                    dc42 administrators @KeeganB
                                    I think you mean you had them configured as low-end (axis minimum) endstops instead of high end (axis maximum) endstops.
                                    5 out of 17
