Random disconnects DuetWifi 3.01 RC12
Okay, thank you.
Is there anything else that could potentially be the problem, as I'd only like to start desoldering parts from the board as a last option or is the wifi chip the most likely cause?
Well we've ruled out the firmware, and your signal strength is good, you've tried another router.
Unless there is some other source of interference in the area you can identify and eliminate.
You could try switching to another wifi channel.
You can try and provide an M122 from when it's disconnected.
Trying multiple different wifi channels didn't seem to have any effect on it.
This is my results from M122 after it disconnects
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC12 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-956GU-DJMSN-6J1DL-3SN6M-TTNRF
Used output buffers: 3 of 24 (8 max)
Static ram: 28084
Dynamic ram: 94064 of which 20 recycled
Exception stack ram used: 600
Never used ram: 8304
Tasks: NETWORK(ready,804) HEAT(blocked,1228) DUEX(blocked,160) MAIN(running,1820) IDLE(ready,76)
Owned mutexes: I2C(DUEX)
Last reset 00:02:19 ago, cause: power up
Last software reset at 2020-05-13 22:26, reason: Stuck in spin loop, spinning module Move, available RAM 8240 bytes (slot 2)
Software reset code 0x4084 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20004344 Task IDLE
Stack: 004549dd 00455412 61000000 a5a5a5a5 004549dd a5a5a5a5 a5a5a5a5 2000436c 2000425c 00000002 20005194
Error status: 0
MCU temperature: min 24.1, current 31.2, max 31.5
Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Driver 9: standstill, SG min/max 0/0
Date/time: 2020-05-14 15:23:48
Cache data hit count 241975993
Slowest loop: 25.44ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.9ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 17823ms
=== MainDDARing ===
Scheduled moves: 16, completed moves: 16, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 31624.06ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address 5c:cf:7f:76:68:e0
WiFi Vcc 3.42, reset reason Unknown
WiFi flash size 4194304, free heap 24696
WiFi IP address 192.168.1.101
WiFi signal strength -34dBm, reconnections 0, sleep mode modem
Socket states: 4 0 0 0 0 0 0 0
=== DueX ===
Read count 19153, 8254.12 reads/min
- WiFi -
Was that while disconnected or after reconnection?
That was after it had reconnected. Is it possible to get a readout while it’s disconnected?
@mike5490 said in Random disconnects DuetWifi 3.01 RC12:
Yes, via USB.
I tried to get a M122 while it's disconnected but have been unable to
Every time it disconnects the USB connection to my computer also disconnects, similar to as if I was unplugging the USB cable
After a bit more troubleshooting I've determined that the printer behaves as if I sent a M999 command but it occurs at random times
this always happen when the board is reset.
running
M122
first thing after connecting to the board again would be helpful. is there anything that could short against the reset pins or trigger the reset switch on the board? pictures andM122
might provide some insight. -
The results from M122 immediately after it reconnects are provided above in a previous post. There's nothing that could be pressing against the reset button.
This is how the board is currently wired
Please upgrade to 3.1.0 release firmware and if the problem continues, post another M122 report taken immediately after it reconnects.
The ground wire between your Duet and DueX5 isn't done according to our wiring instructions. This might be part of the problem, OTOH the wires between them and the DueX5 are short, which will help to mitigate the incorrect wiring.
as in
Unless the firmware is wrong it would suggest you had a power glitch? In any case, what he said
Thank you for pointing out the wiring issue. Unfortunately after fixing that and upgrading to firmware 3.1.0 I am still having the same problem.
This is my M122 immediately after the printer reconnects.
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet WiFi 1.02 or later + DueX5
Used output buffers: 3 of 24 (12 max)
Static ram: 28180
Dynamic ram: 94088 of which 60 recycled
Exception stack ram used: 264
Never used ram: 8480
Tasks: NETWORK(ready,36) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:10 ago, cause: software
Last software reset at 2020-05-18 14:22, reason: Stuck in spin loop, spinning module Move, available RAM 8080 bytes (slot 1)
Software reset code 0x4084 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200043ac Task IDLE
Stack: 00454afd 00455530 61000000 a5a5a5a5 00454afd a5a5a5a5 200043d0 200042c0 00000002 200051f4 0000be35
Error status: 0
MCU temperature: min 29.5, current 30.9, max 31.1
Supply voltage: min 24.3, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-05-18 14:22:39
Cache data hit count 15987603
Slowest loop: 2.94ms; fastest: 0.13ms
=== Storage ===
SD card longest read time 1.5ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 15.67ms; fastest: 0.00ms
WiFi Vcc 3.41, reset reason Unknown
WiFi flash size 4194304, free heap 25200
WiFi signal strength -38dBm, reconnections 0, sleep mode modem
=== DueX ===
Read count 1, 5.62 reads/min
- WiFi -
@mike5490 Can you please share your config.g? How can you reproduce it? If it happens while printing a certain file or while running a certain macro, please share that, too.
I don't know how to reproduce the problem as it's intermittent and I haven't been able to find a cause yet. I haven't bothered to run any macros or prints yet as I'm trying to get the printer working correctly first.
Here's my current config.g file
Please try again with the 3.1.1 release, which we hope to make available later today.
@dc42 I installed the internal build for 3.1.1 -18b8 last night and am still having the same disconnect problems.
Please try the official 3.1.1 release.
I installed the official 3.1.1 and am still having the same issues.
This is my results from M122 immediately after the board reconnects
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
Static ram: 27980
Dynamic ram: 94488 of which 60 recycled
Never used ram: 8280
Tasks: NETWORK(ready,384) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
Last reset 00:00:13 ago, cause: software
Last software reset at 2020-05-20 10:19, reason: Stuck in spin loop, spinning module Move, available RAM 7880 bytes (slot 2)
Software reset code 0x4084 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200042e4 Task IDLE
Stack: 00454cdd 0045570c 61000000 a5a5a5a5 00454cdd a5a5a5a5 20004308 200041f8 00000002 2000512c 00004be2
Error status: 0
MCU temperature: min 31.3, current 32.4, max 33.3
Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-05-20 10:19:45
Cache data hit count 21289392
Slowest loop: 3.01ms; fastest: 0.13ms
=== Storage ===
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 15.62ms; fastest: 0.00ms
WiFi signal strength -43dBm, reconnections 0, sleep mode modem
=== DueX ===
Read count 1, 4.47 reads/min
- WiFi -
After updating to the official 3.1.1 it seems to disconnect less randomly and seems to occur most often after an endstop is triggered while homing.
