    Random disconnects DuetWifi 3.01 RC12
    Beta Firmware
    9
    50
    2.0k
    • mike5490undefined
      mike5490
      I tried to get a M122 while it's disconnected but have been unable to
      Every time it disconnects the USB connection to my computer also disconnects, similar to as if I was unplugging the USB cable
      • mike5490undefined
        mike5490
        After a bit more troubleshooting I've determined that the printer behaves as if I sent a M999 command but it occurs at random times
          A Former User @mike5490
          @mike5490 said in Random disconnects DuetWifi 3.01 RC12:
          this always happen when the board is reset.
          running M122 first thing after connecting to the board again would be helpful. is there anything that could short against the reset pins or trigger the reset switch on the board? pictures and M122 might provide some insight.
          • mike5490undefined
            mike5490
            The results from M122 immediately after it reconnects are provided above in a previous post. There's nothing that could be pressing against the reset button.
            This is how the board is currently wired
              Please upgrade to 3.1.0 release firmware and if the problem continues, post another M122 report taken immediately after it reconnects.
              The ground wire between your Duet and DueX5 isn't done according to our wiring instructions. This might be part of the problem, OTOH the wires between them and the DueX5 are short, which will help to mitigate the incorrect wiring.
                as in
                Last reset 00:02:19 ago, cause: power up
                Unless the firmware is wrong it would suggest you had a power glitch? In any case, what he said ☝
                • mike5490undefined
                  mike5490
                  Thank you for pointing out the wiring issue. Unfortunately after fixing that and upgrading to firmware 3.1.0 I am still having the same problem.
                  This is my M122 immediately after the printer reconnects.
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-956GU-DJMSN-6J1DL-3SN6M-TTNRF
                  Used output buffers: 3 of 24 (12 max)
                  Static ram: 28180
                  Dynamic ram: 94088 of which 60 recycled
                  Exception stack ram used: 264
                  Never used ram: 8480
                  Tasks: NETWORK(ready,36) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:00:10 ago, cause: software
                  Last software reset at 2020-05-18 14:22, reason: Stuck in spin loop, spinning module Move, available RAM 8080 bytes (slot 1)
                  Software reset code 0x4084 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200043ac Task IDLE
                  Stack: 00454afd 00455530 61000000 a5a5a5a5 00454afd a5a5a5a5 200043d0 200042c0 00000002 200051f4 0000be35
                  Error status: 0
                  MCU temperature: min 29.5, current 30.9, max 31.1
                  Supply voltage: min 24.3, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 5: standstill, SG min/max not available
                  Driver 6: standstill, SG min/max not available
                  Driver 7: standstill, SG min/max not available
                  Date/time: 2020-05-18 14:22:39
                  Cache data hit count 15987603
                  Slowest loop: 2.94ms; fastest: 0.13ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 1.5ms, write time 0.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 15.67ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address 5c:cf:7f:76:68:e0
                    WiFi Vcc 3.41, reset reason Unknown
                    WiFi flash size 4194304, free heap 25200
                    WiFi IP address 192.168.1.101
                    WiFi signal strength -38dBm, reconnections 0, sleep mode modem
                    === DueX ===
                    Read count 1, 5.62 reads/min
                  • chrishammundefined
                    chrishamm administrators @mike5490
                    @mike5490 Can you please share your config.g? How can you reproduce it? If it happens while printing a certain file or while running a certain macro, please share that, too.
                    Duet software engineer
                    • mike5490undefined
                      mike5490
                      I don't know how to reproduce the problem as it's intermittent and I haven't been able to find a cause yet. I haven't bothered to run any macros or prints yet as I'm trying to get the printer working correctly first.
                      Here's my current config.g file
                      config.g
                        dc42 administrators @mike5490
                        config.g
                        Please try again with the 3.1.1 release, which we hope to make available later today.
                        • mike5490undefined
                          mike5490
                          @dc42 I installed the internal build for 3.1.1 -18b8 last night and am still having the same disconnect problems.
                            Please try the official 3.1.1 release.
                            • mike5490undefined
                              mike5490
                              I installed the official 3.1.1 and am still having the same issues.
                              This is my results from M122 immediately after the board reconnects
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                              Static ram: 27980
                              Dynamic ram: 94488 of which 60 recycled
                              Never used ram: 8280
                              Tasks: NETWORK(ready,384) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
                              Last reset 00:00:13 ago, cause: software
                              Last software reset at 2020-05-20 10:19, reason: Stuck in spin loop, spinning module Move, available RAM 7880 bytes (slot 2)
                              Software reset code 0x4084 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200042e4 Task IDLE
                              Stack: 00454cdd 0045570c 61000000 a5a5a5a5 00454cdd a5a5a5a5 20004308 200041f8 00000002 2000512c 00004be2
                              Error status: 0
                              MCU temperature: min 31.3, current 32.4, max 33.3
                              Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                              Date/time: 2020-05-20 10:19:45
                              Cache data hit count 21289392
                              Slowest loop: 3.01ms; fastest: 0.13ms
                              === Storage ===
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              === Network ===
                              Slowest loop: 15.62ms; fastest: 0.00ms
                              • WiFi -
                                WiFi Vcc 3.42, reset reason Unknown
                                WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                                === DueX ===
                                Read count 1, 4.47 reads/min
                              • mike5490undefined
                                mike5490
                                After updating to the official 3.1.1 it seems to disconnect less randomly and seems to occur most often after an endstop is triggered while homing.
                                • Chrissundefined
                                  Chriss
                                  Oh, I thought that I'm the only one with that problem.
                                  I saw the same problem with 3.01-RC12 and it still exists with 3.1.1. With 3 or 4 browsers. (router and printer in the same room, 4 meter distance)
                                  It happens often enough that I see it when I edit a file frequently.
                                  I think that I will capture the traffic with wireshark, to see who is not answering.
                                  Cheers, Chriss
                                  mike5490undefined 1 Reply Last reply Reply Quote 0
                                  • mike5490undefined
                                    mike5490 @Chriss
                                    @Chriss any luck with determining what could be causing your disconnect issues?
                                    I still haven't been able to find a solution for mine
                                    Chrissundefined 1 Reply Last reply Reply Quote 0
                                    • Chrissundefined
                                      Chriss @mike5490
                                      Unfortunately not, but it seems to me that the problem is "gone with the wind". I had some trouble with my workstation in a complete other context. So I rebooted the workstation and the router which is my access point too. It seems that the problem is gone now, but I still keep a tcpdump in the background running to have some data when the problem comes back.
                                      As a idea: I would try to trace the actual component/source of the problem first. I do not know how you are "wired" to the duet. I have Workstation, connected via wire to a switch(a), which is connected to a switch(2). This switch(2) is connected to a WiFi bridge (aka AVM Fritz! Box) which is a router too. But I do not use it as a router, it is a bridge to WiFi for me only.
                                      So my idea was to get rid of all the complexity fist. So I would connect a other device (laptop) to WiFi, make sure that the WiFi signal is very good, and test from the laptop first. Just to make sure that no active or passive component in the middle is the root of the problem.
                                      That would be my approach to trace the "failing" component, I hope that gave you a idea.
                                      This topic is not death to me, but I have to many variables at the moment. The reboot of the router and the workstation was not a very good idea. 😞
                                      Cheers, Chriss
                                      • Chrissundefined
                                        Chriss @Chriss
                                        @mike5490
                                        I'm a step closer to the root of that issue. It seems that I have a "block" somewhere in my kernel. There are a couple of reports that the X-Windows system and the linux kernel have some problem with internal blocks of processes when the system runs low in memory. I have that problem at the moment with 100% memory usage plus 13GB swap. The CPU load is around 10-12. On a Threadripper with 24cores and 2 threads per core.
                                        You may to make sure that you do not have a problem with your host. :?
                                        Cheers, Chriss
                                        • Chrissundefined
                                          Chriss @Chriss
                                          Update: I restarted the bloody Firefox (Beta), that gave the Chromium enough resources to communicate properly with the Duet.
                                          This modern browsers open a lot of tcp connections and keep them open for a very long time. You may like to test if you have that problem with a fresh started workstation.
                                          Cheers, Chriss
                                          • mike5490undefined
                                            mike5490
                                            I have bought a brand new duet 2 ethernet board and am still having the same problems. Was hoping using an ethernet board would help.
                                            I updated the new board to firmware 3.1.1 and this is my results for M112 immediately after it reconnects
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later + DueX5
                                            Board ID: 08DLM-996RU-N8PS4-7JKD2-3S06T-9ABRN
                                            Static ram: 27980
                                            Dynamic ram: 94104 of which 60 recycled
                                            Exception stack ram used: 208
                                            Never used ram: 8720
                                            Owned mutexes:
                                            Last reset 00:00:21 ago, cause: software
                                            Last software reset at 2020-06-08 21:30, reason: Stuck in spin loop, spinning module Move, available RAM 8264 bytes (slot 1)
                                            Stack: 00454cdd 0045570c 61000000 a5a5a5a5 00454cdd a5a5a5a5 20004308 200041f8 00000002 2000512c 000124b9
                                            Error status: 0
                                            MCU temperature: min 30.2, current 30.9, max 31.1
                                            Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            Date/time: 2020-06-08 21:31:20
                                            Cache data hit count 39924084
                                            Slowest loop: 5.22ms; fastest: 0.13ms
                                            === Storage ===
                                            SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === Network ===
                                            Slowest loop: 8.15ms; fastest: 0.02ms
                                            Interface state active, link 100Mbps full duplex
                                            === DueX ===
                                            Read count 1, 2.76 reads/min
