Random disconnects DuetWifi 3.01 RC12
Beta Firmware
9
50
2.0k
    Alright. I've moved this to the beta firmware forum.
    If you go back to 2.05.1 do the disconnects stop?
      Viald
      Hello.
      I have the same issue since I upgrade to 2.05.1.
      I run before 2.04 beta
      When I switch to another tab of my browser and then go back few second later to the Duet one, the UI is disconnected, and then connected back automatically
      Connection interrupted, attempting to reconnect...
      HTTP request timed out
      K250VS Delta Printer / Duet 2 WiFi / Firmware: 2.05.1 / Duet WiFi Server Version: 1.23 / Duet Web Control 2.0.7
      undefined 1 Reply Last reply 13 May 2020, 22:53 Reply Quote 0
        Phaedrux Moderator @Viald
        @Viald said in Random disconnects DuetWifi 3.01 RC12:
        This has more to do with browser tab behaviour than the duet. Most browsers now days will put unfocused tabs to sleep to save power. This behaviour can be sometimes configured in the browser. There's not much the DWC can do about it when it's the browser than has severed the connection.
        undefined undefined 2 Replies Last reply 14 May 2020, 10:40 Reply Quote 2
          mike5490
          After installing 2.05.1 the disconnects actually seem to have gotten more frequent. I now can't even home a single axis without the disconnect happening. Any time I click a home button I get a spinning circle over the home button then a message saying "connection lost, attempting to reconnect". After about 10 seconds the blue led on the wifi chip will then flash twice then stay lit. Then the printer will say "connection established" but never finish the homing cycle and goes back to as if I just turned the printer on.
            So not related to RC12 at all then.
            Please try reflashing the 1.23 wifi server firmware. You can just upload it via DWC when connected.
            It may be a failing wifi module.
              mike5490
              I tried reflashing the 1.23 wifi server firmware and I am still having the same problem.
              Is there any way to fix or replace the wifi module if it is failing?
              undefined 1 Reply Last reply 14 May 2020, 18:53 Reply Quote 0
                Viald @Phaedrux
                @Phaedrux Thank you. Perhaps it's due to the browser but It doesn't happen before the upgrade with the same browser.
                I will check with another browser and let you know.
                  Viald
                  Tested with Chrome, no disconnection at all 🙂
                    Phaedrux Moderator @mike5490
                    @mike5490 said in Random disconnects DuetWifi 3.01 RC12:
                    Yes it can be replaced if you're handy with soldering. I believe a hot air rework station is recommended.
                    Check this thread out. He was able to remove it with just a soldering iron.
                    https://forum.duet3d.com/topic/15033/12v-on-the-5v-rail/46?_=1589482012979
                      mike5490
                      Okay, thank you.
                      Is there anything else that could potentially be the problem, as I'd only like to start desoldering parts from the board as a last option or is the wifi chip the most likely cause?
                        Well we've ruled out the firmware, and your signal strength is good, you've tried another router.
                        Unless there is some other source of interference in the area you can identify and eliminate.
                        You could try switching to another wifi channel.
                        You can try and provide an M122 from when it's disconnected.
                          mike5490
                          Trying multiple different wifi channels didn't seem to have any effect on it.
                          This is my results from M122 after it disconnects
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC12 running on Duet WiFi 1.02 or later + DueX5
                          Board ID: 08DGM-956GU-DJMSN-6J1DL-3SN6M-TTNRF
                          Used output buffers: 3 of 24 (8 max)
                          Static ram: 28084
                          Dynamic ram: 94064 of which 20 recycled
                          Exception stack ram used: 600
                          Never used ram: 8304
                          Tasks: NETWORK(ready,804) HEAT(blocked,1228) DUEX(blocked,160) MAIN(running,1820) IDLE(ready,76)
                          Owned mutexes: I2C(DUEX)
                          Last reset 00:02:19 ago, cause: power up
                          Last software reset at 2020-05-13 22:26, reason: Stuck in spin loop, spinning module Move, available RAM 8240 bytes (slot 2)
                          Software reset code 0x4084 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20004344 Task IDLE
                          Stack: 004549dd 00455412 61000000 a5a5a5a5 004549dd a5a5a5a5 a5a5a5a5 2000436c 2000425c 00000002 20005194
                          Error status: 0
                          MCU temperature: min 24.1, current 31.2, max 31.5
                          Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                          Driver 5: standstill, SG min/max not available
                          Driver 6: standstill, SG min/max not available
                          Driver 7: standstill, SG min/max not available
                          Driver 9: standstill, SG min/max 0/0
                          Date/time: 2020-05-14 15:23:48
                          Cache data hit count 241975993
                          Slowest loop: 25.44ms; fastest: 0.12ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 4.9ms, write time 0.0ms, max retries 0
                          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 17823ms
                          === MainDDARing ===
                          Scheduled moves: 16, completed moves: 16, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                          === AuxDDARing ===
                          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 31624.06ms; fastest: 0.00ms
                          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                          HTTP sessions: 1 of 8
                          • WiFi -
                            Network state is active
                            WiFi firmware version 1.23
                            WiFi MAC address 5c:cf:7f:76:68:e0
                            WiFi Vcc 3.42, reset reason Unknown
                            WiFi flash size 4194304, free heap 24696
                            WiFi IP address 192.168.1.101
                            WiFi signal strength -34dBm, reconnections 0, sleep mode modem
                            Socket states: 4 0 0 0 0 0 0 0
                            === DueX ===
                            Read count 19153, 8254.12 reads/min
                          ? 1 Reply Last reply 18 May 2020, 06:42 Reply Quote 0
                            Was that while disconnected or after reconnection?
                            undefined 1 Reply Last reply 15 May 2020, 04:34 Reply Quote 0
                              mike5490 @Phaedrux
                              That was after it had reconnected. Is it possible to get a readout while it’s disconnected?
                              undefined 1 Reply Last reply 15 May 2020, 11:49 Reply Quote 0
                                dc42 administrators @mike5490
                                Yes, via USB.
                                  mike5490
                                  I tried to get a M122 while it's disconnected but have been unable to
                                  Every time it disconnects the USB connection to my computer also disconnects, similar to as if I was unplugging the USB cable
                                  ? 1 Reply Last reply 18 May 2020, 05:44 Reply Quote 0
                                    mike5490
                                    After a bit more troubleshooting I've determined that the printer behaves as if I sent a M999 command but it occurs at random times
                                      A Former User @mike5490
                                      this always happen when the board is reset.
                                      running M122 first thing after connecting to the board again would be helpful. is there anything that could short against the reset pins or trigger the reset switch on the board? pictures and M122 might provide some insight.
                                        mike5490
                                        The results from M122 immediately after it reconnects are provided above in a previous post. There's nothing that could be pressing against the reset button.
                                        This is how the board is currently wired
                                          Please upgrade to 3.1.0 release firmware and if the problem continues, post another M122 report taken immediately after it reconnects.
                                          The ground wire between your Duet and DueX5 isn't done according to our wiring instructions. This might be part of the problem, OTOH the wires between them and the DueX5 are short, which will help to mitigate the incorrect wiring.
                                          13 out of 50
