    Constant errors
    Duet Web Control
    1.9k
      Phaedrux Moderator @Phaedrux
      @Phaedrux said in Constant errors:
      What firmware and DWC versions are you using?
      Also this
        A Former User
        It seems to be retalet more to object height, since when making it shorter and then printing it has no problems.
          A Former User
          Definitely height, any idea why?
            Phaedrux Moderator @A Former User
            @Torppa said in Constant errors:
            Yes. What firmware and DWC versions are you using?
              A Former User
              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1
                A Former User
                DWC 2.0.4
                  A Former User
                  Allso now, contant disconnects from printter, i have had so mucth problems with this board that its geting anoying.
                    3.0beta12
                    You're using a very old beta firmware. Please update to the 3.1 final release that just came out the other day. There have been many many fixes and likely also your error.
                    https://github.com/Duet3D/RepRapFirmware/releases
                    If I recall correctly there may be some issues with updating beta 12 specifically, so you may need to place the firmware file directly on the SD card with your PC and then send the m code to update the firmware.
                      A Former User
                      What file is it? all of them?
                        If you're running in standalone mode without a rpi, you can try to upload the main zip file through the web interface.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.0/Duet2and3Firmware-3.1.0.zip
                        If that does not work, then you would need to extract that file and place the bin files on the SD card and use M997 to update.
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
                          Just the Duet3Firmware_MB6HC.bin file will do initially. When you have installed that, the network connection should be reliable; then you can upload the .zip file to update the other components.
                            A Former User
                            And ofc i get an error, this thing is true POS.
                            I would imagine that paying 260€ would get you a quality product.
                              The firmware you are running is more than six months old. The Ethernet interface on the SAME70 microcontroller was new to us. We were still pulling the bugs out of the vendor-supplied network stack for that interface when we shipped the first Duet 3 main boards. We released an update to fix that network issue on 2 January.
                              Of course, I would have preferred to have shipped the first Duet 3 boards with perfectly stable firmware on them. But this isn't always possible, especially as some bugs only come to light with specific user configurations of the firmware.
                                A Former User
                                Cant update via usb or DWC, what are my options here? An exorcism?
                                  Need more detail. What happened when you tried to update via USB?
                                    A Former User
                                    Nothing, it wont connect.
                                    The first time setup was a pain, had similar issues.
                                    This is my 3rd duet 3 hc6 the first one didnt power on, second one was damaged in delivery so no idea if it would have worked as advertised and finaly this one i have has constant disconnects, random print stops and trying to print objects taller than 80mm ends in an CRC error.
                                    There is something seriously wrong your quality controll or i just have bad luck.
                                      If your PC runs Windows, when you connect the Duet to the PC via USB you should get a device showing up in Device Manager, normally under "Ports - Com & LPT" but possibly under "Unknown device". Does it? If not:
                                      • Put a jumper across the Erase pins of the Duet
                                      • Try a different USB cable (many USB cables sold with chargers supply power only, not data)
                                      • Try a different USB port on the PC
                                        A Former User
                                        its working for now, geting the same error as last time in YAT
                                        M20 P/www
                                        Begin file list
                                        NONE
                                        End file list
                                        ok
                                        The files are in correct order ect, there should not be any problems.
                                        The funny part is that a cheap controll board from china that cost me 20€ works better and is proven to be more reliable than this duet card.
                                        Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          meaning that if you put the SD card in a PC there are all the expected files in the /www folder?
                                            And if you ever do have issues with that board I doubt you'd be getting direct online support from the firmware author and hardware designer.
