    WiFi reported error: Failed while trying to connect
    Firmware installation
    1.9k
      If M122 reports that the WiFi firmware version is 1.23 then it has evidently been installed correctly. I think the WiFi module may be faulty and should be replaced.
      thrawn86undefined 1 Reply Last reply Reply Quote 0
      • thrawn86undefined
        thrawn86 @dc42
        unfortunately the replacement from filastruder has an identical issue
        M552 S0
        ok
        WiFi module started
        M587 S"***" P"***"
        ok
        M552 S1
        ok
        WiFi reported error: Failed while trying to connect to ***
        WiFi module is idle
        M552
        WiFi module is changing mode
        ok
        WiFi module is idle
        M552
        ok
        M115
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
        ok
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
        Board ID: 08DLM-996RU-N85T0-6JTD2-3S46Q-1UTZP
        Used output buffers: 1 of 24 (9 max)
        Static ram: 25680
        Dynamic ram: 93340 of which 164 recycled
        Exception stack ram used: 256
        Never used ram: 11632
        Tasks: NETWORK(ready,1268) HEAT(blocked,916) MAIN(running,3808) IDLE(ready,160)
        Owned mutexes:
        Last reset 00:08:27 ago, cause: power up
        Last software reset details not available
        Error status: 0
        Free file entries: 10
        MCU temperature: min 28.0, current 32.6, max 32.7
        Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
        Driver 0: ok, SG min/max not available
        Driver 1: ok, SG min/max not available
        Driver 2: ok, SG min/max not available
        Driver 3: ok, SG min/max not available
        Driver 4: ok, SG min/max not available
        Cache data hit count 1006782636
        Slowest loop: 100.14ms; fastest: 0.06ms
        Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
        === DDARing ===
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is ready with "M122" in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 1.26ms; fastest: 0.00ms
        HTTP sessions: 0 of 8
        - WiFi -
        Network state is changing mode
        WiFi module is trying to connect
        WiFi firmware version 1.23
        WiFi MAC address bc:dd:c2:2d:5e:3e
        WiFi Vcc 3.36, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 27224
        ok
        WiFi module is idle
        at this point I have done literally nothing but open the box, connect the antenna and perform the steps described in : https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7 , sans firmware update. 2.03 was what I was running on my first board connected to the same network, before the sd card slot died.
        • thrawn86undefined
          thrawn86
          in addition, subsequent attempts (restarting, forgetting and re-adding network, creating a new SSID and connecting to that instead) have all yielded the same variety of wifi error messages including:
          -Error retrieving WiFi status message: bad reply format version
          Error retrieving WiFi status message: SPI timeout
          Failed to change WiFi mode (code -7)
            A Former User @thrawn86
            @thrawn86 said in WiFi reported error: Failed while trying to connect:
            normally fixed by (from YAT etc)
            M552 S-1 ;to disable the wifi module
            M552 S0 ;to disable networking/idle wifi
            G4 S1 ;wait a second
            M587 S"" P"" ; insert ssid and passphrase to add wifi
            M552 S1 ;to enable networking
            but to try and get some more info on the other issues i'd run
            M588 S"*"; forget all previous access point info
            then power down, remove the SD card and power it back up without the SD card. connect to usb/YAT and run
            M111 P14 S1 ;to enable wifi debug
            (don't need to type ; and what comes after, but its safe to copy/paste as is)
            edit: unclear - you installed RRF 2.03 but wifi 1.23 was on there already?
            • thrawn86undefined
              thrawn86 @A Former User
              @bearer
              That was exactly what was on the board out of the box.
              e:
              M552 S0
              ok
              WiFi module started
              M588 S"*"
              ok
              M552
              WiFi module is disabled
              ok
              M111 P14 S1
              Debugging enabled for modules: WiFi(14)
              Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
              ok
              M552 S-1
              ok
              M552 S0
              WiFi:
              WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
              WiFi:
              ok
              WiFi: load 0x4010f000, len 1384, room 16
              WiFi: tail 8
              WiFi: chksum 0x2d
              WiFi: csum 0x2d
              WiFi: v3fff168c
              WiFi: ~ld
              WiFi module started
              G4 S1
              ok
              M587 S"Battlestar Pegasus Mainframe" P"***"
              ok
              M552 S1
              ok
              WiFi:
              WiFi: add if0
              WiFi: wifi evt: 8
              WiFi: scandone
              WiFi: ../src/SocketServer.cpp(353): found network dobry22
              WiFi: ../src/SocketServer.cpp(353): found network Alex WiFi
              WiFi: ../src/SocketServer.cpp(353): found network xfinitywifi
              WiFi: ../src/SocketServer.cpp(353): found network Brother Eye
              WiFi: ../src/SocketServer.cpp(353): found network luk-ela
              WiFi: ../src/SocketServer.cpp(353): found network PS4-A490FF8D684C
              WiFi: ../src/SocketServer.cpp(353): found network PS4-3B1F4A9CD2C0
              WiFi: ../src/SocketServer.cpp(353): found network Wifi is Jericho!!
              WiFi: ../src/SocketServer.cpp(353): found network Toilet Cam #12
              WiFi: ../src/SocketServer.cpp(353): found network Loki1
              WiFi: ../src/SocketServer.cpp(353): found network ATT528s735
              WiFi: ../src/SocketServer.cpp(353): found network The Room Of Requirement
              WiFi reported error: no known networks found
              WiFi module is idle
              WiFi: scandone
              WiFi: ../src/SocketServer.cpp(353): found network Petersen
              WiFi: ../src/SocketServer.cpp(353): found network SEC_LinkShare_836496
              WiFi: ../src/SocketServer.cpp(353): found network TK2.4
              WiFi: ../src/SocketServer.cpp(353): found network degapudi
              WiFi: ../src/SocketServer.cpp(353): found network CRAZYVirus
              WiFi: ../src/SocketServer.cpp(353): found network MAXIMUS
              WiFi: ../src/SocketServer.cpp(353): found network NETGEAR56
              WiFi module is idle
              WiFi: ../src/SocketServer.cpp(353): found network TP-LINK_D28A
              WiFi: scandone
              WiFi: ../src/SocketServer.cpp(353): found network NETGEAR20
              WiFi: ../src/SocketServer.cpp(353): found network Srbija 2G
              WiFi module is idle
              WiFi: scandone
              WiFi: ../src/SocketServer.cpp(353): found network Battlestar Pegasus Mainframe
              WiFi: ../src/SocketServer.cpp(353): found network BattlePi24
              WiFi: ../src/SocketServer.cpp(353): found network ATT3Hkz4Mq2.4
              WiFi: sleep enable,type: 2
              WiFi: wifi evt: 2
              WiFi: scandone
              WiFi: state: 0 -> 2 (b0)
              WiFi: state: 2 -> 0 (2)
              WiFi: reconnect
              WiFi: wifi evt: 1
              WiFi: STA disconnect: 2
              WiFi: scandone
              WiFi: reconnect
              WiFi: wifi evt: 1
              WiFi: scandone
              WiFi: reconnect
              WiFi reported error: Failed while trying to connect to Battlestar Pegasus Mainframe
              WiFi module is idle
              WiFi: wifi evt: 1
              WiFi: scandone
              WiFi: del if0
              WiFi: usl
              WiFi: mode : null
              WiFi: wifi evt: 8
              WiFi: mode : sta(bc:dd:c2:2d:5e:3e)
              WiFi: add if0
              WiFi: wifi evt: 8
              WiFi: scandone
              after that it just starts looping. Also, I was able to start it up in AP mode and I can get into DWC that way if needed.
                @thrawn86 is the network 2.4ghz?
                or maybe the SSID is too long for the firmware to handle, dc42?
                edit nvm, it finds the network but not on every scan, probaly poor signal quality.
                • thrawn86undefined
                  @bearer
                  to eliminate that possibility as well as the 2.4ghz issue (our network is simulcast 2.4/5.0) I created an entirely new 2.4ghz-only SSID with the same results.
                    A Former User
                    try running a wifi scanning app to see which channel is least congested and switch to that?
                    • thrawn86undefined
                      @bearer
                      I moved the antenna as close as I could, it looks like it is pulling in Battlestar Pegasus Mainframe and BattlePi24 on every scan, both of which are broadcasting 2.4, and the latter is 2.4 only.
                      2.4 is pretty crowded here but thats about the best I can do. It didn't seem to be a problem on my older duet with internal antenna.
                        all it takes is a new neighbor, its very unlikely both boards had a fault. maybe wifi and/or internal antenna isn't the best option for your location. (ed: or your router may be among a few that have shown to be incompatible with the ESP8266 chip, but if you haven't changed the router then odds are your environment changed. i.e. (new) neighbor with new wifi router causing poor signal)
