    Editing Large gcode File Connection Drop
    Duet Web Control
    511
    • CCS86undefined
      CCS86 @dc42
      This post is deleted!
      • CCS86undefined
        CCS86 @dc42
        @dc42 said in Editing Large gcode File Connection Drop:
        Please try firmware 3.01RC3. There has been a fix to networking on the Maestro since 3.0, but I don't have the details to hand so I don't know whether it is relevant or not.
        I just installed RC4 (assuming it has the same network fix as RC3), but the issue remains.
        The instant that the file is displayed, this error pops up:
        When it reconnects, I just get booted to the main screen.
        Let me know if I can gather a detailed log that would help you.
        • CCS86undefined
          CCS86
          Honestly, since upgrading from 3.0 to RC4, the network connectivity (outside this specific issue) seems worse.
          I frequently get dropouts on the web control display.
          • CCS86undefined
            CCS86
            I just tested with RC6 and the issue persists.
            • CCS86undefined
              CCS86
              RC11 and DWC 2.1.6
              Same issue. Any ideas? Is this more likely a DWC or RRF issue?
              • CCS86undefined
                CCS86
                Still happening in "stable" RRF 3.1 / DWC 3.1
                @dc42 Thoughts?
                  I was unable to reproduce this, having successfully edited a 9.2Mbyte file multiple times using FireFox under Windows. However, I have just tried again, and I have found that if I use Chrome instead of Firefox, I can reproduce the problem.
                  It's not specific to the Maestro because I have the same issue if I try to edit a 8.1Mbyte file on a Duet WiFi: it works using FireFox but not using Chrome.
                  We'll look into it.
                  CCS86undefined 1 Reply Last reply Reply Quote 1
                  • CCS86undefined
                    CCS86 @dc42
                    We'll look into it.
                    Thank you!
                    I can confirm, I am also using Chrome
                      We've fixed this in release 3.1.1. Thanks for reporting it.
                      CCS86undefined 1 Reply Last reply Reply Quote 0
                      • CCS86undefined
                        CCS86 @dc42
                        RRF 3.1.1 / DWC 3.1.1 installed and tested in Chrome.
                        A 13.9 MB file successfully edits now! Excellent!
                        However, my next size up is 15.8 MB, and that file and anything larger now have the "edit" menu option greyed out.
                        • chrishammundefined
                          chrishamm administrators @CCS86
                          @CCS86 This limit has been defined because at a certain size the HTML textarea becomes too slow to work with. We might be able to remove that once the new G-code editor from the pending DWC PR has been merged.
                          Duet software engineer
