    RRF 3.1+SBC / Board Restart takes much longer than before
    • ropiundefined
      ropi
      Hi, I recently updated from RRF 3.0 to 3.1 and noticed the Board Reset / Emergency Stop via Web Interface now takes a lot longer than before. Also it seems like the software stack on the SBC restarts as well, causing a lost connection to the DWC for a few seconds. Is there a setting to adjust this behaviour? With 3.0 the board reset was done within like half a second and now it takes what feels like about 5 seconds. I have an Arduino connected to monitor the PS_ON pin and if its not connected for more than a second it switches the printer off. So now with RRF 3.1 every time I want to restart the board via the web interface my printer shuts off. If it there is a setting I can tweak to get the old behaviour back without having to reprogram my Arduino that would be great.
      • ropiundefined
        ropi
        Just updated to RRF 3.1.1 and the behaviour stays the same.
        • chrishammundefined
          chrishamm administrators @ropi
          @ropi This is the case because the main component of DSF on the Pi is supposed to terminate when you perform a reset via M999 (which is what Emergency Stop does) and it takes approx. 10 seconds before it restarts. You can suppress this behaviour again by editing /opt/dsf/conf/config.json and changing NoTerminateOnReset to true.
          Duet software engineer
          ropiundefined 1 Reply Last reply Reply Quote 0
          • ropiundefined
            ropi @chrishamm
            @chrishamm this solved it, thank you!
