    Unable to connect to my Duet Wifi 2. Please help!
    806
    • ZPomeroyundefined
      ZPomeroy
      Hey guys,
      I’m having trouble with a duet wifi 2. I use a MacBook to interface with it, with simplify 3d. Yesterday I had everything running okay, bought the printer 2nd hand. I went though the process of connecting the printer to my wifi and everything was fine, until the extruder wasn’t able to get power from the board, it was still reading temps. I propped it down and adjusted the wires to make sure they were inserted correctly, and it was working again. I turned it off to stand it back up, turned it back on and haven’t been able to connect to it since. The screen is showing connecting no matter what, and when I try to connect through USB on my computer in simplify 3d the USB comes up, and I try to connect, but the message comes back failed to connect. Does anyone have any suggestions about how to fix it? Thanks in advance 🙏
      Cheers,
      Zac
        A Former User
        in general https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond and report back?
          It sounds like something might be shorting out inside of the case. Take the duet out and try and get connected via usb with nothing else connected and no sd card in. Follow the steps in the link above.
          • ZPomeroyundefined
            ZPomeroy
            Is there a way to to do the part “connect to a PC” without a PC, but a Mac?
              Yes you can use the mac.
              Pronterface is a USB terminal that works well with the Duet on Mac.
              http://www.pronterface.com/#download
              Example: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38#s141
              ZPomeroyundefined 1 Reply Last reply Reply Quote 0
              • ZPomeroyundefined
                ZPomeroy @Phaedrux
                I downloaded pronterface and followed the instructions on their github about allowing OSX to run unsigned apps. It’s coming up saying “the developer of this app need to update it to work with this version of macOS”
                • ZPomeroyundefined
                  ZPomeroy @ZPomeroy
                  If I buy a copy of Windows and do a bootcamp will that work the same as having a PC?
                    A Former User
                    Google "serial terminal for mac" should give you plenty of options (I was also under the impression YAT termial was available for Mac which doesn't seem to be the case?)
                    https://forum.duet3d.com/topic/3546/duetwifi-for-mac-os/5 gives a few options.
                      Ah, you must be running catalina? I doubt pronterface is going to update... last update was 2015. There are other serial terminals for mac I'm sure but I haven't used any.
                      Technically you don't need to buy a copy of windows. If you're already familiar with virtualbox you can install windows using an iso provided by microsoft themselves, do what you need in windows with YAT, and then torch the VM. I suggest windows 10 LTSC.
                      https://www.microsoft.com/en-us/evalcenter/evaluate-windows-10-enterprise
                      • ZPomeroyundefined
                        ZPomeroy
                        So Last night I was eventually able to get the board up and running by using my neighbours laptop. The problem now is that I have fresh new software on there that I now need to learn how to add all of the endstops and motors, extruder and the bed etc. I'm trying to follow the Delta config page, but I keep getting errors back like "M574: Pin name needed for switch-type endstop on X axis" is there a guide that I can follow that runs me through the process of adding in all of the tools of my printer before I start config files, so that it can see the tools? I apologise for the very basic questions, this is very new to me, and I am in no way shape or form a coder, so this is all rather overwhelming.
                        Thanks for your help,
                        Zac
                          Hi, sounds like you've got RRF3 on there now.
                          To simplify the configuration I suggest you use the online configurator tool to generate a config file set to start from.
                          https://configtool.reprapfirmware.org/Start
                          Fill it out to the best of your knowledge and feel free to ask questions.
                          Then when you have the config set sip file you can upload it to the web interface if you have access, or extract it and manually place the files in the sys folder.
                          • ZPomeroyundefined
                            ZPomeroy
                            I have a set of compiled g-codes that the previous owner has shared with me, I've been comparing it to to this https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
                            is this up to date for RRF3? I've been trying to upload the config files which were supplied (here: https://gist.github.com/BrianGilbert/e3f5065848081cc850fe3c7c32f6402b)
                            I don't have any of my tools added to the program yet. How do I go about doing that? I'm unsure how to define the end stop pin names etc and the extruder, bed, steppers, everything is all missing from my DWC even after uploading the config files through the DWC. Where do I go from here? I tried using the config tool and got stuck on the first page with the config tool saying my delta homed height and maximum carriage travel was too high and wouldn't allow me to continue. I'm extremely overwhelmed here, and I really don't know where to start, I'm feeling very lost and hopeless at the moment... If someone could help me through the process of this, I would be so appreciative!
                              jay_s_uk
                              you're probably best to generate a new set of config files using https://configtool.reprapfirmware.org/Start
                              You have the RRF2 config files from the previous owner so you'll have all the reference values on hand to put in.
                              • ZPomeroyundefined
                                ZPomeroy
                                How do I get around it saying my delta printer is too high? I’m transferring the dimensions right over and it’s not allowing me to use the homing height in the config files I currently have
                                  jay_s_uk
                                  ensure your maximum carriage travel is greater than your homed height
                                  • ZPomeroyundefined
                                    ZPomeroy
                                    I don’t quite understand how they’re different. The homed position should be at the maximum carriage, where the end stops are shouldn’t it? Or an I misunderstanding
                                      A Former User @ZPomeroy
                                      @ZPomeroy concider what happens if you move to z0 and x0,y0 - then you move to x100. One of the carriages will have to move further down than the possition it had at z0, x0, y0 - thereofre the carriage travel has to be longer than the usable z height (this got me the first time with a delta on RRF as well)
                                      • ZPomeroyundefined
                                        ZPomeroy
                                        So if the height of the nozzle above the bed when all three carriages are just high enough to trigger the endstop switches (ie Homed height) is 428.84 How do I figure out what the carriage travel is? I'm so sorry if I'm being irritating, its all so overwhelming, I still don't quite understand the difference and how to measure that from the homed height
                                          A Former User
                                          I'm sure you could calculate it with some trig functions, but I just measured the difference between z0x0y0 and the lowest carriage after manually moving the effector around the build plate and added a few mm for measure. You may want to wait for someone who knows that they're talking about to come up with a more scientific approact.
                                          • ZPomeroyundefined
                                            ZPomeroy
                                            I gave the config tool a go, trying to carefully move the settings over. I failed miserably. Is it possible to put RRF2 onto the board and use the current config files I have?
