    Panel Due with RRF 3.0 issue
    PanelDue
    8
    22
    1.3k
    • smoki3undefined
      smoki3 @dc42
      @dc42 said in Panel Due with RRF 3.0 issue:
      @MrSteve920 said in Panel Due with RRF 3.0 issue:
      When I go to the control page and click a macro to run, the display stops updating and the macro is never run.
      Please provide your config.g file and a sample macro file for which this occurs. If possible, also please confirm whether it still happens using the 3.01beta1 release.
      I think you got it wrong: If the temperatures and coordinates are already frozen then it is not possible to run any macro or something else.
      So its not related to any macro. The problem is more or less that the connection between the duet and panel due is broken
        dc42 administrators @smoki3
        @smoki3 said in Panel Due with RRF 3.0 issue:
        That's not what @MrSteve920 said:
        I have not experienced the display of temperature or coordinates freezing on its own. When I go to the control page and click a macro to run, the display stops updating and the macro is never run.
        • MrSteve920undefined
          MrSteve920 @dc42
          @dc42 Requested files attached:
          config.g
          1_Lights Off.g
          Config.g has been configured to account for the changes from release 3.0 to pre-release 3.01 beta 1, but I can't see how that would make a difference.
          Again to reiterate, I am not seeing any freezing on the temperature/coordinates prior to pressing a macro button on the panel. Also just for full disclosure, running these macros over the web interface causes absolutely no issues and it does seem to happen regardless of what macro I try to run (I've been using my overhead lights off macro as a test case).
          Tested this issue against 3.01 beta 1 and the issue is still present on that pre-release build.
          smoki3undefined 1 Reply Last reply Reply Quote 0
          • smoki3undefined
            smoki3 @MrSteve920
            @MrSteve920 Now I got what you mean. I also noticed that especially when you are printing and you call a macro for example "led off.g" then it has few minutes delay until it is executed. Thats also really wired
            • mloidlundefined
              mloidl
              Seems since v3 macro execution started from PanelDue is queued until a non printing move is done. At least this is what i have observed so far.
              For large print (especially the first layer), it may take a long time until the macro is executed.
              This happens to me when i try to switch On/Off my lights with the macros on the PanelDue. When executed from DWC it is executed after some moves, as with RRF 2.0.5.
              I will post my config later, since i currently have no access to it.
              Edit:
              Here are my config files. 1_Licht_ein.g and 2_Licht_aus.g are the macros mentioned in the post.
              personal_config.g
              estop_enable.g
              estop_disable.g
              config.g
              2_Licht_aus.g
              1_Licht_ein.g
                MrSteve920
                Is this something that will be resolved in the future or is this just going to stay the way it is because of some changes that were made in reprap 3?
                  Thanks for reminding me about this. I can see why the behaviour has changed, and I will fix it in 3.01-RC2.
                  MrSteve920undefined 1 Reply Last reply Reply Quote 0
                    This should be fixed in the RRF3 internal build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                      MrSteve920 @dc42
                      @dc42 Not a problem! Thanks for being so responsive as always. In the end, this is a pretty minor bug but it will be nice to have this working properly again.
                      • Damienundefined
                        Damien
                        I know this is an old post but I am having similar problems with Paneldue 7i. The panel was working fine, even after I updated my Duet 2 Maestro board to 3.1.1. I decided to update the firmware in the paneldue and now its stuck on "connecting" and none of the buttons work.(i.e. Nothing happens).
                        Any suggestions?
                          A Former User @Damien
                          @Damien said in Panel Due with RRF 3.0 issue:
                          Any suggestions?
                          read the https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310 before upgrading.
                          All PanelDue users: the PanelDue connector (or IO_0 on Duet 3) is no longer dedicated to PanelDue, therefore if you connect a PanelDue to this port you must use the following command in config.g to enable it: M575 P1 S1 B57600. You can use baud rates other than 57600, however the IAP files all assume 57600 baud; therefore if you use another baud rate then PanelDue will not display firmware update progress.
