Duet 0.85 2 z axis stepper motors
    Dave1167
    Hi all
    Apologies if this the wrong forum, but I can't find an alternative.
    I am just converting my Wanhao I3 to a duet 0.85. The printer has 2 z axis stepper motors. If I wire them up in parallel I would assume I would run into current problems as the current would be halved
    . Is there anyway to run a master slave setup using E1 ?
    Many thankfully
      T3P3Tony administrators
      Hi!
      You can use the M584 command to map any drive to any axis:
      https://duet3d.com/wiki/G-code#M584:_Set_drive_mapping
      so you could use
      M584 X0 Y1 Z2:4 E3
      Which would map the "Z" driver (number 2) and the "E1" driver (number 4) to the Z axis, leaving the E0 driver for your extruder.
      I am not sure about the Wanhao i3 but if it is a desktop size 3d printer then for Z axis it is normally fine to wire two stepper motors in series from one driver. See this wiki page:
      https://duet3d.com/wiki/Connecting_stepper_motors#Duet_0.6_and_0.8.5
        deckingman
        …............and don't forget that the Duet Wifi already has two Z motor connectors which are wired in series.
        3 out of 3
