Extruder issues
These are my settings and they work great
M350 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 Z160.00 E1837.00 ; set steps per mm
M566 X1000.00 Y1000.00 Z1000.00 E40.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E400.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E120.00 ; set accelerations (mm/s^2)
M906 X1700 Y1700 Z1700 E400 I45 -
Doesn't that M203 E400 result in your max print speed being ~7mm/s?
Apologies should be 2400
And you'll need to increase your steps as mines a version 2 only difference is steps due to drive ratio yours need to be higher
But I think the main problem is mA 1000 and microsteps as neither are as recommended by Zesty
500mA max and no interpolation on E as you are already pushing high steps it may overdrive the motor which sounds like you are having that issue ? -
I'll be damned. Your code fixed the issue. Thanks so much!
I was right where you were not long ago as the site doesn't actually say no interpolation unless you click through a good few page and then it's a bit incidental.
Glad its working better now you can have real fun with retractions! -
@Carlo
Oh and you may want to try lower mA even but not higher than 500 -
Cool. I'm still a bit confused as to why this caused a failure mid-print though. Any ideas?
Technology doesn't need a reason !
strain maybe on the motor ? that's a lot of pulses !Sorry what are your step for E ? they don't appear to be set
Sorry they are below ignore!
M92 E2792; I moved it back to where the others were. Interestingly I changed the M203 E400 to E2400 and the problem came back. So now I am back at M203 E400. I am a little unsure if this corresponds to mm/min of filament or extruded flow, though I lean towards filament. I am using a volcano hotend and 0.7mm line width at 0.3mm layer height, giving a volumetric flow of 12.6mm^3 /s at 60mm/s print speed. That volumetric flow is equivalent to 5.24mm/s of 1.75mm filament into the hot end.
So for every 1mm of 1.75mm filament driven, you can get 11.45mm of 0.7mm*0.3mm extrusion.
So 400mm/min at the extruder equals 76.33 mm/s print speed at those specified layer heights and line widths.
Only doing the filament calibration will tell sorry you'll need to do it again.
Sorry remember my gearing is not the same as your mine is version 2 so you may need to lower that because your steps are higher and if to high its the same as increasing vref mA
@cjorgensenmd said in Extruder issues:
If you had sent a M122 diagnostic after the failure you may have been a high number of hiccups, but that's just a guess.
