Help to configure order
Order discussion
3.4k
    njjn2020
    Hello! I plan to purchase duet ethernet + small screen for kossel printer.
    1. does it support 0.9 stepper motors?
    2. will 0.9 motor on kossel printer give higher precision?
    3. what kind of motor with your board will give more printing speed?
    4. do you sell in the US?
    thank you!
      1. Yes. You should use 24V power with 0.9deg motors, not 12V.
      2. Yes
      3. A motor with low inductance. The higher the rated current, the lower the inductance will be, so look for a motor with between 2.0A and 2.4A rated current per phase. For example, 17HM19-2004S. Longer motors will have higher inductance.
      See also https://duet3d.com/wiki/Choosing_stepper_motors.
      4. Our US distributor is Filastruder.
        njjn2020
        thank you very much for detailed responce.
        i can not find on the site
        1. Mini differential IR height sensor
        2. PanelDue without screen
        please advise how to add those items to the cart.
        have a great evening!
          elmoret
          If you mean the Filastruder site:
          https://www.filastruder.com/products/mini-differential-ir-height-sensor
          https://www.filastruder.com/collections/electronics/products/paneldue
            njjn2020
            and what for the UK site?
            i decided to buy directly from you. thanks!
              You can order those items directly from my escher3d.com web site. But if you are in the US, you'll get them faster if you order them from Filastruder.
                njjn2020
                well, i have decided that i will ship my order to russia from the uk. it will be faster and cheaper.
                is there a way to put
                1 duoWiFi (or Ethernet if availeble)
                2 pannel duo without screen
                3 IR probe
                to one order and single shipment (instead of ordering in 3 different places). thank you!
                  T3P3Tony administrators
                  I am sorting out the option to order a DanelDuet w/o screen now on the website, I will write again once its done.
                  We are currently out of stock of IR probes but I am hopieng we will have some more in stock soon.
                    njjn2020
                    ok, waiting for the integration result and IR probe availability
                      njjn2020
                      duet3d site login function does not work.
                      "The page you requested cannot be found."
                      link - https://duet3d.com/%3C/?php%20echo%20$login;%20?%3E
                        Will look into this now
                          adavidm
                          Can you get to it from here:
                          https://duet3d.com/index.php?route=account/login
                          It looks like a problem with escaping php in the website code.
                            njjn2020
                            with new link i have created new account
                            but was unable logon with account i use on forum. are those the same accounts?
                              njjn2020
                              "my account" in the right top corner does not work either.
                              link is defective (see below)
                              https://duet3d.com/https://duet3d.com/index.php?route=account/account
                                njjn2020
                                any luck with duet board for screen (without screen)?
                                  njjn2020
                                  by the way, is it possible to setup DuetWiFi without screen ?
                                    Yes, you can setup Duet WiFi using a USB connection to a PC.
                                      It should be fixed, please check
                                        Also the product page for the PanelDue has been updated. IR probes will be back in stock soon
                                          IR probes are now back in stock
                                          5 out of 26
