    Just a little lost re: upgrading to 3.0 firmware.
    Firmware installation
    2.1k
    • Steve Lynchundefined
      Steve Lynch
      I was a little sketchy on the whole servo pin angle entry below it as well. does that look ok?
        What do you have in your deployprobe.g and retractprobe.g files?
          Steve Lynch
          this is deploy:
          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Tue Jun 09 2020 01:46:51 GMT-0400 (Eastern Daylight Time)
          M280 P0 C"duex.pwm5" S10 ; deploy BLTouch
          this is retract:
          M280 P0 C"duex.pwm5" S90 ; retract BLTouch
          I tried reaching out to the railcore group, and as it turns out, there are 8 guys who couldn't get it to work, so they went back to 2.5, and one guy who says he can share his config with me, but he doesn't use a BL Touch.
          I went back to 2.5 last night so I could print, everything was fine, then I did the configurator again this morning. Still no Joy, though this time, it did add the BL Touch Info.
          So I guess I have to stick with this for everyone else, once we get mine right, I'll share the info.
          Does anyone have a CoreXY running E3D heater / thermistors, and BL Touch?
          If I can at least look at how it's set up, I can model mine after that.
          Thanks so much!
            Phaedrux Moderator @Steve Lynch
            @Steve-Lynch said in Just a little lost re: upgrading to 3.0 firmware.:
            C"duex.pwm5"
            Remove that from your M280.
            The M950 in your config.g creates the servo pin. M280 P0 targets that servo pin.
              M950 S0 C"duex.pwm5"                           ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
              M557 X15:215 Y15:195 S20                       ; define mesh grid
              ; deployprobe.g
              ; called to deploy a physical Z probe
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 12:35:40 GMT-0600 (Central Standard Time)
              M280 P0 S10 ; deploy BLTouch
              ; retractprobe.g
              ; called to retract a physical Z probe
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 12:36:12 GMT-0600 (Central Standard Time)
              M280 P0 S90 ; retract BLTouch
              That's right out of the configurator.
              Steve Lynchundefined 1 Reply Last reply Reply Quote 0
                Steve Lynch @Phaedrux
                @Phaedrux
                I had it set up just like you just posted, and this is the error I get every time.
                "Invalid servo index 0 in M280 Command."
                I'm in the port labeled PWM5 on the duex board. This really is PWM5, correct? PWM5 isn't really PWM7 or something like that, right? I'm just trying to figure out why I cannot deploy the probe. Everything try yields some error or another when I try the M401...
                  @Phaedrux said in Just a little lost re: upgrading to 3.0 firmware.:
                  That looks correct to me. If you send that command from the console, what response do you get?
                  Please verify using M115 that you are running firmware 3.1.1.
                    Steve Lynch @dc42
                    6/9/2020, 3:40:31 PM M401
                    Error: M280: Invalid servo index 0 in M280 command
                    6/9/2020, 3:40:11 PM Upload of config.g successful after 0s
                    6/9/2020, 3:37:03 PM M401
                    6/9/2020, 3:36:49 PM M401
                    Two tries, then cleared out, saved, re-opened blank deploy and retract g codes, and made them from scratch.. still same thing..
                      Steve Lynch
                      ; deployprobe.g
                      That's my deploy.....
                        And you have this exactly in config.g?
                          dc42 administrators @Steve Lynch
                          The command I wanted you to send from the console was the M950 command that I quoted.
                            Steve Lynch
                            This is my exact BL Touch Section:
                            ; BLTouch
                            M950 S0 C"duex.pwm5" ; Define the bltouch servo on duex.pwm5
                            G31 P500 X0 Y28.8 Z4.9 ; set Z probe trigger value, offset and trigger height
                            M557 X4:300 Y27:300 S20 ; define mesh grid
                              Steve Lynch @dc42
                              @dc42 Sorry sir... This is what it says:
                              6/9/2020, 3:48:23 PM M950 S0 C"duex.pwm5"
                              Warning: M950 command is not supported
                              6/9/2020, 3:48:06 PM M950 S0 C"duex.pwm5"
                                Looks like you are running RepRapFirmware 2.x then. Send M115 to check.
                                  Steve Lynch
                                  Here's what's in the "Machine specific" section...
                                  Electronics
                                  Diagnostics
                                  Board: Duet WiFi 1.02 or later + DueX5
                                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
                                  Duet WiFi Server Version: 1.23
                                  Note: You can install updates on the System page.
                                  Is there any merit to just starting completely fresh? I've upgraded / downgraded several times, and god only knows what could be mismatched. Again, not your fault, I'm just stumbling through this...
                                    Steve Lynch
                                    actually, It was waiting for a restart.... I may have created that problem myself... I was in 3.0 when I originally posted. I switched back down for last night, so I could print, and re-loaded from the configurator a little bit ago... I must not have re-specified my firmware version in the configurator when I uploaded My JSON. Sorry... I've been trying so may things, that I lost track...
                                      Steve Lynch
                                      I just started fresh.... Probe deploys and retracts now! It was the extra C"duex.pwm5" that was in my "deploy probe" that was causing the problem. Just removed it, and I Heard it click!
                                      So I was sooo close... Just had extra crap in the command.. Drats!
                                      Now to figure out My heaters.... I think I probably have to specify ports and stuff for them. I'll go try that, and leave you alone unless I can't get it!
                                      Also, the Configurator inserted extra lines in My BLTouch section. Stuff about Mod Probe, and servo angle and such.. It was not in the lines @Phaedrux sent me, so I deleted it.
                                      I appreciate your patience...
                                        Steve Lynch
                                        @dc42 @Phaedrux
                                        Thanks for helping me get this far. I'm down to 2 little dilemmas now... Well, Possibly three, but We'll just stick with the two...
                                        I've asked all around, and cannot seem to find an answer. What is the Gcode in 3.0 to release a BLTouch Alarm, and Pull Pin Up? I know thew old code was:
                                        M280 P0 S160.
                                        That's changed, and I tried replacing the P0 with C"duex.pwm5" but that doesn't seem to work.
                                        What's happening is that my BLTouch deploys, homes, then goes into "Flashing Mode" saying the pin was already triggered. Any Ideas?
                                        Lastly, I've always controlled lights Via PWM fan ports.
                                        I'm in Fan/LED 3 and Fan/LED 4 on the duex.
                                        If I make a macro with:
                                        M950 F3 C"!duex.fan3" Q0
                                        M950 F4 C"!duex.fan4" Q0
                                        Both Lights Turn Off
                                        any Q number over "1" results in full brightness.
                                        I used to be able to dim the lights using an integer between 1-255. any number I put in there now results in Full Brightness. These LEDS are extremely high output, so To avoid the extreme heat they put off, I simply dim them to 50%
                                        Any suggestions on how to change the dimming value? I believe it was reducing the voltage the way it used to do it. Do you know what the new way is? Thanks!
                                        Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                          Can you try a decimal number between 0 and 1? 0.1, 0.2, etc?
                                            @dc42 @Phaedrux
                                            M280 P0 S160.
                                            Assuming you are using servo index 0 to control the BLTouch, that should still work.
                                            Remove the ! and the Q0 parameters in those two M950 commands.
