    Just a little lost re: upgrading to 3.0 firmware.
    Firmware installation
    1.9k
    • Steve Lynchundefined
      Steve Lynch
      I'm using standard E3d heater, and thermistor, on the hotend.. thye bed is uaing a standard glass bead thermistor as it always has as well.
      Thanks so much for your assistance!
      • Dougal1957undefined
        Dougal1957
        in the M950 line for the BLTouch you have defined a pin on a DUEX expansion board is that correct?
        Steve Lynchundefined 1 Reply Last reply Reply Quote 0
        • whosrdaddyundefined
          whosrdaddy
          Yes the guide is indeed a bit unclear at times.
          the examples are using underscores in the pinnames but the list does not use underscores (ie e0heat vs e0_heat).
          I don't have access to my printers now so I don't know what naming convention I ended up using...
            Steve Lynch @Dougal1957
            @Dougal1957
            yes, I have, or at least I have attempted to, if you see my config above. I'm using the PWM 5 port on the Duex 5. but what to call it? does it need the Exclamation point before it? Does it need the Letter C before it? What does the C mean? "I've been trying to figure that out. I'm also trying to figure out if this new system simplifies the situation by using it's actual name, instead of the "always 1 or 2 off" manner of the old naming convention (example, Pwm 5 on the duex was actually referred to as PWM 7 in the total count).
            So for the name of the port, do I have to include all of the aliases? or just the port I'm using? Is duex pwm5 really pwm5? or Heater7? (it says in the list they're shared....
            This is where my head wants to explode! I see why this change was made, and I embrace it! I just want so desperately to understand the nomenclature, so I can have that light bulb go on over my head and i can say "I Understand Now!" lol
              Dougal1957 @Steve Lynch
              @Steve-Lynch try changing the BLTouch pin name in the M950 to C"expheater7"
              I am not promising but the description of the M950 suggests that.
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
                Dougal1957
                But having said all this I am sure you can use the Mod pin on the Probe connector to drive it but I am not a BLTouch user so not 100% on that
                  @Steve-Lynch said in Just a little lost re: upgrading to 3.0 firmware.:
                  M950 S0 C"duex.pwm5" ; define GPIO/Servo Pin
                  That's correct if you have connected the PWM servo input of the BLTouch to output PWM5 on the DueX.
                  Do the M401 and M402 command deploy and retract the pin?
                    Steve Lynch
                    No, they do not. I am definitely in PWM5 on the duex, with the orange on the left, red in the center, and brown on the right, as seen in the instructions. My white and black leads are plugged into the "probe" port, to the left of the 50 pin duex ribbon. I'm in the first two pinsfrom left to right. white, then black. the same way It's been set up in 2.5.
                      Steve Lynch
                      I was a little sketchy on the whole servo pin angle entry below it as well. does that look ok?
                        What do you have in your deployprobe.g and retractprobe.g files?
                          Steve Lynch
                          this is deploy:
                          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Tue Jun 09 2020 01:46:51 GMT-0400 (Eastern Daylight Time)
                          M280 P0 C"duex.pwm5" S10 ; deploy BLTouch
                          this is retract:
                          M280 P0 C"duex.pwm5" S90 ; retract BLTouch
                          I tried reaching out to the railcore group, and as it turns out, there are 8 guys who couldn't get it to work, so they went back to 2.5, and one guy who says he can share his config with me, but he doesn't use a BL Touch.
                          I went back to 2.5 last night so I could print, everything was fine, then I did the configurator again this morning. Still no Joy, though this time, it did add the BL Touch Info.
                          So I guess I have to stick with this for everyone else, once we get mine right, I'll share the info.
                          Does anyone have a CoreXY running E3D heater / thermistors, and BL Touch?
                          If I can at least look at how it's set up, I can model mine after that.
                          Thanks so much!
                            Phaedrux Moderator @Steve Lynch
                            C"duex.pwm5"
                            Remove that from your M280.
                            The M950 in your config.g creates the servo pin. M280 P0 targets that servo pin.
                              M950 S0 C"duex.pwm5"                           ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
                              M557 X15:215 Y15:195 S20                       ; define mesh grid
                              ; deployprobe.g
                              ; called to deploy a physical Z probe
                              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 12:35:40 GMT-0600 (Central Standard Time)
                              M280 P0 S10 ; deploy BLTouch
                              ; retractprobe.g
                              ; called to retract a physical Z probe
                              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 12:36:12 GMT-0600 (Central Standard Time)
                              M280 P0 S90 ; retract BLTouch
                              That's right out of the configurator.
                                Steve Lynch @Phaedrux
                                @Phaedrux
                                I had it set up just like you just posted, and this is the error I get every time.
                                "Invalid servo index 0 in M280 Command."
                                I'm in the port labeled PWM5 on the duex board. This really is PWM5, correct? PWM5 isn't really PWM7 or something like that, right? I'm just trying to figure out why I cannot deploy the probe. Everything try yields some error or another when I try the M401...
                                  @Phaedrux said in Just a little lost re: upgrading to 3.0 firmware.:
                                  That looks correct to me. If you send that command from the console, what response do you get?
                                  Please verify using M115 that you are running firmware 3.1.1.
                                    Steve Lynch @dc42
                                    6/9/2020, 3:40:31 PM M401
                                    Error: M280: Invalid servo index 0 in M280 command
                                    6/9/2020, 3:40:11 PM Upload of config.g successful after 0s
                                    6/9/2020, 3:37:03 PM M401
                                    6/9/2020, 3:36:49 PM M401
                                    Two tries, then cleared out, saved, re-opened blank deploy and retract g codes, and made them from scratch.. still same thing..
                                      Steve Lynch
                                      ; deployprobe.g
                                      That's my deploy.....
                                        And you have this exactly in config.g?
                                          dc42 administrators @Steve Lynch
                                          The command I wanted you to send from the console was the M950 command that I quoted.
                                            Steve Lynch
                                            This is my exact BL Touch Section:
                                            ; BLTouch
                                            M950 S0 C"duex.pwm5" ; Define the bltouch servo on duex.pwm5
                                            G31 P500 X0 Y28.8 Z4.9 ; set Z probe trigger value, offset and trigger height
                                            M557 X4:300 Y27:300 S20 ; define mesh grid
