Burned board?
-273.1c
looks very much like the thermistors are not physically connected thus not being seen by the board.
I would recommend you double check any connections between the board and the location of the thermistors for continuity.
For testing/diagnostic purposes I have a spare thermistor wired up with a short leads to a duet connector, this allows you to plug in a known good thermistor and eliminate it being the printers thermistor or confirm you have a board/config issue.
Here is a copy of a WORKING heaters section of code on a standard i3 style printer on a Duet2-Wifi board
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bed-temp
M950 H0 C"bedheat" T0 ; create bed heater output on bed-heat and map it to sensor 0
M143 H0 S100 ; set temperature limit for the bed to 100C
M307 H0 A78.8 C572.2 D4.9 V24.1 B0 ; settings for the bed after auto-tune
M143 H1 S280 ; set temperature limit for the hot end to 280C
M307 H1 A296.7 C79.4 D4.9 V24.1 B0 ; settings for the hot-end after auto-tune
@CaLviNx said in Burned board?:
-273.1c
looks very much like the thermistors are not physically connected thus not being seen by the board.a short perhaps, i think an open circuit reports 2000c due to the negative coefficient -273.1 would probably be a short - but thats all theory and speculation from my end
@bearer
possible but i have seen open circuit thermistors show the -273.1 value along with 2000 and an odd 3xxxx
either way diagnostics on those circuits are required checking for continuity (and shorts)
@CaLviNx You are right.
It was 2 faulty thermistors! Who could have thought :))Made a short wired spare thermistor both chanells works fine
CASE CLOSED
M140 H0 ; map heated bed to heater 0M140 H0 must come before you set the max temp with M143
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit -
@Phaedrux said in Burned board?:
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit if that's the case you might want to tell that to the guys who put the online config tool together, as that is where that list of code came from.....
The current config tool does put the M140 H0 command before the M143 H0 command. It has been updated recently, so perhaps it didn't when you ran it.
That came straight out of the config tool today, so it has been fixed.
I ran that last week, I'm still not convinced to fully make the jump over to RRF3 but I have to keep an open mind so I play with it when I have time, and as I'm getting older (or old fart as recently called...) I have learned to not remember everything for fear of overload (that's my excuse and i'm sticking to it)
I'm still using the online tool to generate the RRF3 config.g to help me compare the differences between the old/new code, and I dont remember shifting any heater code around.
I see the mention of it being required to come before the M143 command on the G code dozuki page, what is the official reason for this order requirement.
So that we can set a lower default maximum temperature for a bed or chamber heater than we do for an extruder.
