    Connecting…. never fully connects
    1.6k
    • StevenLundefined
      StevenL
      I will try these steps tonight. Thanks.
      That info should be made into a sticky forum note for all to see.
        The first part is covered at https://duet3d.com/wiki/What_to_do_if_your_Duet_or_Duet_WiFi_won%27t_respond.
        • TYPPA Albert Einsteinundefined
          @dc42:
          You may have ended up with incompatible versions of DuetWebControl, DuetWiFiServer, and DuetWiFiFirmware. Try this:
          1. Edit sys/config.g on the SD card, commenting out the M552 S1 command that enables the network. While you are at it, put the latest versions of DuetWiFiFirmware.bin, DuetWiFiServer.bin and DuetWebControl.bin ni the /sys folder of the SD card. Make sure they have exactly these names, i.e. remove the version numbers from the names of the files you downloaded.
          2. Put the SD card back in the Duet and see whether you can connect via USB.
          3. If you can't connect via USB, check whether your PC can see the board as a Duet. If it shows up as an unknown device, then you don't have the correct device driver installed.
          4. If you still can't connect via USB, download sam-ba, then erase and re-flash the firmware.
          5. When you are connected via USB, run M105 to check you are running the latest DuetWiFiFirmware (1.18.1). Then use M997 S1 and M997 S2 to update DuetWiFiServer and DuetWebControl.
          6. Send M552 S1 to re-enable WiFi, and you should be able to connect via WiFi.
          7. Edit config.g over the network to re-enable the M552 S1 command.
          HTH David
          Hi Dc42 David,
          I can not at all connect to my Wi-Fi network. I installed the latest version of the FW stable with 1.3 DuetWifiServer, but nothing When I type M552 S1 does not appear to enable the connection of IP Duet. He did the procedure with Sam Ba, then erase and re-flash the firmware. (Windows)
           the latest DuetWiFiFirmware (1.18.1). I used the commands M997 M997 S1 and S2 to update DuetWiFiServer and DuetWebControl (iMac) But nothing to do does not come out to me the IP Duet with M552 S1 command. Use Windows to re-flash with Sam Ba and Mac / Crome to update Server / DWC. I do not see the end is five hours that I try in every possible way but nothing. Problems with DuetWifiServer? Very bad my English, sorry
          I have no special talent. I am only passionately curious.
          -Albert Einstein
            Does the WiFi module start up in access point mode, and are you able to connect to it, selected your access point, and enter the password?
            A known issue is that passwords containing accented characters will not be processed correctly.
              @dc42:
              My PW os very simple is only number and letter
              i not abile to set the PW
              see the image ….duet is dialUP ?
              i send email whit various screenshot
              -Albert Einstein
                non able to send image …
                DuetWiFiServer version 1.03 (ch fork)
                Flash size 4194304, free RAM 32072 bytes, WiFi Vcc 3.10V, host name: duetwifi, reset reason: Turned on by main processor
                WiFi is running as an access point with name DuetWiFi
                serial: M105
                NOT SEE the IP
                my network work on
                Tiscali network DHCP
                Net mask: 255.255.255.0
                Roter 192.16811.254
                DNS 192.16811.254
                AirPort Mac see the DuetWIFI but i non possible to set PW
                -Albert Einstein
                  Do you have a smartphone that you can use to connect to the DuetWiFi access point?
                    @dc42:
                    YES
                    but i see the 192.168.1.100 ( iPhone)page from setup i set the TISCALI NETWORK and my PW….send and reboot me please....send from HOST M552 S1 / M552 S0 but not set the password same problems
                    -Albert Einstein
                      Hi Dc42
                      –----When you are connected via USB, run M105 to check you are running the latest DuetWiFiFirmware (1.18.1)
                      M115 version of FW !! on wiki M105 Temperature check
                      FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-04-09
                      Help me for wifi ?
                      -Albert Einstein
                        T3P3Tony administrators
                        Can i just triple check something.
                        When you have the DuetWifi in access point mode (it says so in the pronterface output you pasted in a previous comment), you then connect to the DuetWifi access point. When you go to 192.168.1.1 in your web browser, do you get a basic screen showing your WiFi network SSID (and maybe other nearby networks?) You then have to enter your WiFi network password and save, then reboot.
                          @T3P3Tony:
                          SOLVE : I have very large 20/25 nearby wifi SSID on my listing and the Duet wifi attact on the this router … now Duet wifi work perfect on my network .... thanks
                          -Albert Einstein
