    Acceleration test - but the result doesn't change
    544
    • houpdeltaundefined
      houpdelta
      I tried to do an acceleration test, but the result doesn't change.
      First test I printed with no gcode modification of the part.
      Second test.
      In the gcode, I added the M201 P400 before layer=0 and every five centimeters, I updated the code with M201 P800, M201 P1200, ....
      Between test one and test two, the parts are identical like the code M201 doesn't work.
      I read in the old post, that I need to add the M400 before each M201, I tried but same result.
      I have downloaded the part from the web interface.
      I'm a beginner, I think we have a PEBCAK issue 😊
      Thanks for helping me.
      Regards.
      AM8 BLV build
      theruttmeisterundefined 1 Reply Last reply Reply Quote 0
      • theruttmeisterundefined
        theruttmeister @houpdelta
        @houpdelta
        You are using the wrong g-code. M201 sets per-axis (X,Y etc). P (and T) is used with M204 to set acceleration when extruding or not.
        So:
        M201 X8000 Y8000
        M204 P4000 T8000
        Would limit acceleration while extruding to 4000mm/s/s. But allow travel moves to be at 8000mm/s/s
        But:
        M201 X4000 X4000
        M204 P4000 T8000
        Would mean that travel moves would still just be 4000mm/s/s.
        Check your base M201 values and try again with M204
        Isolate, substitute, verify.
          houpdelta
          Sorry, I made a mistake in my previous post.
          I have this in my gcode.
          ;Layer:0
          M400
          M201 X3000 Y3000
          M204 P400
          ;Layer:5
          M204 P800
          ;Layer:10
          M204 P1200
          ;Layer:25
          M204 P2400.
          regards.
          AM8 BLV build
            Does your slicer have any acceleration controls enabled? Can you share the gcode file itself?
              houpdelta
              No problem
              AA8_acceleration_test_piece_modify.gcode
              AM8 BLV build
                @houpdelta
                Whats the acceleration on your E axis? Its possible that's the limiting factor.
                  Yes please share your full config.g
                    houpdelta
                    You could find the config.g
                    config.g
                    it has been generated by the RepRapFirmware Configuration Tool.
                    I just comment the lines M201, M203, M205 to do test.
                    I used Cura to generate the gcode.
                    AM8 BLV build
                      Phaedrux Moderator @houpdelta
                      @houpdelta said in Acceleration test - but the result doesn't change:
                      Don't do that. It's no wonder there was no change in the printed file because you've removed the definitions for all motors.
                      ;M201 X3000 Y3000 Z3000 E250.00:250.00              ; set accelerations (mm/s^2)
                      ;M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00    ; set maximum speeds (mm/min)
                      ;M205 X900.00 Y900.00 Z12.00 E120.00:120.00         ; set maximum instantaneous speed changes (mm/min)
                      Leave those in config.g. When you alter the value in the print file with M204 P T it will override the print move and travel acceleration the way you want and leave the other settings intact.
                      • fractalengineerundefined
                        fractalengineer
                        I just did the test on my duet 3 last night.
                        I followed the same steps with the M204 after every x layers,
                        BUT I also increased the global accel BEFORE the first M204 to make sure it's not limiting it.
                        So the first line would be
                        ; Layer = 0
                        M201 X3000 Y3000
                        M204 P400
                        Railcore II ZL
                          Did you uncomment your speed settings in config.g?
                          houpdeltaundefined 1 Reply Last reply Reply Quote 0
                            houpdelta @Phaedrux
                            @Phaedrux
                            Yes I uncommented the line.
                            I did tests, but at the same time I have found another problem and I have to resolve it before.
                            I will post this problem in the right category.
                            Regards.
                            AM8 BLV build
