    How can I control addressable RGB LEDS?
    35
    4.5k
    • matej1006undefined
      matej1006 @matej1006
      @appjaws what pin's did you use gpio or which one's
      • appjawsundefined
        appjaws
        @matej1006 I connected the RGB wires to the fan outputs negative pins for fan 3,4 and 5 and the common wire to the positive .
        the LED settings were then added to config.g:-
        ; LED Lighting
        M950 F3 C"duex.fan3" Q500 ; create fan 3 on pin duex.fan3 and set its frequency for LED Red
        M106 P3 C"RGB Red" ; set RGB Red to P3
        M950 F4 C"duex.fan4" Q500 ; create fan 4 on pin duex.fan4 and set its frequency for LED Green
        M106 P4 C"RGB Green" ; set RGB Green to P4
        M950 F5 C"duex.fan5" Q500 ; create fan 5 on pin duex.fan5 and set its frequency for LED Blue
        M106 P5 C"RGB Blue" ; set RGB Blue to P5
        I just bought a strip from amazon, my system is 24V so I bought a 5 meter reel of DC24V LED Ribbon.
        Hope this helps
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
        matej1006undefined 1 Reply Last reply Reply Quote 0
          matej1006 @appjaws
          @appjaws mm ok thenyour strip isn't same as my, i have only 3 cabel to connect i have 2 wire for supply voltage and one for digital input.
          So i guess i will need to add arduino anyway . thanks 😉
          Greetings Matej
          • appjawsundefined
            appjaws
            This is a link for the 12V version at £8.50
            JOYLAND 12V Flexible RGB LED Strip Lights 300 Units 5050 LEDs, Non-Waterproof LED Tape Multi-Colors LED Strips Light Pack of 16.4ft/5m
            by Joyled
            Simplify3D 5.1.2
              matej1006 @appjaws
              @appjaws Link don't work
              • appjawsundefined
                appjaws
                @appjaws said in How can I control addressable RGB LEDS?:
                just do a search in amazon for JOYLAND 12V Flexible RGB LED Strip Lights
                Simplify3D 5.1.2
                • hersheycjundefined
                  hersheycj
                  I have recently setup the E3D Toolchanger with a Duet2 Wifi and Duex5 boards. I also upgraded to the RRF3 firmware and had a question regarding setup of Neopixel lights with these boards. I am wondering, what is it about the Duex5 board which requires an additional Arduino to control the LED lights. From first inspection, I would have thought the PWM pins on the Duex5 along with M950 and M150 gcode would have been enough to control the LED lights. What is it about the arduino board that makes it a necessary component?
                  • whopping pochardundefined
                    whopping pochard
                    For normal non-addressable RGB LEDs, you’re exactly right. However, if you want to use fancy individually-addressable LEDs like Neopixels, an Arduino offers a convenient way of controlling them via existing libraries.
                    hersheycjundefined 1 Reply Last reply Reply Quote 1
                      hersheycj @whopping pochard
                      @whopping-pochard said in How can I control addressable RGB LEDS?:
                      That makes sense. Thanks for clearing it up. I'll play around with both.
                        Neopixels have tricky timing requirements, which means that unless you use DMA to SPI, you have to stop all other processing while writing to them.
                        The Duet 3 main board supports Neopixel strips directly, because the CPU on that board had a spare SPI channels that we could dedicate to Neopixel support, and enough RAM that we were able to dedicate some to a Neopixel DMA buffer. Duet 2 doesn't have a spare SPI channel.
