    Duet3 Diag constantly flashing
    919
    • Lanovarundefined
      Lanovar
      But i didnt change anything.
      i forgot to tell, that the "old" SD card, wouldnt show up in windows.
      • Lanovarundefined
        Lanovar
        @bearer
        Ok, now Im not getting timeouted, instead:
        Your Duet rejected the HTTP request: page not found
        Check that the SD card is mounted and has the correct files in its /www folder
        • Lanovarundefined
          Lanovar
          And after a reboot - timeouted again.
            A Former User @Lanovar
            sounds like the backup card doesn't have the duet web control files on it.
            download and extract to /www on the sd card.
            https://github.com/Duet3D/DuetWebControl/releases
            (and its not a timeout, its a http 404 not found error)
            • Lanovarundefined
              Lanovar
              Isnt the /www included if i download the .zip from DWI? Maybe my problem is, that I'm trying to upload without the www and sys?
                @Lanovar said in Duet3 Diag constantly flashing:
                no.
                how are you uploading the files without a functioning DuetWebControl? you probably need to copy the files onto the sd card from your computer (into the correct folder, which may or may not need to be created if it doesn't exist)
                • Lanovarundefined
                  Lanovar
                  Sorry, by uploading I meant via SD card. And you were right, but not only the DWI was missing. The whole SD card deleted itself. I dont know how that happend with a pretty new card.
                  The old card doesnt even show up in windows. Do you have any ideas/experience on that?
                  I got it back up and running so far, but i dont have a backup of my macros. 😕 Any tipps on maybe recovering the old one?
                  Maybe a hint in the documentation about file structure and how to "rebuild" a SD card if one fails would be nice. (What i did is, just throwing the unzipped config onto the card and putting it back into the printer - now I can tell you: "that doesnt work" haha)
                    true story: http://google.com/?q=duet+sd+card
                    you could google fat32 recovery but odds are slim.
                    Lanovarundefined 1 Reply Last reply Reply Quote 1
                    • Lanovarundefined
                      Lanovar @A Former User
                      In my case this link would have been all I need. Whos taking care the documentaion?
                      @bearer said in Duet3 Diag constantly flashing:
                      Sadly i dont get my PC to detect the card. 😕
                      But thanks to your help, I got all up and running again. (and I have a backup now! 🤦 )
                        Phaedrux Moderator @Lanovar
                        https://duet3d.dozuki.com/Wiki/SD_Card
                          A Former User @Phaedrux
                          I believe that was the first result in google; and I was trying to make a point ... 😇
                          • Lanovarundefined
                            Yes, i know. I didnt google for SD card, but for the problem in my words. And I did not find this... So my idea was just to help others who might be thinking the way I was. But anyways, thanks for your help-
                              droftarts administrators @Lanovar
                              @Lanovar Links to that SD card page are all over the documentation, including on the first page and in the troubleshooting section. I've added a link here, too: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
                              • Lanovarundefined
                                Lanovar
                                @droftarts Thx.
                                Didnt want to make it that complicated, I was just trying to help and make it a bit easier for new users like me.
                                  Thanks for sharing your new user perspective. We're always trying to make it as easy as possible for new users to try and lessen the learning curve.
