tfree1.g is being ignored
I have a very simple tfree1.g. I have a y joiner on a single nozzle hotend and want to pull out filament 100mm, the push in 100mm of the other filament when needed. I can get it to handle one extruder at a time, but when it come to tool changes, my macros are completely ignored. It seems to do a normal retraction rather than a normal retract followed by tfree1.g or tfree0.g.
Weirdly, if I just run the macros in the webui manually, they work fine.
tfree0.g
T0; troubleshooting tool changes. Probably should remove this when finished M83; relative mode G1 E-100 F2500; rip it upward tfree1.g
T1; troubleshooting tool changes. Probably should remove this when finished M83; relative mode G1 E-100 F2500; rip it upward tpost0.g
T0; select itself -_- M83; relative mode G1 E100 F2500 ; ram it down tpost1.g
T1; select itself -_- M83; relative mode G1 E100 F2500 ; ram it down config.g
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Feb 26 2020 15:22:01 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"foamboard forge" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes backwards M569 P5 S1 ; physical drive 5 goes forwards M569 P6 S1 ; physical drive 6 goes forwards M584 X0 Y1 Z2 E5:6 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E824.00:824.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z1800.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X320 Y300 Z350 S0 ; set axis maxima ; Endstops M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S0 P"ystop" ; configure active-low endstop for low end on Y via pin ystop M574 Z1 S0 P"zstop" ; configure active-low endstop for low end on Z via pin zstop ; Z-Probe M558 P9 C"^duex.e2stop" H5 F120 T6000 M950 S0 C"duex.e3heat" ; create servo pin 0 for BLTouch G31 P25 X-40.2 Y-7.5 Z2.9 ; set Z probe trigger value, offset and trigger height M557 X29:270 Y27:267 S24:24 ; define mesh grid ; M557 X40:340 Y10:310 S24 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp ; M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp M950 H0 C"e0heat" T0 ; create bed heater output on e0heat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin duex.e2temp M950 H1 C"duex.e2heat" T1 ; create nozzle heater output on duex.e2heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"duex.fan5" Q500 ; create fan 0 on pin duex.fan5 and set its frequency M106 P0 C"part cooler" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"duex.fan4" Q100 ; create fan 1 on pin duex.fan4 and set its frequency M106 P1 C"hotend" S0 H1:1 T30 ; set fan 1 name and value. Thermostatic control is turned on M950 F2 C"duex.fan3" Q500 ; create fan 2 on pin duex.fan3 and set its frequency M106 P2 C"mcu" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency M106 P3 C"lighting" S1 H-1 B0 ; set fan 3 name and value. Thermostatic control is turned off ; Tools M563 P0 S"hotend" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"hotend" D1 H1 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings M308 S2 P"duex.e3temp" Y"thermistor" A"chamber temp" T100000 B3988 C0 R2200 ; chamber temperature sensor M307 H0 A150.1 C1119.9 D1.6 V24.2 B0 ; calibrate bed heater M307 H1 A348.9 C165.7 D3.7 C24.2 B0 ; calibrate hotend heater ; M558 P9 C"^duex.gp1" H5 F120 T2000 ; config UI does not allow gpio/endstop assignments to zprobe input but rrf3 does. Put it in manually. ^duex.e2stop or ^duex.gp1 ; TODO ; When a separate lighting control method is found, break lighting out from fan controls and finally, the attached test gcode file. testrun2.gcode
I'm sure its obvious, but I cannot find what's going wrong. It just wants to jam filament together rather than pull one completely out and put the other completely in.
This is just a guess, but can you try adding some M400 commands to your macros?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M400_Wait_for_current_moves_to_finish
Where in the macros would be helpful? Doesn't it normally complete a line before acting on the next one?
At the start of the macro? Like I said, it's more a guess.
I did some more playing around to get the behavior of this setup closer to that of the gcode the original creator's generator puts out. I had to guess and check the extrusion lengths, speeds, and replace some weird wiggle thing with dwell time, but it's kind of working now.
I can't call it a success though. The part it pulls out of the hotend has a wider diameter tip than the rest of the filament so when it goes to push it back in, it gets stuck. From what I can tell, its because I'm using an all metal hotend and there's nothing narrow inside to scrape it off on.
I think the prusa MMU was having similar issues with tip diameter, maybe look into how they were dealing with it.
