Configure external trigger - using Momentary Switch for LED
485
    callielli
    Hi guys,
    I have a question for the brains' trust.
    Can I use M581 to turn on an LED strip light via the Duet3?
    The PSU voltage and the LED are both 24V, I have a momentary switch spare which I can change to a latching setup however if I can direct the power through the board and use the mom-switch acting as a an end stop trigger of sorts, that would be my preference.
    Is M581 able to be used without a print being active? Or is it only called from inside a processing G-Code file?
    Would my code look something like:
    M581 P"e0stop" T2 C1 ; invoke trigger 2 when a rising edge is detected on the E1 endstop input
    but need to define a trigger too?
    Thanks everyone
      aidar
      Using Duet3 board makes me assume you are using latest firmware on it. So:
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later
        Send M115 to verify what firmware version you are actually using. should be 3.1.1
        undefined 2 Replies Last reply 24 Jun 2020, 00:49 Reply Quote 0
          callielli @Phaedrux
          @Phaedrux FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-04-21b1
            callielli @Phaedrux
            @Phaedrux
            From what I can see there, M581 can be triggered when the SD card has an active GCode being printed.
            Is there a function I can use to trigger all the time? ie: when the Duet has power?
            undefined 1 Reply Last reply 24 Jun 2020, 02:41 Reply Quote 0
              Phaedrux Moderator @callielli
              @callielli said in Configure external trigger - using Momentary Switch for LED:
              That is the default of the R parameter as far as I read it.
              Please update to 3.1.1
              undefined 1 Reply Last reply 24 Jun 2020, 02:57 Reply Quote 0
                callielli @Phaedrux
                @Phaedrux
                I have just tried to upload the firmware downloaded via the RRF Config tool and get an error:
                M997 S0
                Error: M997: In-application programming binary "Duet3_SDiap_MB6HC.bin" not found
                undefined 1 Reply Last reply 24 Jun 2020, 03:11 Reply Quote 0
                  callielli @callielli
                  @Phaedrux
                  M997 S0
                  I will try to start from scratch on a formatted card as I am not confident the issue hasn't been introduced by something silly I might have missed.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3_SDiap_MB6HC.bin
                    You're just missing the IAP file from the 3.0 release.
                    undefined 1 Reply Last reply 24 Jun 2020, 03:23 Reply Quote 0
                      callielli @Phaedrux
                      @Phaedrux
                      Thanks, I'll get it in there!
                      Appreciate your guidance!
                        callielli
                        M115
                        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2
                        Sorted - thanks mate!
                        6 out of 11
